Automatic Accelerator Guide Tube
kkirwin
kkirwin is offline
PostPosted: Sun Apr 05, 2009 10:28 am    Post subject: Automatic Accelerator Guide Tube Reply with quote
Need some help from the auto tranny folks. I had my accelerator cable break and when removing the old cable I discovered the guide tube was broken, possibly the cause of the cable to break. There is a round metal end with a groove that connects to a bracket with a c-clip above the transmission housing, this metal end is what broke off. The tube is metal spiral wound thing covered in vinyl, I found something similar like this:
http://www.oeveedub.com/mm5/merchant.mvc?Screen=PR...gory_Code=
I was wondering if anybody has used this or adapted it with the metal end from the old tube? As far as I can tell the part is NLA since nobody has it listed and I've tried all the used vendors and nobody has one.
Thanks for any help.
1978 Riviera FI Auto Trans
1973 Super Beetle
2003 Dodge Ram 1500 4X4 5.7 HEMI
2012 Suzuki VStrom DL1000
2006 Yamaha WR450
Jonnydaz53
Jonnydaz53 is offline
PostPosted: Wed Jul 21, 2021 9:23 am    Post subject: Re: Automatic Accelerator Guide Tube Reply with quote
anyone found a replacment part for this?
pgtips
pgtips is offline
PostPosted: Fri Jul 23, 2021 8:28 am    Post subject: Re: Automatic Accelerator Guide Tube Reply with quote
from what he is describing that's just a std cable shield can buy anywhere.
I have also used a plastic conduit like the tubing found under the bus in one area where the shielding wasn't suitable.
1975 1.8l FI Auto Westy - Subaru converted
1971 356 kit 1600 TP - semi/stickshift
1971 1302 LS - semi/stickshift
Trim ring info here -> http://www.thesamba.com/vw/forum/viewtopic.php?t=559668
http://www.thesamba.com/vw/forum/viewtopic.php?t=451210
http://www.thesamba.com/vw/forum/viewtopic.php?t=479721
