EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
herbie555 Samba Member
Joined: August 25, 2009 Posts: 13 Location: San Diego, CA
Posted: Tue Feb 28, 2012 12:15 pm Post subject: Hinges really stiff? |
Thread resurrection time:
I finally got off the fence and ordered a set of these hinges from Bus Depot, and now I have a question:
Were anybody (or everybody) else's hinges REALLY stiff? Like almost impossible to pivot through the motion?
I had to put one into a vice and really lean into it to even begin to get the linkages to move through their arc. Almost like all the rivets are too tight. Mostly worried that I got a bum pair.
I imagine things will be a bit easier once everything is bolted to a box and I have the leverage of a full seat attached, but I was hoping to move the linkage through it's motions to take some measurements first. Maybe I'll have to build a miniature "sample" bed box or something.
Thanks. |
durfeec Samba Member
Posted: Tue Feb 28, 2012 2:57 pm Post subject: |
Oh yes. Mine were extremely stiff out of the box. Once you get them bolted to the frame and use the leverage of the seat bottom to move them, they are normal. They are still a little stiff but at least my seat isnt moving on its own. Dont worry. They are worth the money and yours are fine. _________________ 1960 Bus Panel/Camper |
awalls Samba Member
Joined: March 21, 2005 Posts: 128 Location: Beaverton, OR
Posted: Tue Feb 28, 2012 6:04 pm Post subject: |
Since this thread is back:
Anyone have and estimate for cost to make cushions? Just a ball park would be great. Thanks. _________________ '64 Bug
'58 Kombi |
Scooterboyd Samba Member
Joined: January 18, 2009 Posts: 342 Location: Rancho Cordova, California
Posted: Fri Mar 16, 2012 6:32 pm Post subject: |
I just purchased 4" foam 54"x72" (Full size Bed)for $168. Vinyl is $12 yd. Piping and labor TBD. _________________ President of "Society of Unappreciated Overachievers"
62 - 23 Window Bus
60 - Karmann Ghia Convertible
59 - Convertible Raceable Baja Bug
63 - Dune Buggy
65 - Single Cab |
DavidKvapil Samba Member
Posted: Wed Apr 04, 2012 11:23 am Post subject: |
I bought some nice high density, super comfortable 3" thick foam for right about $100 from a local foam store. _________________ '62 Turkis Kombi FOR SALE. Please see my ad. |
rpm750 Samba Member
Joined: April 19, 2007 Posts: 390 Location: Newnan, Ga
Posted: Sun Apr 29, 2012 5:59 pm Post subject: |
I found some stock hinges at the swap and they are almost the same as the new ones you used Dean. I used your measurements and they were spot on. Good times as yo bro says. Can't wait to meet ya face to face in June. Glenn and I are close buds along with Shaky!
Thanks for all the leg work! _________________ rpm750
'64 Sunroof "Geek"
'74 SB "Chigger"
'70 Bus
Georgia Dubs |
sfleet75 Samba Member
Joined: January 28, 2012 Posts: 7 Location: Los Angeles
Posted: Sun Oct 07, 2012 9:57 pm Post subject: q for OP |
question for OP: I am going to swap out existing bench seat in order to build a bed like you showed, and I have a question:
in the pic where you have the actual bottom piece of the bed bolted into the floor of the bus body, the bolt is shown as though it were coming up from the bottom (i.e. head not shown, tail and nut facing up). how do you bolt this from under the vehicle? or is this not how you did it? sorry, never done this before, and am trying to cover my bases here.
also, as for mounting the hinges to the actual floor/wheel well as well, did you just use self-tapping screws to go into the floor metal so as not to need to bolt from underneath, or did you have to do the latter?
thanks
steven |
patban82 Samba Member
Joined: March 22, 2010 Posts: 211 Location: LOS ANGELES, CA
Posted: Mon Jan 06, 2014 3:21 pm Post subject: |
Can anyone come up with a rock n roll bed for a dc. That would be awesome!!! |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Tue Jan 07, 2014 11:16 am Post subject: |
patban82 wrote: |
every DC comes with a bed, it is 6 ft, and if equipped with a nice canopy makes for a great camper... _________________ regards
Uli
EverettB Administrator
Joined: April 11, 2000 Posts: 69807 Location: Phoenix Metro
Posted: Tue Jan 07, 2014 4:47 pm Post subject: |
mandraks wrote: |
patban82 wrote: |
every DC comes with a bed, it is 6 ft, and if equipped with a nice canopy makes for a great camper... |
The Double Cab bed is kind of short to sleep in, I have done it. _________________ How to Post Photos
Heathintexas Samba Member
Joined: September 24, 2011 Posts: 135 Location: Berlin Germany
Posted: Mon Apr 21, 2014 10:01 am Post subject: Rock and Roll bed |
Thanks EDragnDean for the Walkthrough! I used it to build mine yesterday.
I just have one problem that I hope someone here could assist with. When I roll the seat out into the bed, the board closest to the front of the bus doesn't seem to hold more than 30kg with out flexing like crazy. I was hoping to be able to sit at least 200kg(3 people) on the end so it could still act like a chair while in bed mode.
Is this part only able to support the wait of feet when a person is laid out, or should I expect it to be more sturdy?
I used 3/4 inch pine plywood and also the JK hinge kit. _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=582117 |
Ernie Punkin Samba Member
Joined: August 31, 2014 Posts: 84 Location: Hawaii/B.C. Canada/Seattle
Posted: Tue Dec 09, 2014 10:43 pm Post subject: propping up the end board |
Just one quick but slightly odd idea....
What if you use 3 of the readily available adjustable height fold out table legs? Space them between the hinges?
Check JustKampers.com for a few options. Also at other sites, including RV sites and Vanagon later model VW parts sites.
Don't know their weight limit, but I'm thinking they'd mostly help when sleeping with the bed down too. Likely there will be some weight on that end when climbing in and out.
The smallest model doesn't have a very long throw as it's designed for installation on the underside of the the front dash mount table.
When in the bench seat position, they'd be neatly attached to the underside of the bench seat board - inside the box.
To use to prop up your "headboard" or "footboard" just pull them out, snap into place, and adjust the height as needed.
Heck, if someone needs to sleep with their head elevated (as might be the case for a few of us aging baby boomer camping fans ), then the adjustable height legs could provide a bit of slope or lift for one end of the bed, if you purchase them with an appropriate height range. This would work if you tuck your feet into the rear window end of the bed.
To keep from losing pillows on to the camper floor, use one of the long GoWesty cargo nets hooked up to a side wall or something.
Have I just described a camping crib for adults? Kinda crazy, but practical? _________________ 1977 Westfalia "Happy"
Bye Bye 1979 Westfalia ERNIE the REI Bus
Ion Pod Trailer
Posted: Wed Dec 10, 2014 6:35 am Post subject: Re: Rock and Roll bed |
Heathintexas wrote: |
I used 3/4 inch pine plywood and also the JK hinge kit. |
I added a 90 degree piece of angle iron to the bottom of the seat board. Adds more rigidity to the seat base also so it doesn't dip in bench mode. Shows in the original photos.
Ernie -- interesting idea on the table legs, that might work.
I'm thinking if Heathintexas wants more front support, ie a seat in the horizontal, start with the angle iron. Then use a piano hinge set up and add 3/4 plywood that folds off the bottom of the seat or out from the seat base. _________________ 63 Double Cab http://www.thesamba.com/vw/forum/viewtopic.php?t=443823&highlight=deanos
66 Bus Click to view image - SOLD
73 Thing http://www.thesamba.com/vw/forum/viewtopic.php?p=8111202#8111202
70 BusClick to view image |
samanthathevan Samba Member
Posted: Wed Mar 25, 2015 8:14 am Post subject: |
This is a really great writeup. Thanks! I was originally trying to find zbed hinges to install on my existing rear seat, but maybe I will have to try this if I can't. My one question is, how does this work with seatbelts? I have a 7 month old son in a car seat and the one advantage of the stock bed might be safety for that? |
fwitiw Samba Member
Posted: Fri Apr 17, 2015 8:57 pm Post subject: |
Thank you for having a fantastic write up and thread. I am considering going to the full width from the three quarter bed and will use this thread to guide me.
I saw that HeathinTexas was also creating his own rear facing seat to go with this. Has any one else done this or have dimensions? _________________ 77 Westy 2.0
78 Transporter (no engine yet!)
71 Beetle |
