peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5274 Location: Taoswest, USA
Posted: Wed Mar 25, 2009 11:25 am Post subject: Can I get some wheel offset help? |
I have a 68 Westy, which I am just beginning a resto on. I want to run BFG All Terrain Radials on it. I am thinking of using CIP1 wide 5 white spoke rims, but I am concerned about the correct offset for the wheels.
I would like to put 195x15 tires all the way around.
Can someone help me with the correct offset, maybe from experience, or from actual knowledge. I do not want to cut the rear fender wells.
Thanks for any help! _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
calebmelvin Samba Member
Joined: July 19, 2006 Posts: 3140 Location: Seattle, WA
fusername Samba Member
Joined: March 15, 2006 Posts: 2897 Location: Boston MA
Posted: Wed Apr 01, 2009 7:11 pm Post subject: |
can you find BFG All terrains in your shoe size? make sure before you start setting up. _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote: |
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
Kirk Samba Member
Joined: December 05, 2003 Posts: 5487 Location: North Texas
fastmc25 Samba Member
Joined: January 01, 2004 Posts: 1202 Location: East Tennessee
Posted: Thu Apr 02, 2009 5:16 am Post subject: |
Try these....... 32 x 10.50R15"
_________________ Peace,
Paul
1973 Type181 Kubelwagen (Thing 2 ) 2110cc
1971 Transporter (Pickle) 1914cc
1961 Deluxe Beetle (Christine) 1776cc
1973 Adventurewagen Baja Bus (Clyde) 3.4L
1970 Formula Vee Beetle 2276cc
I identify as: “A Pissed Old GI ” |
Posted: Thu Apr 02, 2009 7:37 am Post subject: |
show off. One of these days I'll match that build, but AC all the way! _________________ [email protected]
Posted: Thu Apr 02, 2009 7:42 am Post subject: |
fusername wrote: |
show off. One of these days I'll match that build, but AC all the way! |
If i had the cash i'd put a 2.7 or 3.0 Porsche in it ..... and be aircooled too.... I'd burn up a type 4 in this thing.... especially pulling my trailer loaded....uphill both ways.... _________________ Peace,
Paul
krautwaggen Samba Member
Posted: Thu Apr 02, 2009 11:44 am Post subject: |
I'm having a wheelset made for my 68 single cab. Beetle centers with stock width (for a bus) outers. The highest part of the cost will be having the shop cut the wheels apart and reassemble. I'll then have the proper offset with a near stock looking 15" wheel that is also the right width for a bus. My only issue is that the front wheels will be running adapters (to a late bus beam) I have to decide whether I want to try to compensate for the 1/2" or so track increase on each side by adjusting the offset (which will make the front wheels different than the rears) or just have a slightly wider track up there.
Most aftermarket wheels will not suit your application. Not wide 5 anyway.
You could run adapters and use Eurovan wheels although you'll have to do some math there. The adapters will make the needed offset increase (by however thick they are) I beleive the Eurovan wheels are about ET58 while bay's are et38.
Option F...change your bolt patterns using parts from a late bay and use Audi/Mercedes rims. I believe the steelies will fit with little modification and have a near stock offset. I've seen them on more than a few late bays (one recently for sale in the classifieds was running General Grabber AT2s and looked pretty sharp.
Check out the Vanagon and Split forums as well as the offroad forums for more information on this stuff. _________________ Half Bus, Half Truck, What the _______? |
type2much Samba Member
Joined: November 13, 2003 Posts: 319 Location: 65536 Missouri
Posted: Mon Dec 09, 2013 11:34 am Post subject: |
I've searched and have not found an answer. Are split bus and early bay 14" rims the same or interchangeable? If they are different is it the offset, or weight rating, or what? thanks! _________________ Gnarly Goat Rancher |
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Brian Samba Moderator
Posted: Tue Dec 10, 2013 6:28 pm Post subject: |
I'm trying to do the same thing on my single cab. I have 215/75-15 goodyear wranglers and the section width is 8.5 inches and they're currently mounted on 5 inch beetle rims. This setup is unsafe so I'm getting deep smoothies, and am in the same boat for what offset is needed. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
westfaliaftw Samba Member
Joined: April 02, 2011 Posts: 64 Location: Alberta, Canada
Posted: Tue Dec 10, 2013 10:51 pm Post subject: |
I'm putting general tire grabber at2's on my '73 bus. They only make them in 1 size in the 14" diameter. The 27 x 8.5 r14's. They seem to fit just fine so far. _________________ 1974 standard beetle - Africa red
1959 deluxe beetle - l41 black/brick red interior
1956 single cab - dove blue
1961 standard micro bus - mango green/dove grey
1971 campmobile - pastel white |
