randywebb Samba Member
Posted: Sat Jun 12, 2010 12:33 pm Post subject: |
any idea how many hours you've put in on this project so far? _________________ 1986 2.1L Westy 2wd Auto Trans. |
ddonnell Samba Member
Joined: September 04, 2007 Posts: 373 Location: Sunset Beach
Posted: Sat Jun 12, 2010 12:43 pm Post subject: |
RicoS wrote: |
Once, when I had a joint....
Say no more
Just kidding I knew what you meant.
bmwmango:
NICE conversion!! wish I had the time/knowledge to take that on! _________________ 1990 Vanagon Carat-SOLD
1995 Dodge Ram 2500 4x4 V10
1966 Baja "The Beast"
instagram #bajabugproject |
SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 2458 Location: Highnam, UK
Posted: Sun Jun 13, 2010 6:14 am Post subject: |
Looks good.
I have used the 2wd shifter rod at the back just altered the angles so that the cup sat in the right place for the ball on the trans.
When fitting the gearbox, I've done it in 2 different ways. Drill holes for the mounts into the cross member and then either send bolts through from above so they point down, tack weld them inside the cross member (not fun!) and then use nuts or.. tack weld nuts inside the cross member as per factory (even less fun!).
Oh, the syncro has the bottom corners of the battery boxes altered to allow more clearance for the tyres.
Good to see someone over there converting 2WD to Syncro too
MG _________________ T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD |
at3619 Samba Member
Joined: December 27, 2009 Posts: 1 Location: Denver, Co.
Posted: Mon Jun 21, 2010 9:57 am Post subject: |
b
SyncroGhia wrote: |
MG |
There may be a few of us over here doing this in our garage
Uploaded with ImageShack.us
Note everything that could be uninstalled from the van was sand blasted and powder coated (i would recommend this vs the wire wheel. a lot of time is saved and its relatively inexpensive. a local place did all of it for $150. And they gave me a matching black in a rattle can for all the stuff i couldn't take off)
Ghia, you have me concerned about the battery box issue. Just looked at my van and the donor syncro and i can see what you are talking about. cant see it until you remove the 2wd evap crap, but the syncro battery box has the outermost corner flattened. will i need to modify the battery boxes? I plan on running oversized tires.. does this mean i have to fit smaller batteries?
Well, since iv now gone public.. lol
Just a few things to ponder on for those underway or considering this swap. at least things I have run into..
-It SUCKS. Im a former mechanic(gone service writer) and iv done more than a few swaps in my day. my latest was an 88 celica alltrac that i swapped a 94 jdm(st205) drivetrain into. This syncro project makes that look like an oil service
-Bmwmango's method of power steering crossmember transfer is very insightful. spent a few days scratching my head on this one until i found this thread. I made a mistake of leaving extra steel spotwelded to the crossmember for strength since i would be bolting this side to the outer ears of the 2wd rack i left in. I now have a Clearance issue with the ps gear and sway bar.. I either need to move the sway bar forward 1/4in or notch the ps pinion housing. not sure if he is having any clearance issues, but this method required the ps crossmember to be moved forward a little anyway. Im also worried the syncro steering shaft may be too long but i haven't installed it yet.
-There is a crossmember spot welded under the rear seat where the lower gas tank straps bolt to and the tank is pressed against once the straps are tightened. Very easy to weld in. NOT easy to remove from the syncro OR easy to remove all the excess metal so it can be welded in. Do yourself a favor and build your own. I wasted an entire day on this part. I already had the thing cut out before i realized this was a waste of time or else id have given up.
-I am also doing an svx conversion on the van at the same time as the syncro swap. stay away from the smallcar conversion kit. This is the one I bought and am less than impressed by the quality and engineering of the kit. Also the things they didn't include with the kit. Like one of the motor mounts.. power steering hose.. oil pan.. VERY unimpressed by the bell-housing kit. There are large bubbles in the aluminum casting, and the kit utilizes a vw internal type slave cyl/throwout bearing assym which requires removal of the transaxle when(not if) the slave fails. Also I would rate their customer service Generally poor. Do yourself a favor, spend the money.. Call Mike at Rocky mountain westy. On My next swap I'll use his kit. Iv seen the difference in quality first hand
Thank you bmwmango for creating this thread!! Its a help to all of us. Its nice to be able to get ideas from others undertaking this task
kpbo, same to you. I will follow your method of fuel filler transfer. I needed an idea on how to get away with not painting the van, and I didnt want a primer spot. Thank you
Thank you Mark at wolfsburg auto Boulder, Co., Mike at RM Westy, Tynans VW parts department Aurora, Co. and Pete and Chris at vancafe.com! |
Posted: Mon Jun 21, 2010 3:02 pm Post subject: |
Re battery boxes,
It really depends on how extreme you're going to go. I think you'll prob run into clearance issues with the back of the front arches before you start rubbing the corners but it also depends on what wheel offset you're running... obviously the further in the tyre sits, the more chance of them catching.
I'm running a huge battery in Limey which barely leaves enough room for the battery cables... there must be a couple of mm each side of the battery and no more. It still sits happily and fastens down in place with the lid closing over the top.
Re tank straps, on the 2 vans I've converted, I just drilled through just above the cross member into the van inself, used large washers and nuts which you access in the van.
I didn't have any clearance issues with the steering gear and I fitted it in a similar way to yours except I welded mine in.
Re bellhousings... RJES is a good friend of mine and I can't recommend his kit enough. He's an engineer by trade and designs everything himself. If you want the best, his website is worth a visit. He's also very happy to talk things through with any customer.
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
Central Syncronizer Samba Member
Joined: November 19, 2008 Posts: 302 Location: Vancouver
Posted: Wed Aug 11, 2010 10:01 pm Post subject: |
Any progress on this?
cheers _________________ Ongoing restoration/maintenance of my syncro double cab (and soon Westy):
http://88syncrodoka.blogspot.com/ |
Fritz Samba Member
Joined: July 24, 2009 Posts: 68 Location: The Big Mitten
Posted: Fri Nov 05, 2010 6:55 pm Post subject: |
Any progress on this? |
Jteerlink Samba Member
Posted: Fri Jul 15, 2011 1:30 pm Post subject: |
Finished? Sold? Gave up? |
outwesty Samba Member
Joined: June 06, 2006 Posts: 1074 Location: Tahoe City
Posted: Mon Oct 17, 2011 6:22 pm Post subject: |
Did this ever see the road again ? This was my favorite thread of all time. |
mathieux46 Samba Member
Posted: Mon Oct 17, 2011 6:32 pm Post subject: |
Yes the coolest thread ever!!
I'm converting my 2wd to syncro in November. I'm planning a full week but the syncro donor is already dismantled.... all the parts sitting the garage.
I will take pictures! |
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Mon Oct 17, 2011 7:30 pm Post subject: |
sweet, makes me kinda wish I snagged a rusted out syncro cheap. |
notfadeaway_72 Samba Member
Joined: August 24, 2011 Posts: 4 Location: Washington
Posted: Mon Jan 02, 2012 7:25 pm Post subject: conversion |
Great thread..I completed my conversion several months ago and could'nt have done it without this type of info loven my westy more than ever.. |
carterzest Samba Member
Joined: January 22, 2008 Posts: 3842 Location: Eagle, ID/Sun Valley, ID
Posted: Mon Jan 02, 2012 7:59 pm Post subject: |
mathieux46 wrote: |
One of my favorite threads as well, along with pastis and the subie 5 speed thread, and, this thread has inspired many people to do the same thing. Frankensubysyncro did the same thing, and, I have yet to ride in a more capable Syncro Of course, he has gone better, stronger and faster cuz thats just how he rolls
I have been trying to encourage him to do a build thread as well. I guess he is just too busy in the Yahoo Syncro group
Hope all is well for you bmwmango. _________________ Happiness=Portland, Oregon in the rearview mirror! |
bmwmango Samba Member
Posted: Mon May 07, 2012 12:42 pm Post subject: |
Happy Syncro de Mayo
Here is the remainder of the front suspension install.
Here we are installing the springs.
The springs were compressed using two threaded compressors.
It might take more than one try to find the right spot on the spring to place the compressor.
Old Man Emu shocks and Syncro.org springs.
Please note: The floor jack is simply lifting the lower control arm. The van is sitting on jack stands.
The power steering rack bolts right up to the mount I removed from the Syncro
Front brakes. I also decided to keep the original 2wd fuel fill. The black cover and cap looked better an empty hole. I taped up the end. Maybe use it for an aux fuel tank sometime in the future.
I went with the big brake kit from Van Café
Next you need to install the steering shaft. Please take note that these shafts are different lengths with the 2wd shaft being the longer of the two.
I ran the power steering rack through its full range of motion and counted the number of revolutions the splined shaft made. I believe there were 54 splines on this shaft, but don’t quote me on that. I took the total number of revolutions times 54 and then divided it by 2. This is where I set my steering wheel to straight ahead.
Then I installed the sway bar, but had to grind away some of the welds from the suspension plates we installed earlier to install the mount. This picture also shows the speedometer cable bracket. The Syncro has a two piece cable with an intermediate mileage box.
And another one
The rear heater core lines run differently in the Syncro than the 2wd. To seal the original holes, I used 1” Hoffman plugs used by electricians to seal boxes. I think the hole for the brain wires took a 3” or 4” plug.
This new routing requires some modifications to the heater box.
_________________ 1990 Westy converted to a Syncro Westy
2009 BMW R1200GS
1990 BMW K75
1986 BMW K75 Parts (Deer 1, Beemer 0) |
MayorMcCheese Samba Member
Joined: October 07, 2009 Posts: 658 Location: Lancaster PA
Posted: Mon May 07, 2012 2:56 pm Post subject: |
Bonus points for dealing with a gravel driveway. |
GoWestyYoungMan Samba Member
Posted: Mon May 07, 2012 6:23 pm Post subject: |
Thank you so much for documenting this project so thoroughly!!
I am starting to collect parts, strip the interior for Syncro conversion and new paint job on my '86 West.
Glad you are progressing and posting, a lot of us subscribed to this thread! |
Posted: Mon May 07, 2012 8:08 pm Post subject: |
MayorMcCheese wrote: |
x2 hardcore ! |
airsweden Samba Member
Posted: Sat May 12, 2012 4:14 pm Post subject: |
Does any body have insight regarding the difference between a manual and a power steering rack in the conversion? I have not yet had an opportunity to compare rack dimensions and how they attach. If I am lucky enough to round up a donor, I would like to tackle this but would also like to keep my manual rack. _________________ 1982 1.6 NA Diesel Westy
1982 AHU MTDi CHC
1984 1.9 WBX Westy
1985 1.9 WBX Westy
1986 2.1 WBX Syncro Westy |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6347 Location: Honolulu,Hawaii and France
