My Express engine
vicpolky
vicpolky is offline
PostPosted: Sun Apr 12, 2009 10:58 am    Post subject: Reply with quote
Fantastic motor, great work.
It sounds great in the film too Cool Cool
1385cc 40HP Vintage Speed Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=325587&postdays=0&postorder=asc&start=0
http://www.oldspeed-mouse-motor.blogspot.com/
http://www.superninety.blogspot.com/
oval53/split52
oval53/split52 is offline
PostPosted: Mon Apr 13, 2009 5:23 am    Post subject: Reply with quote
I had to make some of these for my kit. Quite easy, but be carefull and take your time when drilling backelite. If its turning too fast, the bakelite will soon start burning.
Repro:
OG:
Peter_Plade
Peter_Plade is offline
PostPosted: Mon Apr 13, 2009 11:52 am    Post subject: Reply with quote
Looks like that is just what I need!
You don´t have a extra set lying? Very Happy
Original 1954 3 fold oval
http://vw-bluehats.blogspot.com/
oval53/split52
PostPosted: Mon Apr 13, 2009 12:19 pm    Post subject: Reply with quote
Hmm. No. I bought those from a guy here in Norway. I bellieve it was this guy: http://www.velosiped.no
They needed a bit work before they can be fitted, but its absolutely worth it Smile
Ninamashr
Location: City of Round Rock in the Great State of Texas
Ninamashr is offline
PostPosted: Tue Apr 14, 2009 10:17 am    Post subject: Reply with quote
Congrats Peter, That engine sounds and looks awesome (even though it's missing a carb Wink )
1957 Karmann Kabriolet "Franky"
1957 Allstate trailer
'64cal lookdub
1200 Deluxe
'64cal lookdub is offline
PostPosted: Tue Apr 14, 2009 4:06 pm    Post subject: Reply with quote
Beautiful engine!
Peter_Plade
PostPosted: Sun Apr 19, 2009 8:15 am    Post subject: Reply with quote
Here is a fresh picture of the motor, and I think I have solved the starting problems, I´ve changed the needlevalves to some nos ones, it seems that it has helped. But I´m still considering making some plates to isolate from manifold to carb.
marcnr1
marcnr1 is offline
PostPosted: Sun May 10, 2009 11:42 pm    Post subject: Reply with quote
great engine in a great car, I looked at your car at the mai kafer treffen in hannover! I am trying to build a engine like that myself. I am in doubt if I build the inlet manifolds myself or buy them at riechert in germany.
Mark
Peter_Plade
PostPosted: Mon May 11, 2009 6:38 am    Post subject: Reply with quote
Hi thank you for the nice words!
I would go for the riechert option, seems like they work very well!
Peter_Plade
PostPosted: Sun Feb 07, 2010 8:48 am    Post subject: Reply with quote
New features for the motor this winther, is the heads have been redone with new seats/guides and new valves.
The inlet valves is Okrasa valves, so they are 33mm instead of stock 30mm.
Next step is bigger venturis.
oval56
oval56 is offline
PostPosted: Tue Feb 09, 2010 7:05 am    Post subject: Reply with quote
Wink Laughing Very Happy
good job
is you flywheel lightened / machined balanced?
www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com
77ducci
Samba Beer Head
77ducci is offline
PostPosted: Tue Feb 09, 2010 9:07 am    Post subject: Reply with quote
Mark
Made mine myself. My first set was not so good, but my second set came out very nice:
If you would like any details you can PM me.
marcnr1
marcnr1 is offline
PostPosted: Tue Feb 09, 2010 9:21 am    Post subject: Reply with quote
77ducci wrote:
Mark
I've already bought a set and almost ready 'building' the engine. Parts are powdercoated en painted as we speak.
Peter_Plade
PostPosted: Wed Feb 10, 2010 12:09 am    Post subject: Reply with quote
good job
Yes ofcourse, both lightned and balanced with the flywheel the clutch pressur eplate and the pulley.
And all the rods and pistons is weighed of to the same weight.
Peter_Plade
PostPosted: Fri Apr 16, 2010 12:47 pm    Post subject: Reply with quote
Finally it was time to get the Express motor on the dyno again.
It runs really good now, but the bigger venturies were too much for it, so we went back to the stock ones.
But it seems the new heads are working really well.
oval56
oval56 is offline
PostPosted: Fri Apr 16, 2010 2:25 pm    Post subject: Reply with quote
thumbs up peter, but i think i have mentioned it, the problem is the cam, heads are fine, valves and rest also but now the original cam is on the end of the possibilities... so next step is an custom grind cam, to get more rpm's and than use the bigger venturis.... Wink but good to hear that the heads are working fine... Wink
www.oval56.com
www.dbkvw.com
Peter_Plade
PostPosted: Fri Apr 16, 2010 10:41 pm    Post subject: Reply with quote
Hi Andi I allready have a mr okrasa cam in it.
But I´m real satisfied with how it runs now, it has maximum torque around 3000rpm that is perfect because that is were it goes 100km/h.
oval56
oval56 is offline
PostPosted: Sat Apr 17, 2010 3:24 am    Post subject: Reply with quote
mhhh but than the bigger venturis should work better... that was my experience...
www.oval56.com
www.dbkvw.com
Peter_Plade
PostPosted: Sat Apr 17, 2010 4:08 am    Post subject: Reply with quote
The first run on the dyno was 44hp, after cahnging the venturies it was 46hp. And then we gawe it a litttle more timing.
But I´m happy Smile never thought I would get over 50hp with it.
marcnr1
marcnr1 is offline
PostPosted: Sat Apr 17, 2010 4:42 am    Post subject: Reply with quote
At what rpm did you het that horsepower?
Page 2 of 4
