Replacing Side Window Seal On a Westy
Wolfram
Wolfram is offline
PostPosted: Tue Apr 14, 2009 9:56 am    Post subject: Replacing Side Window Seal On a Westy Reply with quote
I sent my '88 to have the side window seals replaced and the shop called to say that they could not get at the left rear ones without the cabinets being pulled.
Has anyone else experienced this? It would be a bitch to have to pull the cabinets just to replace the seal.
thanks
Geoff
MarkWard
MarkWard is offline
PostPosted: Tue Apr 14, 2009 11:14 am    Post subject: Reply with quote
The windows are designed to be "pulled" in. There is no room to really work a window in behind the cabinet. If I recall, just replacing my curtain behind the cabinet was a chore. I do know of someone that replaced a windshield from the inside out on a Scirocco once. They were not familiar with how to "pull" one the proper way. I suppose, you might be able to do something similar. Most shops are in the business to make money. Trying to change the L/R window seal of a camper without removing the cabinet would not be worth while. If you have rear AC it will be an even bigger pain in the arse. Regards,
1982 Vanagon Camper with ALH TDI conversion.
1990 Vanagon Camper Syncro conversion.
ftp2leta
ftp2leta is offline
PostPosted: Tue Apr 14, 2009 12:48 pm    Post subject: Re: Replacing Side Window Seal On a Westy Reply with quote
thanks
Geoff
If you 88 as the rear plastic vent at the rear of each side window (part of window),
it's impossible to put the window back with the cabinet.
If you have AC.... = not good, mucho money and hours to work around that situation.
Ben
Working with rust, grease, dirt and dust is a sad truth.
FI part for sale: http://www.benplace.com/parts_sale1.htm
My site: http://www.benplace.com/vw2.htm
Subi conversion: http://www.benplace.com/vanaru_eng.htm
Youtube http://www.youtube.com/user/ftp2leta
