50Split Samba Member
Posted: Fri Apr 10, 2009 5:31 pm Post subject: Rusted area on my '58 Ghia |
Does anyone know if this area (rear outer wheel well) is repoped? KGPR shows the top half of this section, but doesn't seem to go all the way down to the bottom of the fender. I need to replace this rusted out section for my '58 lowlight Ghia. It's the passenger side. If not, does any one have a dry, used section for sale? Thanks for any and all help.
_________________ Quintin - IG @GFK602 |
anthracitedub Samba Member
Posted: Fri Apr 10, 2009 6:34 pm Post subject: |
You could just make it out of sheet metal...very easy. |
1960bus Samba Member
tstracy39 Samba Member
Joined: May 14, 2008 Posts: 3294 Location: Seattle, WA
Posted: Sun Apr 12, 2009 12:00 am Post subject: |
The little inner piece that attaches to the crossmember and has the torsion bar hole is definately reproduced for later model Ghias, for lowlights you might be able to get one imported, or modify a later one to fit. |
Posted: Mon Apr 13, 2009 3:18 pm Post subject: |
tstracy39 wrote: |
This is the rear where the bumper mounts. I guess have to stick with plan A. Make it from scratch... _________________ Quintin - IG @GFK602 |
Posted: Mon Apr 13, 2009 3:22 pm Post subject: |
Thanks, I was hoping for someone in the states to make this piece. It will just have to be fabricated. _________________ Quintin - IG @GFK602 |
garabaldy Samba Member
Joined: November 14, 2007 Posts: 19 Location: parker,co
Posted: Mon Apr 13, 2009 3:49 pm Post subject: |
Thanks! _________________ Quintin - IG @GFK602 |
pbaptist Samba Member
Joined: January 02, 2005 Posts: 1205 Location: Netherlands
Posted: Mon Apr 13, 2009 11:52 pm Post subject: |
It will not work on a 58!!
The inner rear fenders for 56-66 is different than 67-74
Patrick _________________ Dutch Karmann-Ghia and coachbuild lover.
1* Karmann Ghia Coupe (1966 Teak)
2* Karmann Ghia Convertible (1958, 1971)
4* Rometsch Lawrence (nr 534, 555, 558 and 561)
Karmann-Ghia Lowlight page and registry
Karmann-Ghia Collectibles database |
