BGLOCOTE Samba Member
Posted: Wed May 25, 2011 8:06 pm Post subject: |
I spoke with the local bug shop and with the cost of the spindals and the labor to reinstall my bushings and link pins it was about the same price as having adjusters installed on my stock beam so which way should I go? _________________ 1955 TYPE 1 RAG Under Construction
1962 TYPE 1 SOLD
UNITED STATES SUBMARINE VETERAN |
Posted: Thu May 26, 2011 7:14 pm Post subject: |
Anyone have any ideas? _________________ 1955 TYPE 1 RAG Under Construction
1962 TYPE 1 SOLD
tb03830 Samba Member
Joined: December 02, 2009 Posts: 1045 Location: Leavenworth, KS
Posted: Fri May 27, 2011 8:18 am Post subject: |
My suggestion is to go with spindles. They reproduce the stock ride with shocks and are a little heavier duty than the origionals. Mine work great.
I also have adjusters but do not use them for now. All kinds of other things to consider with adjusters like new shocks, Wedges, bumpier ride and you always find things wrong. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
1964 Convertible Bug - 1600cc SP engine with a stock H30/31 Carb and SVDA Distributor - Swing Arm Highway Flyer Tranny, Gene Berg's Temperature Dipstick, 2.5" drop spindles, 2" narrowed adjustable front end. Chromed OEM fan tower. |
Posted: Fri May 27, 2011 9:50 am Post subject: |
tb03830 wrote: |
I also have adjusters but do not use them for now. All kinds of other things to consider with adjusters like new shocks, Wedges, bumpier ride and you always find things wrong. |
Thanks for the advice. I will probably go that route. I just thought it would be cool to be able to adjust the ride height. _________________ 1955 TYPE 1 RAG Under Construction
1962 TYPE 1 SOLD
s1b Samba Member
Posted: Fri May 27, 2011 11:21 am Post subject: |
Will the tires rub with a stock width beam and drop spindles? |
Joey Samba Member
Joined: August 12, 2005 Posts: 5261 Location: Nova Scotia - Canada
Posted: Fri May 27, 2011 2:07 pm Post subject: |
s1b wrote: |
Stock size tires (165R15) on stock rims will rub when cornering with dropped spindles. Even with 145R15 tires you'll still get a bit of rubbing... at least I did on my '65. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '56 Beetle - '65 Beetle |
Tin Badge Samba Member
Joined: June 07, 2011 Posts: 76 Location: Clarksburg WV
Posted: Mon Sep 12, 2011 5:27 pm Post subject: |
Thanks for the post this helped a lot in doing mine. Also I was not as brave and bought mine off widefive.net already done they were just plug and play but the other info you posted as far as removal and such helped greatly. Thanks again.
mykidsbug Samba Member
Joined: April 07, 2011 Posts: 447 Location: SoSo Cal LA
Posted: Tue Sep 13, 2011 3:58 pm Post subject: |
I wonder if you can get a front Beam with the adjuster and lower a bug 2.5.. also if you can use regular tires. my 135's are hard to get.. |
jims65 Samba Member
Joined: October 06, 2010 Posts: 14 Location: Pasadena
Posted: Tue Mar 06, 2012 4:48 pm Post subject: |
Hey guys sorry for bringing up an old thread but I was wondering if running dropped spindles on a stock width beam would rub. When i bought the car it had some torsion bars pulled so its not stock height. I have empi 5 spokes and 135's in the front . |
Posted: Mon Mar 12, 2012 11:56 pm Post subject: |
jims65 wrote: |
They might with some of the torsion bars pulled. You would just have to try it and find out in my opinion. And if it dose then start adding the bars till you get what your striving for. Mine is a stock frontend and just drop spindles and I am running 145's and have not had any rubbing issues even with a front passenger. Both of us 220 each. Good Luck! |
gitchesum Samba Member
Joined: November 10, 2003 Posts: 478 Location: North Cali
Posted: Mon Jul 30, 2012 8:22 am Post subject: |
Jean Michel wrote: |
I just want to say that for those wanting to do this modification to their bug and want to fit the Porsche 356 brakes, that it can be done with the early 356 A Brakes only (small modification to the spindle or backing plate required) Dropped Spindles will not work with 356 B brakes as the backing plates for these are very diffrent to the 356 A brakes, which are diffrent again to the early 356 A Brakes! The B brakes are 1 cm larger in diameter to the A brakes and drums and backing plates can not be interchanged! |
Not sure about that at all....I took my CB spindles to my extra set of 356B brakes, the front fits fine on the backing plate...I do have to figure out the bearing issue however. The Porsche bearing has a bigger ID than the VW bearing. Hoping I can put VW bearings in the Porsche drum.
My bug now has 356B brakes on it already, just don't remember what I did about the bearings..plus I'm putting a 4 in/2 1/2 spindles/BRM's on it this time around. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
73 The Thing w/2276, and more.
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go... |
topgun13b Samba Member
Posted: Sat Oct 06, 2012 8:11 pm Post subject: 1960 vw beetle Spindl |
I need your advice I got my 1960 bug, and its already lowered and the beam shorted. I would like to rise it up a little bit from the front because its very low and diffecult to put it on the trailer. Could I loose the spindl and take off the two arms that connected to the spindel and the the beem, then move the two arms one step down, and then connect the spindel again? is that going to risa the car a little bit? and is it going to work? |
Vintagespeed Samba Member
Joined: October 01, 2005 Posts: 574 Location: Westerlo (Belgium)
Posted: Fri Jan 18, 2013 5:04 pm Post subject: Re: UPDATE |
Focker wrote: |
bugdozer wrote: |
...Do you have any rubbing after installing the spindles? |
Yesterday I decided to lower the rear one notch (outer spline) just to level the bug. It's a simple task unless your E-Brake cable is short like mine...PITA. Some guys I know had longer cables which allowed them to swing the rear drum back and out of the way.
I think I accomplished the goal of leveling but what I didn't expect is that the rubbing up front was cut down to less than half (In my experience). I zipped around some of the same corners that I had rubbing issues and it was a lot less noticeable. If I end up running 145's up front (165's currently) it should be even less. My concern is that the "Rake" from the smaller tire diameter will cause the tires to rub again since they will be up inside the fender more.
I'm sure there is some kind of Physics involved that explains the whole thing...Obviously I'm no Biologist.
Here is a new comparison shot...Starting with the lowered front.
Here is after the rear was completed...Yes I drove around and let everything settle.
did you get those 145s on? A little rake was great, and should be back with smaler front tires. |
netsniper Samba Member
Miklo ¡Chale!
Joined: August 27, 2008 Posts: 2048 Location: Antelope Valley, Ca
Posted: Sat Apr 20, 2013 2:31 pm Post subject: |
You'll need a pair of ball joint spindles netsniper. _________________ ✠WagenKült✠
'55 Type1 "Ozma"
'70 Type2 "Hannah"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote: |
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche... |
Posted: Sat Apr 20, 2013 3:18 pm Post subject: |
Thank you |
Posted: Fri May 03, 2013 3:59 am Post subject: |
What tools do I need to fit spindles on my bug |
slaphappytrav Samba Member
Posted: Fri Apr 04, 2014 8:17 pm Post subject: |
11 month old thread, but I started this project tonight! |
Posted: Sat Apr 05, 2014 1:15 am Post subject: |
I've done mine now and it was very easy. |
