Tcash Samba Member
Posted: Wed Dec 09, 2015 9:43 pm Post subject: Re: Replacing oil cooler seals |
Speaking of seal composition.
thanks to mayor ratwell
"Q Oil cooler seals 021 117 151A 2 $0.79 Red silicone" |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Thu Dec 10, 2015 8:29 am Post subject: Re: Replacing oil cooler seals |
asiab3 wrote: |
"Well I've never had an issue so I know I'm doing it right!" We've all heard that before, right? That doesn't mean crap anymore, now that all of the world's knowledge is here at our fingertips; I'm here to learn.
I have never had an issue with any Type 4 engine, so I have not pursued it to the extent that some have. That is not to say to Ray Greenwood that I am in some self-exalting state of proudly boasting, "well, at least I know I'm right." Puhleeeeeze.
I don't know anything but that tomorrow is likely to throw a new challenge my direction. There are many variables to be found in these old cars.
I have dealt with Type 1 oil cooler leaks, Type 3 oil cooler leaks, old and new, and the only problems I have been able to spot had to do with the use of incorrect seals, or in the case of my 1600 bus, spacer washers that did not belong.
If I should ever get a call-back for an oil cooler leak, after checking my work and my parts, I might have to open the inquiry and see if the lubrication system has been modified unduly with "heavy duty" pressure relief springs and monster oil pumps and all the other ways we inadvertently open cans of worms.
Like you said Robbie, "I'm here to learn."
Colin _________________ www.itinerant-air-cooled.com |
Tcash Samba Member
Posted: Thu Dec 10, 2015 10:19 am Post subject: Re: Replacing oil cooler seals |
raygreenwood wrote: |
Tcash wrote: |
A quick search came up with this.
"Static seal cross-sections are generally compressed from 10% to 40%"
What does the lip of the seal measure?
Thank you
Tcash |
Let me measure and calculate it will be after lunch. I actually have to work..... |
If you get a chance could you please due this?
Question......what type of seal were they speaking of? The problem with compression in such a wide range....and especially jn such an elastic material.
Sorry missed this. It was a rule of thumb for O-rings. It did not mention the composition of the O-ring either.
http://www.applerubber.com/seal-design-guide/technical-summary/rules-of-thumb.cfm |
Posted: Thu Dec 10, 2015 11:01 am Post subject: Re: Replacing oil cooler seals |
Good link, I think it is important to note that when the seals are compressed they should not exceed the area of the gland.
Quotes from the link:
"The maximum volume of the O-ring should never surpass the minimum volume of the gland."
and
"Static seal cross-sections are generally compressed from 10% to 40%, whereas Dynamic seals are from 10% to only 30%."
In the case of the set of seals at issue here the seals were compressed so tightly that they were forced out of the designed gland area. I would guess that this seal was compressed by about 40-50% in the Saturn ring area forcing the seal inward and outward from the intended gland area.
wbnguyen Samba Member
Posted: Sat Dec 12, 2015 8:25 pm Post subject: Re: Replacing oil cooler seals |
WOW!! Loads of GREAT info! So, I have made a full trip to and from Oregon to San Diego (2k miles) and NO LEAKS! I used the spacer combo as mentioned in my earlier posts. So my oil cooler started leaking upon my arrival into Oregon. The weather went from 95 degrees to a chilling 24 degrees. Assuming the "over tightened" oil cooler seals hardened causing it to piss oil. I have the motor out again dealing with a pilot bearing issue, maybe I can get some pics. Just as a reminder the seals I used were:
Posted: Sat Dec 12, 2015 9:10 pm Post subject: Re: Replacing oil cooler seals |
I would buy and install the best seals you can while you have the chance. |
Posted: Sat Dec 12, 2015 9:31 pm Post subject: Re: Replacing oil cooler seals |
Wildthings wrote: |
You're right, those were my ONLY option to get back on the road in Oregon. They're not leaking...yet. I should pick up some to throw in the tool box. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Sun Dec 13, 2015 8:06 am Post subject: Re: Replacing oil cooler seals |
I guess one of my main reasons for a little over the top interest.....is partly due to the same type of questions raised by the last few posts.
Its not that I am overly questioning the design of the seals......overall they have worked quite well over the eons and zillions made.
But.......just like every other rubber, sealing or elastomer product.....how is the quality and uniformity of these seals holding up these days.....from manufacturer to manufacturer. Thats my question to those looking at this thread. I dont have data on it except for anecdotal experience over the years.
Just with what I have learned about silicone over the past five years.....makes me know for a fact that there MUST be large differences in formulations and capabilities like oil resistance, compression/durometer, porosity etc.
For example....one thing I noticed over the years...even back when I was in high school....was differences in not just color but surface texture and hardness of seals made by various manufacturers. Not that I had any data to say one was better than another.....but some just looked like crap so I avoided them.
For example....and for the life of me I cant remember the exact brand name....but the very common brand with red logo that listed Juntas all over it (yes I know Juntas means seal in Spanish....but it was used as part of the brand name).....had the crappier looking, sharp edged, pinkish seals that looked more like a natural rubber derivitive.
Victor Reinz always seemed to be the smoothest molding....but are noticably harder than the Juntas seals or Elring....which always seemed to be the most consistent.
Just like the crank seals....as we have found.....differences in material hardness snd manufacturing tolerances......have made it where we have definite preferences in what is better (examples being Sabo versus Elring versus Reinz etc.).......my question is will we sooner or later start seeing significant quality issues in these seals as well.
What I am seeing in molded rubber product quality (and not just in the automotive industry)......is the formulations are changing. With normal synthetic rubber products like boots etc......most of those normally HAVE to be injection molded. The equipment cost alone.....means that some level of expertise and precision has to be involved (rubber formulations aside).
With silicones.....most are or have been injection molded....but they do not have to be. They can be pressure molded or cast or vacuum cast. This is also aided by the ever increasing range of casting silicones in the industrial world. Silicone molded products CAN even be made in a back room or a garage....by relatively low skilled people.....like me.
And.....each formulation....and each molding method.....has variations and differing finished product characteristics. I just wonder......if some of the most important seals in our cars.....will sooner or later go the same declining quality route as other seals we have seen.
I'm not saying I have seen this happening at all. But....unless you know what to look for.....how will you know when it starts to happen? Ray |
Tcash Samba Member
Posted: Wed Jan 06, 2016 11:35 pm Post subject: Oil cooler seal failures |
[/img] |
timvw7476 Samba Member
Posted: Thu Jan 07, 2016 12:48 am Post subject: Re: Replacing oil cooler seals |
The only issue I get is slight hardening of the material after several years,
if your seals are distorting, you're over-torquing. My type 4 seals come out
the way they went in, looking like new, but not "feeling" like new.
I do "glue" them in place with Bel-Ray Salt-Water proof wheel bearing
grease, so they don't shift/drop during assembly.
Maybe that stuff (Bel-Ray) is magic? |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Fri Jan 08, 2016 1:55 pm Post subject: Re: Replacing oil cooler seals |
I got out my 1973 issue VW engine service manual and it shows three different cooler layouts
T1 upright 1200, 1300, 1500 T2 1600
All have no spacer washers on the oil cooler fixing studs either original upright cooler or doghouse cooler with adaptor. No spacers under the adaptor either.
T3 1500,1600 with horizontal oil cooler mounted on top of engine block
Spacer washers under oil cooler on fixing bolts
T4 1700 with horizontal oil cooler mounted on the side of engine block.
No spacer washers under the oil cooler
And I discovered where somebody had transposed two pages in 1973 when they inserted an update supplement .. because the diagram showed items which had either two different descriptions for the T3 or no descriptions for the T4 _________________ Ancient vehicles and vessels
blues90 Samba Member
Joined: March 14, 2009 Posts: 1912 Location: Hollywood ,CA
Posted: Fri Feb 12, 2016 7:13 pm Post subject: Re: Replacing oil cooler seals |
I have to add this.
https://www.thesamba.com/vw/gallery/pix/1349520.jpg
This I a photo I posted of the seals off my 73 T3 1600 .
The one on the left came off that engine and I replaced it in 85 when I got this car . I have no idea what brand it was all I knew was the case and cooler were both 10mm and as far as I could tell they were never off before I got it.
This is what it looked like in 97 when I rebuild a 72 case and used the same oil cooler . That seal was not leaking but the rest of the areas were.
From what I can tell from the marks left on that case from the cooler bosses I didn't used the washers , they are larger in OD than the clean marks on that case. I have three of those spacer washers and have forgotten if they came on the 73 when I got it or were on the 72 case. Both cases are late model dual relief 10mm cases and coolers. I know I didn't buy them.
The seal is at about 50% compressed. It is not split or and ID is 11mm at the case side which it the longer small OD end and it's 10 mm at the cooler side. It basically became 11mm to 10mm. I noted no restriction.
I used the same cooler because I knew it was good and clean and didn't leak. Off the top of my head I assume I didn't use the spacers on the 72 case either but 97 is long ago I don't recall. From what I'm reading in these posts is if I have used the 3 spacers it sound possible the seal may not leak . I need to check the thickness of them to know.
The issues is the Bentley and Haynes are all I have and they don't mention the 8mm to 10mm cooler seals all I recall is the spacers and install them if they were there. I had no internet in 97 and certainly not in 85 .
In the T-3 forums there is a writing by Russ Wolf stating only use the spaces with the thick 8mm seals , none with the 10mm and then the 8 to 10 adapter seal which I was never concerned about.
I can see what appears to be cooler seal leaks since I have a leak on the left side that seems to wet the large super cool tin against and under the cylinders. It's not pouring out just oily enough to cause concern. |
patkennedy Samba Member
Joined: January 05, 2014 Posts: 2 Location: Denville, NJ
Posted: Mon Nov 21, 2016 8:29 am Post subject: Re: Replacing oil cooler seals |
I have a 912E that is leaking oil near the cooler. No oil is coming from the oil pressure switch.
I have seen a few blogs that indicate the seals can be removed and replaced without removing the engine or a lot of other components.
The information I read basically said to remove the oil filter, filter housing and then loosen and remove the nuts that hold the cooler in place.
The cooler can then be slid rearwards to access the old seals. Has anyone tried this or think it will work?
Looks like the upper nut on the filter housing is somewhat difficult to get to.
Maybe a special wrench is necessary. Please respond. Thanks, Pat |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Mon Nov 21, 2016 2:23 pm Post subject: Re: Replacing oil cooler seals |
It is possible to do the cooler in the car and there is actually more room than
there is on a late bus.
most of the 76 912e engines in california came with A/C & air pump.
You may want to go to a Porsche tech forum and post this too.
there is a porsche forum here but, few posts or, www.pelicanparts.com
has a tech section
probably been 35 years since i even had a deck lid open on a 912e
Chris _________________ V.W.owner since 1967 |
Posted: Mon Nov 21, 2016 5:27 pm Post subject: Re: Replacing oil cooler seals |
Thanks Chris,
I took your advice and posted the same message on the Pelican Parts Porsche 912 forum. The forums are really amazing. The knowledge that's out there is very useful for the weekend mechanics.
Pat |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Thu Jan 03, 2019 10:14 pm Post subject: Re: Oil cooler seal failures |
I have been researching some cooler seal stuff and read through this thread. I realized that is my photo from several years back when I screwed up an install on my own engine. One might think I had never done it before, but I just did it wrong because I was hurrying.
This has been a great thread. I love the total comprehensive seal ID and install directional by T cash. Well done.
Today I was dealing with a VW type 1 powered air compressor tune up. Owner wanted me to replace the cooler seals. Turns out it is a universal case with 10mm galleys, and a standard cooler with 8mm holes. Finally found some adapter seals in my stuff, only to realize the cooler itself was distorted and would not have sealed anyway. Found a good used cooler (in my pile-0-crap) with 10mm holes. Will install tomorrow if it passes a pressure test. If that fails, it will get a remote cooler mount with adapter. I have all of that crap laying around and need it gone anyway. For the application, it will work fine. _________________ nothing |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Thu Jan 03, 2019 10:32 pm Post subject: Re: Oil cooler seal failures |
cdennisg wrote: |
Today I was dealing with a VW type 1 powered air compressor tune up. Owner wanted me to replace the cooler seals. Turns out it is a universal case with 10mm galleys, and a standard cooler with 8mm holes. Finally found some adapter seals in my stuff, only to realize the cooler itself was distorted and would not have sealed anyway. Found a good used cooler (in my pile-0-crap) with 10mm holes. Will install tomorrow if it passes a pressure test. If that fails, it will get a remote cooler mount with adapter. I have all of that crap laying around and need it gone anyway. For the application, it will work fine. |
Nice! Got pics of the air compressor? I love those things.
Care to share what your mistake was so we can all learn from it?
www.airschooled.com |
Posted: Thu Jan 03, 2019 10:40 pm Post subject: Re: Oil cooler seal failures |
asiab3 wrote: |
cdennisg wrote: |
Robbie |
Pretty sure the mistake was just not making sure I had things aligned properly before tightening. Seals moved out of their spots just enough to get pinched and cut while I snugged things down. Second round went fine. That engine is still doing just fine.
Will upload photos and post. _________________ nothing |
Posted: Thu Jan 03, 2019 10:50 pm Post subject: Re: Replacing oil cooler seals |
I won't fill this thread with photos, and I apologize for their quality. Not my good camera with me today.
One shot of the unit (without fan shroud, carb, alternator, etc) and one shot of the white stepped cooler seals that had been installed who-knows-when by who-knows? Other photos in my gallery. I can provide better photos if requested.
scubasteve321 Samba Member
Posted: Sun May 15, 2022 12:45 pm Post subject: Re: Replacing oil cooler seals |
Thanks all for your input and info, definitely clarified some questions I was going to post, and is helping me on my way to getting my engine together
I am in a bit of a stressful life position at the moment so having trouble digesting all the info
One thing that I don't think I came across is it appears my oil passages are different sized, one is 8mm one is 10mm
This is a dual relief case for a bus
That being said, could I not just use the 10mm for both
shown on the left of the image taken of them on the book?
_________________ 1971 Campmobile Tin-Top
1971 Campmobile Pop-Top
1974 VW Bus |
