GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Mon Apr 06, 2009 3:19 pm Post subject: |
1621 wrote: |
I've always thought the Westy brown could use a splash of a periwinkle floral print! |
That's what you get for letting your wife drive it! _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
plummerdesign Samba Member
Posted: Thu Nov 25, 2010 4:32 pm Post subject: |
1621 and I are on the same page here.
The cargo shade allows a bit less interest for those who peek in the windows while we are out doing the fun stuff. People cannot miss my green Westy. They leave notes under the wiper and noseprints on the window glass.
So this month I will begin the process of designing a UV resistant, washable, tan fabric panel that will attach just like the sliding door window curtain. Perhaps even adding a set of front/back fiberglass stiffner rods to keep the cover taunt (these rods can stow up in the nook by the rear window). By keeping away from a roller-type shade it can stow easily with the window coverings.
Will share how it comes out with the Samba. If someone wants one afterwards, maybe we do that too.
Cheers,
Jeffery
. _________________ It is old and green and it makes me grin.
1984 Westfalia 1.9 |
simd0ggie Samba Member
Joined: April 24, 2008 Posts: 418 Location: Chincoteague, VA
Posted: Thu Nov 25, 2010 4:47 pm Post subject: |
I don't see the width REQUIRED here in this post, and since I don't have a T3...
Anyway, my wife's Dodge Caliber has one of the nicest designs I've seen, and it is approx 50" wide. Retractable cover, and the roller unit (bar just behind rear seat) has springy ends that fit into notches, that you could easily replicate. The springy ends make it able to have a little play in the width, and easy to install and remove for laying the rear seat down. _________________ -Matt
'85 Westfalia w/EJ25, '14 Tiguan R-Line 4 Motion
"There are two possible outcomes: if the result confirms the hypothesis, then you've made a measurement. If the result is contrary to the hypothesis, then you've made a discovery.” |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Thu Nov 25, 2010 4:51 pm Post subject: |
Check the first post
45.5" wide by 35" deep _________________ 89 Westy 2.1 Auto |
Posted: Thu Nov 25, 2010 5:06 pm Post subject: |
whoops! _________________ -Matt
Zeitgeist 13 Samba Member
Posted: Thu Nov 25, 2010 6:50 pm Post subject: |
A Mercedes double roller blind would be a cool addition, 'cause it not only has the horizontal cargo cover, but also includes a vertical pet partition. It's 50.5" wide and kinda pricey. They're available in a variety of colors. I have one in grey for my wagon.
http://cgi.ebay.com/ebaymotors/MERCEDES-W124-300TE...53e4cbab41
Another option would be the Audi 100CS Avant rear cover which is 54.5" wide _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
1621 Samba Member
Posted: Thu Nov 25, 2010 8:06 pm Post subject: |
I should probably update anyone interested in the progress I made. I had a roller shade trimmed down to my exact dimensions and mounted it just behind the rear backrest. I placed a dowel in the end of the fabric and made it possible to fix it into place at the rear. It was really effective except for the return mechanism. It seems the springs are set to return the shade from a vertical position, not from a horizontal position like in the van. Not a deal breaker, just a minor annoyance. My other issue was that if I wanted to grab something in the back from the rear seat I'd need to go around and roll back the cover. Still, the cover worked exactly as I'd intended from the beginning.
Ultimately though, the spring mechanism died, and I wasn't willing to go through the process again every year or so. I now think Jeffery (plummerdesign) is on a better path by keeping it simple with a sheet of fabric that can be folded up and stowed away. Perhaps even using snaps at the corners to fasten it would make it fool proof while also allowing for access to the rear from the back seat. Jeffery, I'm looking forward to seeing your design, hopefully in person on Dec. 19th when a bunch of locals meet up at the NW Lucky Lab. _________________ '85 Westy |
thummmper Samba Member
Joined: November 25, 2009 Posts: 2015 Location: Meadow Valley, California Republic
Posted: Thu Nov 25, 2010 10:46 pm Post subject: |
this is where window shopping at the jy is invaluable--lots of diversity and quantity. thats how I found out the F150 muffler would work. take a tape withya, and go on a fact finding mission.
Ill bet the isuzu rocky or amigo has something your size. the suby legacy has one too. most little wagons, like a 95 accord wagon. they attach to the rear strut towers and have lambchop fins on the sides to provide strait channels for the sides to slide in.
carterzest Samba Member
Joined: January 22, 2008 Posts: 3842 Location: Eagle, ID/Sun Valley, ID
Posted: Fri Nov 26, 2010 12:51 am Post subject: |
1621 wrote: |
I now think Jeffery (plummerdesign) is on a better path by keeping it simple with a sheet of fabric that can be folded up and stowed away. Jeffery, I'm looking forward to seeing your design, hopefully in person on Dec. 19th when a bunch of locals meet up at the NW Lucky Lab. |
Oh snap, another Jeffrey in the PDX group and another van to be Green with envy over Can't wait boys! I am thinking a sunbrella cover made to fit with snaps may be the best way to go. _________________ Happiness=Portland, Oregon in the rearview mirror! |
HAPIKAMPER Samba Member
Joined: September 27, 2009 Posts: 74 Location: NOR CAL
Posted: Fri Nov 26, 2010 9:48 pm Post subject: |
1621,
I'm a damage writer for a large rental fleet, If your still interested in your original design I will measure a few for you and see if I can find something to your specs. Thinking i might want to do the same to my "fat bastard" _________________ 1997 VW Eurovan Camper Winnebago...aka "Bibendum"
" I don't care to belong to a club that accepts people like me as members'' - Groucho Marx |
1621 Samba Member
Posted: Fri Nov 26, 2010 10:40 pm Post subject: |
HAPIKAMPER wrote: |
1621,
I'm a damage writer for a large rental fleet, If your still interested in your original design I will measure a few for you and see if I can find something to your specs. Thinking i might want to do the same to my "fat bastard" |
Well how could I turn down an offer like that? If you do stumble across something, please keep us informed. I imagine some of those factory covers could potentially be modified to fit as well. Thanks, and I'm interested in seeing what others come up with. _________________ '85 Westy |
Posted: Wed May 04, 2011 11:12 am Post subject: |
Just to follow up, I did install a simple roller cargo shade and offer up a visual guide to everyone.
My stuff is a bit more hidden when out and about. The less they see, the less they are tempted.
Cheers,
Jeffery
Posted: Thu May 12, 2011 7:56 pm Post subject: |
Image is to show that the shade extends WITH the rear hatch. OR it can be un-hooked and retracted prior to opening the hatch. Simple and useful. _________________ It is old and green and it makes me grin.
SteelB12 Samba Member
Joined: December 21, 2010 Posts: 591 Location: Central Virginia
Posted: Fri May 13, 2011 1:34 am Post subject: |
That is cool. I might even be able to do that |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat May 14, 2011 9:44 pm Post subject: |
I like it - nice work!
_________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
HeftySmurf Samba Member
Joined: June 15, 2008 Posts: 879 Location: Washington, USA
Posted: Sat May 14, 2011 10:34 pm Post subject: |
Could always tint your windows too _________________ -Lorenzo
90 GL w/ Bostig |
Steelhead Samba Member
Joined: February 25, 2007 Posts: 1791 Location: Kentfield, CA
Posted: Sun May 15, 2011 1:34 pm Post subject: |
PDXWesty wrote: |
I just close my rear curtains. $0.00 |
x2. I'm all for innovation, but how is this more desirable than a curtain? Seems like more for me to break and or/get in the way. _________________ '77 Bay Window / '89 Caratsburg (aka. the Stormtrooper) |
supersooner Samba Member
Joined: July 27, 2005 Posts: 131 Location: At the ranch - 20 miles east of Oklahoma City
Posted: Sun May 15, 2011 1:54 pm Post subject: |
Better, I think, because one doesn't have to close the curtains at each stop and open them again when leaving. Not a big chore, but the cargo cover is more convenient. |
1621 Samba Member
Posted: Sun May 15, 2011 2:08 pm Post subject: |
plummerdesign wrote: |
Image is to show that the shade extends WITH the rear hatch. OR it can be un-hooked and retracted prior to opening the hatch. Simple and useful. |
Very nicely set up! My version ultimately failed due to the roller mechanism, and the fact that I couldn't access the items undercover without getting out and walking to the rear of the van. Your set up with the roller at the rear remedies this while also "opening" like a trunk with the rear hatch lifted. I'm eager to check this out in person someday soon. Maybe one of the local meet-ups this spring or summer.
Erik _________________ '85 Westy |
Posted: Sun May 15, 2011 8:26 pm Post subject: |
okcattleco wrote: |
Better, because one doesn't have to close the curtains at each stop and open them again when leaving. Not a big chore, but the cargo cover is more convenient. |
...'zactly! _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
