My Express engine
marcnr1
marcnr1 is offline
PostPosted: Sat Apr 17, 2010 4:47 am    Post subject: Reply with quote
marcnr1 wrote:
Peter_Plade wrote:
The first run on the dyno was 44hp, after cahnging the venturies it was 46hp. And then we gawe it a litttle more timing.
But Im happy Smile never thought I would get over 50hp with it.
At what rpm did you het that horsepower?
=51hp@4100rpm
Sorry, I had to watch the movie before I did that last post!
Peter_Plade
Peter_Plade is offline
PostPosted: Tue Oct 30, 2012 1:30 am    Post subject: Reply with quote
Well this was what happend this summer, after almost 30.000km with the Express motor the crank gave up.
The most crazy thing was that I actually was able to limp it the last 15km home with the broken crank.
The motor is now torn down and new plans have been made.
This time Im putting in a 72mm stroker crank, this should make it a 1341cc, kind of exited to see how this will work out.
Original 1954 3 fold oval
http://vw-bluehats.blogspot.com/
John Moxon Premium Member
John Moxon is offline
PostPosted: Tue Oct 30, 2012 1:59 am    Post subject: Reply with quote
How many is that now Peter?...I seem to remember you broke another one before. Wink
John.
Judson Information on The Samba
Superior "Supercharged by Judson" badges
Flying Scotsman & '58 Karmann Ghia Wall Poster
Peter_Plade
PostPosted: Tue Oct 30, 2012 2:19 am    Post subject: Reply with quote
You have a good memory John Very Happy
Its true I also broke one back when I was running my Judson.
Apparently I rev my motors to high, I just cant control myself Rolling Eyes
J
J is offline
PostPosted: Sat Nov 03, 2012 2:48 am    Post subject: Reply with quote
Join the club-)
mine broke after 12000km.
http://www.oldtimeroldspeedclub.org/
http://www.petermaxrennen.org/
grueni
grueni is offline
PostPosted: Sat Nov 03, 2012 2:59 am    Post subject: Reply with quote
they allways brake at the same point Wink
damn.
1956 oval 1192cc 36hp Supercharged 70HP at 3900RPM / 150NM at 2000RPM @ 13 psi
1960 1641cc Twin scroll turbocharged, intercooled @17 psi 318nm/3430rpm 160hp/4790rpm
with cb2280 cheater cam 222@ 0.05"
Peter_Plade
PostPosted: Wed Nov 07, 2012 12:09 am    Post subject: Reply with quote
They can also brake in the other end Shocked
This is the one that broke when I was running my Judson motor.
grueni
grueni is offline
PostPosted: Wed Nov 07, 2012 2:55 am    Post subject: Reply with quote
autsch...than i had luck with my supercharged engine.
but on the medusa engine i let the crank checked alot. maybe because they are so old? so allways better to use a porsche 356 one Wink
mightymouse
mightymouse is offline
PostPosted: Thu Nov 08, 2012 3:26 pm    Post subject: Reply with quote
Thats due to no counterweights and no weight on the nose of the crank.
They flex in the middle and thusly break in that same spot at either end. More likely to be the flywheel end because of the flywheel weighing more and contributing more to the flex.
Add counterweights and heavier pulley or harmonic damper.
Problems will cease.
Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters.
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Thu Nov 08, 2012 3:52 pm    Post subject: Reply with quote
Shocked
My dog's vet has all my car money (http://sagecenters.com/)
Mr. Motorhead
Mad Scientist
Mr. Motorhead is offline
PostPosted: Thu Nov 08, 2012 5:14 pm    Post subject: Reply with quote
72mm is a very popular stroke, out of the three I had made up from Porsche cranks I only have one left.
30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy
HerrLowlight Premium Member
HerrLowlight is offline
PostPosted: Mon Dec 10, 2012 3:02 pm    Post subject: Reply with quote
Hi Peter,
You've run both a Judson and an Express engine on the same car. Can you pick which of the two gave you better low and top end performance? Which did you enjoy more? Which (if either) was a pain to set-up and maintain?
Thanks
Trevor
1967 SO42
1959 Karmann Ghia
1959 Karmann Ghia Convertible
Peter_Plade
PostPosted: Tue Dec 11, 2012 6:16 am    Post subject: Reply with quote
Hi Trevor
I like the Express motor the most. Not near the same problems as I had with the Judson.
And I can push it much more without it getting to hot.
Only thing that I miss is the torque at low rpms that the Judson had.
Peter_Plade
PostPosted: Sun Feb 17, 2013 3:41 pm    Post subject: Reply with quote
Finnally I made some progress on the motor.
The short block is now assembled, and now some machine work is needed before I can get any further.
Peter_Plade
PostPosted: Sun Feb 23, 2014 10:22 am    Post subject: Reply with quote
I had 8500 trouble free kilometers with the new set up last summer.
The extra ccm made some nice low end torque,and the hp raised to 55 on the dyno.
This winter I made a new "Abarth" for it and now it's ready for some more driving Very Happy
turbolaz
turbolaz is offline
PostPosted: Fri Mar 07, 2014 6:23 pm    Post subject: engine Reply with quote
Nice engine peter, im looking to build something like this what size crank did you use? what kind of carb kit is that?
shipping extra,paypal ok at 4% added to parts.
parts are sold as is.
Peter_Plade
PostPosted: Sat Mar 08, 2014 12:10 pm    Post subject: Reply with quote
I use a 72mm DPR crank, it's really good!
The kit is Autotechnik Express made in Hannover.
malsteph
malsteph is offline
PostPosted: Thu Apr 03, 2014 7:19 am    Post subject: Reply with quote
You could use an early Porsche cam. (103 if my memory is correct)
Period correct and very compatible with the rest of the engine.
Id would probably move the power band a little higher in the revs. But if you are still getting good torque value around 3000 RPM, it is worth a try.
tobiasax
tobiasax is offline
PostPosted: Thu Apr 03, 2014 11:10 am    Post subject: Reply with quote
Hello malsteph: Have you good info on early Porsche cams? I have bee trying to find out what different cams the pre-A had, but haven't really succeeded.
Peter_Plade
PostPosted: Fri Apr 04, 2014 12:39 pm    Post subject: Reply with quote
I use a mr okrasa cam and have no plans changing it, since it runs so good as it does. Might look for other cams if I some day need to take it apart again.
Page 3 of 4
