420GOAT Samba Member
Joined: March 31, 2006 Posts: 3343 Location: Wilmington, CA on a nice quiet street but still in the 'hood
Posted: Sat Apr 04, 2009 11:09 pm Post subject: Any interest in Tarboards for a 68-71 engine comparetment? |
im not exactly sure what other years use tarboard up in the engine compartment, i know it changed to a honeycomb type in later busses, but im thinking of making a few sets of compartment sound deadner for early bays. im going to use the type of tarboard that is used for bugs and ghias, a waffle like impregnated paper stock.... _________________ once you realize im not impressed we will get along just fine |
Blaubus Samba Member
Posted: Sun Apr 05, 2009 5:26 am Post subject: Re: Any interest in Tarboards for a 68-71 engine comparetmen |
71s do not use tarboards, thats a 68-69 and perhaps a 70 thing.
alikatcraig Samba Member
Joined: September 09, 2007 Posts: 556 Location: Anaheim, CA
Posted: Sun Apr 05, 2009 10:43 am Post subject: |
If you mean the 2 part black fiber board that holds up the 1" thick factory foam boards above the engine, then I am in the process of getting some made in either ply or black HDPE. I'll let you know how it turns out. The old ones were warped and brittle, and I wanted something that looks good and lasts. I did contemplate 1/8" aluminum sheet powder-coated semi-gloss or wrinkle black.
Al _________________ 1967 Ghia
1971 Deluxe Microbus
1974 Convertible Bug
1973 Standard Bug
1998 Mexican Bug |
enjoispammy8 Samba Member
Joined: December 26, 2007 Posts: 1984 Location: Long Beach, CA
Posted: Sun Apr 05, 2009 12:10 pm Post subject: |
depending on price, im down. mine were warped more than an american politician _________________ 1969 Westy, 1690cc. montana red and cloud white.
1969 Standard Beetle [sold]
Watch My Movies: https://www.youtube.com/user/taylorlikesacdc
Desertbusman wrote: |
Is there a message here? Enjoy Spammy Ate |
EZ Gruv wrote: |
Way to fuck up some little kids riding in the car next to you. |
hazetguy wrote: |
you need to be doing better drugs. |
vwpieces Samba Member
Joined: March 23, 2005 Posts: 345 Location: UpHill BothWays, PA
Posted: Sun Apr 05, 2009 3:33 pm Post subject: |
I have an Early 68 & there are no tar boards in the engine bay. My early 68 also does not have the metal covering the gastank.
I know my previous 70 had the boards but can not remember if my first 68 kombi had them. _________________ 68 BUS
83 JETTA TURBO DIESEL
83 2dr JETTA 16V
81 Turbo Diesel Jabbit |
RatCamper Samba Member
Joined: November 13, 2008 Posts: 3305 Location: Australia
Posted: Sun Apr 05, 2009 3:59 pm Post subject: |
We are talking about the stuff on the inside top of the engine bay, right?
Mine is masonite with furry insulation sandwiched under it held in place with clear plastic. There's still a VW part number on the insulation fuzz on the inspection hatch still so it's OEM. |
Posted: Sun Apr 05, 2009 4:19 pm Post subject: |
RatCamper wrote: |
what year bus? _________________ once you realize im not impressed we will get along just fine |
Posted: Sun Apr 05, 2009 4:23 pm Post subject: |
420GOAT wrote: |
RatCamper wrote: |
what year bus? |
1975. Sorry, I meant to put that in there but my morning coffee hadn't quite hit my brain. |
RobWeidman Samba Member
Joined: March 08, 2008 Posts: 271 Location: Pittsburgh, PA
Posted: Mon Apr 06, 2009 6:35 pm Post subject: |
Ok, I "might" be interested in a set for a '71, assuming they were flame retardant. I wet my existing ones and was able to get them semi-straight.
I've read where others had made their own and I contemplated the same. But I couldn't find the appropriate flame retardant material. Can you? _________________ Add life to your years, instead of years to your life. |
LetsGoCamping Samba Member
Joined: February 26, 2008 Posts: 207 Location: Corona, CA
Posted: Mon Apr 06, 2009 9:30 pm Post subject: |
Count me in if the price is right. _________________ 1969 Westy Tin Top. |
Desertbusman Samba Member
Posted: Mon Apr 06, 2009 10:16 pm Post subject: |
You don't want to use tarboard like bugs use. It is just tar impregnated heavy paper board. It sags big time as it has no strength when hot. Even when it is on the vertical surfaces of a bug it ends up sagging and drooping. Thats why on a bug firewall there are many of the pointed "spikes" to hold it in place. And it still ends up sagging with time. It would be no good on a overhead surface. Additionally it wouldn't work as it has to support the weight of the insulation panels. The '71, '70, and maybe earlier busses used a hardboard equivilant of masonite. It's painted black and not impregnated. When I remade mine I sealed them with Thompson's water seal to prevent future damage from absorbing moisture and then good paint sealing. Also the fiberglass insulation panels were originally sealed with a plastic film wrap. Do a Samba search as this has been covered in detail a few times already.
part numbers for 3 of the 4 fibreglass insulation panels.
_________________ 71 Superbug
71 Westy |
Posted: Tue Apr 07, 2009 12:04 am Post subject: |
Wow, Desertbusman thanks for that info.
How is that stuff different to masonite? Density or something?
I'm interested that your insulation is fiberglass. I think mine is fuzzy coloured thready stuff sort of like carpet underlay or some seat stuffings.
Not sure if it's a '75 or an Australian thing. I'll grab the part number of the inspection plate stuffing tomorrow. Don't feel like shifting the tools off the bed tonight. |
Posted: Tue Apr 07, 2009 12:26 am Post subject: |
RatCamper wrote: |
The original might not be quite as dense as masonite. And it looks a little like press board where flakes were pressed together although much more less flaky. And actually it might have been the same material as was used on the OG door panels. Evidently that exact material might not be available any longer. Cheap brand new door panels are made from a mickey mouse type heavy paperboard. Good ones are made of masonite. I think the key to using any of that type material is water proofing it. _________________ 71 Superbug
71 Westy |
Posted: Tue Apr 07, 2009 6:36 am Post subject: |
my boards ive seen in both my 70 and 69 are like that of a bug, also there are 1 inch clips that fold and hold the boards in place. the boards have warped and are on their way out, they are not falling apart but they dont fit exactly like they should. my idea would only be for deadening purpose and im not exactly sure what effects if any on cooling it will have. it will definately make my compartment nicer. look ill cut a few sets and display them , and if any have interest please let me know. _________________ once you realize im not impressed we will get along just fine |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Tue Apr 07, 2009 6:55 am Post subject: |
Do a Samba search as this has been covered in detail a few times already. |
here's one: http://www.thesamba.com/vw/forum/viewtopic.php?t=288082 _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Tue Apr 07, 2009 9:51 am Post subject: |
i know it was covered by 3 pages already , but no one ever discussed producing more than one set. _________________ once you realize im not impressed we will get along just fine |
Posted: Thu Apr 09, 2009 10:57 pm Post subject: |
I should have a set for my '71 next week. Looking at masonite cut by laser or high temp black HDPE waterjet cut. When I have an idea on price I will post. Also running a set of caliper mounts from 6061 T6 billet at the same time. I will need to do a little finishing before doing a trial mount on the bus. Several Mercedes rotors will fit depending on look required.
1973 Standard Bug
1998 Mexican Bug |
Posted: Fri Apr 10, 2009 4:12 am Post subject: |
alikatcraig wrote: |
Al |
Any more info on the brakes? front or rear? if rear will it preserve the handbrake?
...I miss working on mercs. |
gvjustice Samba Member
Joined: February 17, 2009 Posts: 18 Location: Oxford, MS
Posted: Sun May 22, 2011 4:47 pm Post subject: |
420Goat, did you ever make those panels? |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Sun May 22, 2011 5:16 pm Post subject: |
Good job on those panels Mike. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
