Rebuilt 2.2L wbx engine no oil pressure on start up?
Ryan Pruden
Ryan Pruden is offline
PostPosted: Thu Jun 28, 2012 5:18 pm    Post subject: Rebuilt 2.2L wbx engine no oil pressure on start up? Reply with quote
hey rebuilt my wbx into a 2.2 and can only get pressure once, after i prime the pump.... seems like the pickup is restricted or something???
I removed the oil pump and everything seems normal, blow compressed air through the passage and can hear it blowing bubbles on the suction side. And on the other side i have a gauge tee-d in with the pressure switch and it builds 30psi when blowing into it.
any ideas???
ive already dumped the oil several times....
Ryan Pruden
PostPosted: Thu Jun 28, 2012 6:15 pm    Post subject: Reply with quote
Someone? I'm stumped...
stevey88
stevey88 is offline
PostPosted: Thu Jun 28, 2012 8:54 pm    Post subject: Reply with quote
Was the rear end of your van jacked up ? Try jacking up the front end so the oil pump is submerged in engine oil.
Steve
87 Westfalia full camper 4 speed
Ryan Pruden
PostPosted: Thu Jun 28, 2012 11:00 pm    Post subject: Reply with quote
tried that to... thanks thou
pulled engine and torn it apart, cant see anything wrong. some more inspections and back together tomorrow.
hopefully it was just something weird, air locked somehow? I even used a vac pump and pulled oil from the sump, thru the pump and out the filter housing.
stevey88
stevey88 is offline
PostPosted: Thu Jun 28, 2012 11:24 pm    Post subject: Reply with quote
Just wondering. When you have the oil pump cover off, did the oil pump turn when you turn the crank shaft ? If you use a type 1 cam and the Vanagon oil pump, the pump will not turn because the drive will not reach the slot at the cam.
Also, is the oil pressure relieve valve piston and spring in and the piston can move freely ?
There is only a few thou clearance from the oil pump cover and the oil pump gear, it should be very difficult to suck oil out this way.
Steve
AtlasShrugged
AtlasShrugged is offline
PostPosted: Fri Jun 29, 2012 6:50 am    Post subject: Reply with quote
If the oil pump is engaging the camshaft , and is turning ...your pressure relief spring/piston are correctly installed , try packing the oil pump with Vaseline. It will "prime " the pump, which can be an issue dry.
Ryan Pruden
PostPosted: Fri Jun 29, 2012 7:45 am    Post subject: Reply with quote
Its all stock, the pump engages alittle over a 1/4"
All the relief stuff is there and free...
It took a fair bit of vacuum to pull the oil thru
Ryan Pruden
PostPosted: Fri Jun 29, 2012 7:48 am    Post subject: Reply with quote
I packed it with assembly lube, I normally do this on all my aircooled engines too, but this is my first wbx.
This is driving me nuts!
stevey88
stevey88 is offline
PostPosted: Fri Jun 29, 2012 10:22 pm    Post subject: Reply with quote
Any updates ?
Steve
Wildthings
Wildthings is offline
PostPosted: Sat Jun 30, 2012 3:51 am    Post subject: Re: Rebuilt 2.2L wbx engine no oil pressure on start up? Reply with quote
So you get pressure the first time you fire the engine up, but on repeated tries you do not? How tight does your pump fit to the case? Did you use a gasket under the cover or not?
tencentlife
tencentlife is offline
PostPosted: Sat Jun 30, 2012 9:56 am    Post subject: Reply with quote
There's a scrap of rag or paper towel or something in the oil suction head.
See innovative Vanagon accessories at the Vanistan shop:
I don't use The Samba Private Messaging. Please use the contact link at www.intrepidoverland.com
"Official" IntrepidOverland thread for news and discussion:
Ryan Pruden
PostPosted: Sun Jul 01, 2012 7:35 pm    Post subject: Reply with quote
That was my exact thought too, so pulled the engine and tore it apart on thursday evening. Went over everything and couldn't find any issues! So I put it back together and installed it on friday. Within 5 seconds I had pressure, and every other time I would have pressure within 2 seconds after that.... Then I proceeded to still go camping all weekend with the new found power of the 2.2L! Its awesome!
34 hours of stress to find nothing... Never seen anything like it before.
Ryan Pruden
PostPosted: Sun Jul 01, 2012 7:40 pm    Post subject: Re: Rebuilt 2.2L wbx engine no oil pressure on start up? Reply with quote
Pump was snug slidding into the case, I sanded the pump face flush with the gears and used a .004 gasket installed dry.
