DrDarby Samba Member
Joined: May 12, 2004 Posts: 6534 Location: Northern Illinois
Posted: Mon Apr 06, 2009 1:33 pm Post subject: New carb for an Autostick? |
I'm working on a '71 A/S Ghia with a cronic idle problem. The car is a 55k orig mile virgin but I can't get the carb to wake up and I've cleaned and rebuilt it before. I can't find a new carb with the proper vacuum ports. Any ideas? Currently I have the idle jet loose and it will idle that way but it's a band aid fix. _________________ Midwest Autosavers, Inc. Woodstock, IL |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Mon Apr 06, 2009 2:11 pm Post subject: |
just drill a vac port. it's not hard. keifernet might have one. what type of distributor do you have? _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Mon Apr 06, 2009 2:28 pm Post subject: |
The correct flange # for a German Solex for auto stick for 71 is "282-1"... and if your running the DVDA still then that is what you would need... or a 72 is "282-2" and in 73 there were "281-4" which had generator linkage and "281-5" which had alt linkage... but the accel linkage is interchangeable so that is not an issue. These cores show up from time to time.
SVDA versions were the "412-1" ( late 73 )and the "428-1" (74)
There are probably a couple other odd numbers that are out there too I run across an odd one once in awhile...
The Bocar and aftermarket carbs have all the vac ports on them and are *supposed to work with everthing but we know how that goes.
You can drill out the port pretty easy if you have another German carb you like... but I don't see what is wrong with setting the idle pilot jet where it needs to be to run. I have done it for over 25 years on 34's... to me it's not a band aid... it fixes the problem of some monkey over tightening the shit out of the pilot jet at some point in the carb's life... and I'd rather have a German carb with that than a Kafer or Empi or Pierburg Chinese POS... |
59eurobug Samba Member
Posted: Mon Apr 06, 2009 2:35 pm Post subject: |
would his ghia still be a single port? i have a manifold and carb for an autostick with a single port engine |
volkenstein Samba Member
Joined: June 26, 2005 Posts: 858 Location: The Land of Oz
Posted: Mon Apr 06, 2009 4:49 pm Post subject: |
DrDarby,
Done to death over on vwar .
http://www.vwar.org/forum/index.php?topic=608.0
If you want to retain the carb for orginalities sake...I'd say Keifernet is the man to rescue it!
Enjoy
Volkenstein _________________ 71 RHD AS Super - "Klaus"...
Wisdom of youth, energy of old age... |
