73' Thing Fuse Box/ Wiper Motor Questions
hollycanon
hollycanon is offline
PostPosted: Tue Apr 07, 2009 2:57 pm    Post subject: 73' Thing Fuse Box/ Wiper Motor Questions Reply with quote
I just bought my 73' thing and I'm a little green on where everything is located on the vehicle.
The wipers are not working, but I was "assured" by the seller that they did work and that the fuse may have been blown. Where is the fuse box and does it take standard fuses.
If you have other suggestions I would really appreciate the help.
I'll post pics soon.
Captain Spalding
Captain Spalding is offline
PostPosted: Tue Apr 07, 2009 4:07 pm    Post subject: Re: 73' Thing Fuse Box/ Wiper Motor Questions Reply with quote
First off, welcome to the forum!
The following is from the owner's manual. The wipers are on fuse 1. If the fuse is the problem, the turn indicators shouldn't work either. It's a good idea while you're playing around with the fuse box to remove all the fuses and clean the contacts, both on the fuses and the fuse box, and then reinstall.
The fuses you want are sometimes called torpedo or Bosch fuses. They look like this:
ETA: Don't be surprised if the fuse is not the problem. Even if it is, there is a reason the fuse blew. The wiper motor is a recurring topic here. Often times they go bad. Replacements can be hard to find and expensive. The good news is that many in many cases the motor can be disassembled, purged of the thirty-year-old grease, re-lubricated, electrical contacts cleaned, and that will solve the problem.
thinghunter
thinghunter is offline
PostPosted: Wed Apr 08, 2009 10:17 am    Post subject: Reply with quote
Also, try taking the posts apart that go through the windshield frame and clean and lube them. These being caked with 35 yr old grime can cause the motor to work harder than it should be.
Rabid Irish
Rabid Irish is offline
PostPosted: Thu Feb 16, 2012 10:02 am    Post subject: Reply with quote
Bringing this back form the dead.
Everytime I turn on my wipers the fuse blows. When I first bought the car everything worked great. I removed all the fuses and cleaned the contacts.
Turn signals seem to function just fine with no problems as long as the fuse is not blown. As soon as I hit the switch for the wipers it instantly pops.
Anyone recomend some troubleshooting starting points? I did do a search but can't find anything with the same symptoms as mine. I didn't want to start a new thread because I know how much of a sore subject that can be around here. Any help would be greatly appreciated.
Semper_Dad
Semper_Dad is offline
PostPosted: Thu Feb 16, 2012 10:13 am    Post subject: Reply with quote
Does the fuse blow immediately when you activate the switch? or does it take a couple of seconds? Just in low speed? high speed?
74 VW Thing - Walküre (Now Project)
Rabid Irish
PostPosted: Thu Feb 16, 2012 10:40 am    Post subject: Reply with quote
I will check next time I head over to the garage. I Think it goes instantly in any setting.
citroen
citroen is offline
PostPosted: Fri Feb 17, 2012 9:57 pm    Post subject: Reply with quote
motor locked, one or both wiper pivots froze,or wire going to wiper motor or switch shorted disconect right wiper arm first to see if it moves next check for bare wires then the motor may be froze
Semper_Dad
PostPosted: Fri Feb 17, 2012 10:19 pm    Post subject: Reply with quote
If the fuse blows imediately, then most likely the switch
If it takes a second or two. most likely an issue with the motor or some bound up linkage.
Below is a current flow diagram of the wire system showing the currant path in each of the modes.
The following procedure will check the operation of the wiper motor. It takes the wiper switch out of the equation.
1) Disconnect the moon shaped connector (with 4 wires)
2) Place a jumper wire in the connecter between the Black and Black/Grey wires.
3) Turn on ignition (Wiper motor should move in slow speed)
4) Turn off ignition
5) Move jumper to Black/Yellow and Black/Grey
6) Turn on ignition (Wiper motor should move in fasterish speed)
If motor works using this procedure then switch is most likely the issue
Rabid Irish
PostPosted: Sat Feb 18, 2012 12:24 pm    Post subject: Reply with quote
Thanks for the tips gents. So if I do determine that it's the switch, would I need to replace the whole column switch unit (wiper and turn signal)?
[email protected] Premium Member
mpb181@aol.com is offline
PostPosted: Sat Feb 18, 2012 1:04 pm    Post subject: Reply with quote
My guess is the wiper motor you could send to me I could look at it for you or just take the cover off and take a picture of it so I can see what's wrong
Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173
Semper_Dad
PostPosted: Sat Feb 18, 2012 2:17 pm    Post subject: Reply with quote
The wiper and turn signal switches are nested together but they come apart and you only need to replace the bad switch.
Rabid Irish
PostPosted: Mon Feb 20, 2012 9:15 am    Post subject: Reply with quote
I am going to try and get over to the car some time this week to look into the issue a bit more. While I am there I will snap a picture of the motor with the cover off.
Rabid Irish
PostPosted: Fri Mar 23, 2012 11:52 am    Post subject: Reply with quote
Just wanted to stop back in to thank everyone for helping me with this issue. Turns out nothing was wrong at all. Seems at some point while cleaning up connections I inadvertanly plugged the connector back in and the prong closest to the drivers door did not go back into the connector. It slid along side the outside. So whenever I hit the wiper switch it shorted out blowing the fuse. I still used the jumper method to make sure everything was in good working order. Plugged the connector back in CORRECTLY and the wipers worked like a charm. Very thankfull no harm was caused by this except for a few blown fuses. THANKS AGAIN!!!
Captain Spalding
PostPosted: Fri Mar 23, 2012 1:49 pm    Post subject: Reply with quote
Excellent news.
@SemperDad: your explanation with diagram above was brilliant. Did you make up the diagram yourself?
Semper_Dad
PostPosted: Fri Mar 23, 2012 11:52 pm    Post subject: Reply with quote
Captain Spalding wrote:
Excellent news.
Yes I did. All I had to work with is MS Paint though. Feel free to clean it up if you wish. Sometimes it hard to see the tree behind all those leaves.
Captain Spalding
PostPosted: Sat Mar 24, 2012 9:34 am    Post subject: Reply with quote
Are you kidding? It's great!
