My Express engine
Page: Previous  1, 2, 3, 4
Peter_Plade
Peter_Plade is offline
PostPosted: Sat Jul 11, 2015 11:10 pm    Post subject: Reply with quote
Again this year I made some updates.
I changed the carbs to 32pci and modified the original 54-55 strap over filters so they aren't as restrictive.
It now makes 61hp and I'm quite happy Laughing
Original 1954 3 fold oval
http://vw-bluehats.blogspot.com/
PostPosted: Sat Jul 11, 2015 11:38 pm    Post subject: Reply with quote
What did you change in the air cleaners?
Peter_Plade
PostPosted: Sat Jul 11, 2015 11:50 pm    Post subject: Reply with quote
If you take a look at the bottom of the filter you can the flange that goes over the carb is of center, that of course to move the filter back towards the fan shroud on the stock motor otherwise it would hit the decklid.
But not having that problem I moved the carb flange so it is centered with the inside pipe, and almost works as a stack now. I can take some pics if that explains it better?
Can't tell if it's the filter or carbs, but I have less carb "noise" now than I used too.
Btw it wasn't the best day cutting up 2 original filters Confused But the end result was good!
PostPosted: Sun Jul 12, 2015 9:04 am    Post subject: Reply with quote
I understand your text - you put the bottom carburetor connection in the center instead of it being offset. Cool.
Yes, I would be hesitant to cut 2 original strap air cleaners too. Smile
Peter_Plade
PostPosted: Sun Jul 12, 2015 10:52 am    Post subject: Reply with quote
But now there are 2 original filters less out there, making the remaining ones more rare Wink
Scotty
Scotty is offline
PostPosted: Fri Jul 24, 2015 6:29 am    Post subject: Reply with quote
Such a beautiful engine!
MDKG
MDKG is offline
PostPosted: Sat Aug 29, 2015 11:36 am    Post subject: Reply with quote
Very nice engine Peter! Any video of you latest set up running? Love the fact that you really drive your car. Do you run the standard brakes? If so how do they perform with this engine?
Peter_Plade
PostPosted: Wed Sep 09, 2015 4:56 am    Post subject: Reply with quote
Hi and thanks for the nice words, the only video i have is from when i was running it in and adjusting the mixture before I had it on the dyno (might have a dyno video also)
As for brakes, I have been running 356A brakes in the front the last 3 years and planning on mounting the rears too, even the front ones does an exelent job.
grailoc
grailoc is offline
PostPosted: Sun Jan 15, 2017 4:56 pm    Post subject: Re: My Express engine Reply with quote
Hello Peter, you have a very nice build !!
I am currently building an autechnik engine, here is my thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=670827
I need your help to show me more details about your linkage setup between carb and the main axle shaft. see green circle below:
I have been told I needed the rotule setup but I do not have any of the part yet. Do you know where I can get them ?
thanks for help.
Jerome
My 59 low light ghia: http://www.thesamba.com/vw/forum/viewtopic.php?p=7852268
My 56 beetle convertible: http://www.thesamba.com/vw/forum/viewtopic.php?p=7796259
My 60 SO23 westy: http://www.thesamba.com/vw/forum/viewtopic.php?t=341539
Check my blog: http://us-road-trip-vw-bus.skynetblogs.be/
and my garage build thread: http://www.garagejournal.com/forum/showthread.php?t=199438
My other vehicles
KG 64
vespa 1961 Acma & spanish GT 160
2 Lambretta LI 150
2 1971 Honda CT70
Peter_Plade
PostPosted: Mon Jan 16, 2017 12:37 pm    Post subject: Re: My Express engine Reply with quote
Hi Jerome very nice set you have there.
My arms for the linkage aren't original, I made my own with baljoints at both ends of a adjustable arm.
grailoc
grailoc is offline
PostPosted: Sun Feb 26, 2017 5:48 am    Post subject: Re: My Express engine Reply with quote
Hello Peter,
Do you know what are the jet setup of the 28 PCI carbs for the 36hp engine with an express kit?
I got new jets yesterday and wanted to know if what I got correspond to the right setup.
Here is what I need:
Main Jet size:
Air correction Jet size:
Float size
Venturi size
Emultion tube size
thanks in advance for help.
Jerome
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
grailoc
grailoc is offline
PostPosted: Tue Mar 07, 2017 6:28 pm    Post subject: Reply with quote
Peter_Plade wrote:
Hi Peter,
I just got a 356 oil filler, the same as yours,
and I would like to know how you were able to fit it on the engine case ?
Do you have a closer picture I can look at ?
thanks for help.
/Jerome
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
Peter_Plade
PostPosted: Wed Mar 08, 2017 2:35 am    Post subject: Reply with quote
grailoc wrote:
Peter_Plade wrote:
Hi Peter,
thanks for help.
/Jerome
Hi Jerome
Ive answered your pm about the oil filler.
About what jets to use, i cant remember which ones I started out with, Ive done alot of upgrades to my motor over the years and now Im running 32 Solexs.
But one thing I always has is having the final adjustment done on a dyno.
grailoc
grailoc is offline
PostPosted: Wed Mar 08, 2017 6:20 am    Post subject: Reply with quote
Thanks just saw your email, as for the jet I found what I needed .
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
JeeWee
JeeWee is offline
PostPosted: Mon Mar 13, 2017 8:15 am    Post subject: Re: My Express engine Reply with quote
are you still running the original heater boxes?
grailoc
grailoc is offline
PostPosted: Mon Mar 13, 2017 9:50 am    Post subject: Re: My Express engine Reply with quote
I would guess so with that setup ?
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
Peter_Plade
PostPosted: Tue Mar 14, 2017 1:55 am    Post subject: Re: My Express engine Reply with quote
Yes I am.
Page 4 of 4
