TopBud Samba Member
Joined: February 28, 2004 Posts: 1111 Location: Flagstaff AZ
Posted: Wed Mar 25, 2009 12:56 pm Post subject: slider door lock seal |
I have been looking for a long time for a seal that goes around the door lock on the slider. The handle and the lock (where you put the Key) are separate and I am missing the seal. Does anyone know of a supplier. It is a 74. thanks in advance _________________ 86 bostig SYNCRO
66 convertible Karmann Ghia |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Wed Mar 25, 2009 1:55 pm Post subject: |
You might try Chris at Busted Bus. He had one for my '76/77 buses. Not cheap, however. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
SGKent Samba Member
Posted: Wed Mar 25, 2009 2:09 pm Post subject: |
we got our plastic seal from BusDepot
http://busdepot.com/details.jsp?partnumber=J10968 _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Rubber Duck Samba Member
Joined: January 18, 2006 Posts: 806 Location: Pitt Meadows BC
Posted: Wed Mar 25, 2009 2:53 pm Post subject: Re: slider door lock seal |
TopBud wrote: |
I have been looking for a long time for a seal that goes around the door lock on the slider. The handle and the lock (where you put the Key) are separate and I am missing the seal. Does anyone know of a supplier. It is a 74. thanks in advance |
[url=ProductDetails]I got mine from CIP[/url]. Doesn't look so nice in the pix, but looks really sharp on the bus
I also ordered one for the handle itself, and for that, well, I haven't really tried it on, cos eyeballing it and it doesn't look like it'll fit.
The one for the lock came in a West Coast Metric packaging if that means anything. _________________ ---------
Rubber Duck
1974 Westfalia |
AndyM Samba Member
Posted: Wed Mar 25, 2009 5:29 pm Post subject: |
Those seals usually fall down inside the slider door. Open it up and you will probably find it down in the muck. Otherwise, a simple repair that seems to work rather well is to use a black garden hose washer. They fit in there nicely and it's hard to tell the difference. |
TopBud Samba Member
Posted: Wed Mar 25, 2009 7:10 pm Post subject: |
Thanks. I I thought I searched all the vendors listed in the above posts, but I guess I didn't look hard enough. Thanks again _________________ 86 bostig SYNCRO
SGKent Samba Member
Posted: Wed Mar 25, 2009 7:11 pm Post subject: |
the OG one seals to the door and lock to keep water out. There is also a seal on the outer handle and a hard foam piece in their too that is near impossible to find. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
TopBud Samba Member
Posted: Wed Mar 25, 2009 7:41 pm Post subject: |
I could have sworn the OG one inserted into the door and also around the lock. Kind of like a mushroom, but I might not remember correctly. _________________ 86 bostig SYNCRO
norcalmike Samba Member
Joined: May 14, 2005 Posts: 4784 Location: Marina, CA
Posted: Wed Mar 25, 2009 7:43 pm Post subject: |
yes, topbud, you are correct.
i was lucky enough to have a nice one on my parts bus.
i love having a parts bus |
71_georgia_beetle Samba Member
Joined: March 24, 2008 Posts: 360 Location: Grayson, GA
Posted: Wed Mar 25, 2009 10:51 pm Post subject: |
TopBud wrote: |
I could have sworn the OG one inserted into the door and also around the lock. Kind of like a mushroom, but I might not remember correctly. |
#42
_________________ 71 Standard Beetle "Big Bird"
74 Westfalia "Winifrid"
Call me if I need you!
www.burelphotography.com |
ChuxBus Samba Member
Joined: March 19, 2005 Posts: 297 Location: East Atlanta, GA
TopBud Samba Member
Posted: Thu Mar 26, 2009 6:19 am Post subject: |
I do believe it is the one from west coast metric. thanks again _________________ 86 bostig SYNCRO
Posted: Thu Mar 26, 2009 7:00 am Post subject: |
That's the one I got...looks good. Hmmm my earlier link did not work. Try this one.
I'm not sure how one of the posters said that the seal can fall inside the door. This seal literally presses in from the outside. I was always bothered by the big gap between the lock tumbler and the door skin. With this seal, it just looks so much nicer now. Get it man, its cheap and it works.
I also like the other's guys idea to use the garden hose washer. FWIW, I used that to seal between the door mirror and the body after the CIP seal failed to work. That one is a waste of money. _________________ ---------
Rubber Duck
1974 Westfalia |
White99z Samba Member
Joined: August 17, 2008 Posts: 735 Location: Bus hunting in the USA!!!
Posted: Thu Mar 26, 2009 12:46 pm Post subject: |
They have these for $2.50 at busdepot. Is it the same one? |
