Solan Samba Member
Joined: March 26, 2009 Posts: 41 Location: Bergen, Norway
Posted: Mon May 16, 2011 4:18 am Post subject: |
Ok, I will convert
I've actually come across several "types" of inches, are the inches in your post like this: 1 inch = 25,4 mm ? _________________ '65 11W Microbus
'52 Beetle ragtop |
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
durfeec Samba Member
Posted: Mon May 16, 2011 8:26 pm Post subject: |
EDragnDean, I noticed you didn't cover the bottom or back of your seat like the originals are. You only covered the cushion. How come? How does the cushion attach to the wood? _________________ 1960 Bus Panel/Camper |
Solan Samba Member
Posted: Tue May 17, 2011 2:20 am Post subject: |
EDragnDean wrote: |
Solan wrote: |
Ok, I will convert
I've actually come across several "types" of inches, are the inches in your post like this: 1 inch = 25,4 mm ? |
Correct. Or we could send you an American Standard tape measure... |
America goes metric, inch by inch...? Thanks, but I think I'll stick with the millimeters
By the way, it's Norway's national day today, everyone's waving the flag, and wearing the national costume. Except me, I'm lying under an old bus...
Have a nice day!
Cheers from Norway
Svein _________________ '65 11W Microbus
'52 Beetle ragtop |
blacter Samba Member
Joined: October 14, 2004 Posts: 157 Location: Bend, OR
Posted: Sun Jul 10, 2011 8:04 pm Post subject: |
Anybody know if these dimensions will work on a Bay? I have a '71. |
Solan Samba Member
Posted: Sun Jul 10, 2011 10:46 pm Post subject: |
EDragnDean wrote: |
Bay rear seats are approx 2 inches shorter. So all measurments should work, just remove 2 inches from the overall width. |
Are Bay seats really shorter...? Or did you mean that split seats are shorter? _________________ '65 11W Microbus
'52 Beetle ragtop |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Mon Jul 11, 2011 5:29 am Post subject: |
Solan wrote: |
EDragnDean wrote: |
Solan wrote: |
Ok, I will convert
Have a nice day!
Cheers from Norway
Svein |
wow! british army used metric system in 1776. they were still using it in 1812. mexico used metric during spanish american war. germany used metric in 1914-1918. japan and germany used metric in 1939 to 1945. hmm i like .50 cal instead of 12.2 caliber metric. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
Posted: Mon Jul 11, 2011 1:51 pm Post subject: |
EDragnDean wrote: |
When you say "width," you're talking about the dimension from one side of the bus to the other (50-something inches) correct?
Where would I measure to see how wide I can go?
Thanks. |
Matarcos Samba Member
Joined: July 01, 2011 Posts: 1 Location: Quito, Ecuador
Posted: Sat Jul 16, 2011 6:40 pm Post subject: hinges measurements |
does anyone can help me with the measurements and tech specs of the hinges in order to try a reproduction |
KILLERWATT Samba Member
Joined: November 18, 2003 Posts: 3298 Location: Vero Beach
Posted: Sun Jul 17, 2011 7:54 pm Post subject: |
brettsvw wrote: |
Here is how I turned my 3/4 rock-n-roll bracket to be a full width bed.
Did my hinges today! Thanks for the tutorial!
live2surf Samba Member
Posted: Tue Jul 26, 2011 4:19 am Post subject: |
Hi EDragnDean, can middle seats be installed once the RnR bed is fitted? Is the bed too long to include a middle seat or is shortening the width of the seat base a possibility to accommodate this? Room for small bums only though! Thanks, and great post. |
Posted: Thu Aug 11, 2011 6:56 pm Post subject: |
how close did you put the hinges to your side panels? i was looking and couldnt tell. i looked through the other links and couldnt really tell.
im building my bed right now. i started cutting the pieces today. _________________ 1960 Bus Panel/Camper |
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
Posted: Fri Aug 26, 2011 8:03 pm Post subject: |
could i get pics of how to mount the hinges to the bus? i beleive i figured it out but i wanna make sure. i have all the wood cut and stained ready to go. _________________ 1960 Bus Panel/Camper |
Posted: Sat Oct 29, 2011 7:56 am Post subject: |
Getting there but some of the measurements on the original post screwed me up.
I think because I have the SO42 hinges and supports the bolt holes for the sides didn't work for me and the front at 17 inches was too high. The sliding supports need to be mounted in the corners so I notched about 4" down out of the front. I measured an OG 3/4 z bed and the base was only 12" tall in front and 11 1/2" tall on the sides.
BTW I'm using marine grade 3/4" plywood.
