targis58 Samba Member
Joined: July 11, 2006 Posts: 539 Location: sunnyvale,ca
Posted: Wed Apr 15, 2009 5:32 pm Post subject: brake oil leak. what's wrong with this unit? |
I've noticed my brake oil level was getting low too soon after fill up. I looked around under the reservoir and found where the leak was happening. Can you tell me what gets wrong with this unit usually so I can check on it? This unit is located right behind the brake pedal as you can see in the pictures. Thanks in advance.
right side view
left side view
_________________ 90 westy 2wd w/ TBD |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Wed Apr 15, 2009 5:36 pm Post subject: |
That's the clutch master cylinder, if it's leaking you replace it. |
Posted: Wed Apr 15, 2009 5:54 pm Post subject: |
mightyart wrote: |
no repair? _________________ 90 westy 2wd w/ TBD |
tangstadt Samba Member
Joined: December 07, 2008 Posts: 90 Location: Atlanta, GA
Posted: Wed Apr 15, 2009 6:02 pm Post subject: |
You can buy a rebuild kit with new o-rings and stuff for about 5 bucks...But you gotta ask yourself one question "do I feel lucky?" |
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3341 Location: Talos IV, Piedmont Arizona
Posted: Wed Apr 15, 2009 6:35 pm Post subject: |
tangstadt wrote: |
Waste of time___get a new one. Wonder where the fluid went? Look under your carpet. All that fluid will start to eat the paint on the floor. Have fun cleaning that mess.
It's a right of passage___we have all gone thru it. _________________ LEARN TO SELF RESCUE
.....................All Current....................... |
Posted: Wed Apr 15, 2009 7:05 pm Post subject: |
Bill W wrote: |
tangstadt wrote: |
It's a right of passage___we have all gone thru it. |
Yeah! I was able to find the leaking area quick because the carpet was wet on the floor. _________________ 90 westy 2wd w/ TBD |
Posted: Wed Apr 15, 2009 9:48 pm Post subject: |
I kitted mine not too long ago, but I can't remember where I found the kits. They were pretty cheap, like $10 or $11 apiece for the master and slave. A little hard to get the piston back in with the new seal, but not impossible. Should last as long as new. |
?Waldo? Samba Member
Posted: Wed Apr 15, 2009 10:46 pm Post subject: |
It's hard to tell from the pics exactly where the leak is coming from. If it is coming from the boot on top, then get another clutch master cylinder. If it is leaking from that fitting then the fix could be as simple as a new copper washer on either side of that banjo fitting. Clean that area and watch while the clutch pedal is depressed.
Andrew |
Posted: Thu Apr 16, 2009 9:12 am Post subject: |
Andrew A. Libby wrote: |
Andrew |
I checked to see where it s leaking. It doesn't show in the picture but there is a rectangular box thingy above the clear hose. Looks like two bolts are holding it and the bottom bolt is squirting the oil out when I pumped the pedal. _________________ 90 westy 2wd w/ TBD |
Posted: Thu Apr 16, 2009 11:18 am Post subject: |
If I'm not mistaken, then the two left bottom holes simply mount the clutch master. The bottom right is the banjo hyd connection and the top rubber fitting is where the fluid enters from the reservoir. I'm pretty sure the two mounting holes were blind and didn't enter the hyd area at all. If you think the fuel is coming from the bottom of those holes, I would clean it off thoroughly and check again. Perhaps it is leaking from the boot area in a non-visible way and collecting at the bolt.
Andrew |
Posted: Thu Apr 16, 2009 11:44 am Post subject: |
Is it dripping or squirting? If it is actually squirting around a bolt hole then there is a crack or casting flaw and total replacement would be the only option. Replacements are available through many sources. |
Posted: Thu Apr 16, 2009 6:41 pm Post subject: |
Andrew |
You are right
I checked again. It was very hard to see upthere from the pedal area but found the leaking hole on the boot. oil pumped out of a small hole on the boot... what to do now? replace the whole thing? _________________ 90 westy 2wd w/ TBD |
Posted: Thu Apr 16, 2009 6:51 pm Post subject: |
Since you don't seem real familiar with this part of a car, you would probably be way ahead just to order and install a new master cylinder. Swapping them out is very easy, takes little time, and only a few tools. |
Posted: Thu Apr 16, 2009 6:56 pm Post subject: |
Yes, new clutch master is in order. You'll also want to bleed the system of air after replacement.
Andrew |
Posted: Thu Apr 16, 2009 9:01 pm Post subject: |
ok! thanks for all your help guys... _________________ 90 westy 2wd w/ TBD |
kenmag Samba Member
Joined: March 12, 2007 Posts: 275 Location: Toronto, Canada
Posted: Fri Apr 17, 2009 5:09 am Post subject: |
I recommend an OEM stealership unit. Tried an aftermarket one and it failed after 3 months. _________________ 87GL Westy/suby ej22
87GL tintop/suby ej22
05 Golf TDI
95 jetta GLX |
dcaver01 Samba Member
Joined: February 23, 2009 Posts: 103 Location: Los Angeles
Posted: Tue Nov 03, 2009 12:49 pm Post subject: |
Looks like I have the same thing going on with my '86 Vanagon, but I am a bit confused. Why would the clutch master cylinder be leaking brake fluid? I checked the reservoir and it was at the min, so I assume the fluid on my carpet is brake fluid. Also, assuming I do need a new clutch master cylinder, should I also go ahead and install a clutch slave cylinder as the busdepot suggests...
"It's been our experience that if your clutch master cylinder has failed, your clutch slave cylinder is not far behind..."
or are they just trying to sell me an extra part?
I'm not very mechanically inclined, but I have been learning alot so far between reading the forums here and looking through my bently manual. Anyway, any help or advice would be greatly appreciated, and in the mean time is it alright to drive? The brakes seem to be working just fine, but if there is a chance the brakes could give out, I would rather keep it parked until I get this fixed.
Thanks!
-Dave |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17121 Location: Retired South Florida
Posted: Tue Nov 03, 2009 1:29 pm Post subject: |
Dave, the brakes and clutch share the same resevoir. Should you replace both the clutch master and slave at the same time? I would. They can be a bitch to bleed. Both operate the same amount. If you replace both, you can mark them off your to do list. If you don't mind redoing the clutch bleeding when the slave lays down, then replacing only the defective part is fine. _________________ ☮️ |
Posted: Tue Nov 03, 2009 1:42 pm Post subject: |
rsxsr,
Thanks for the reply, I suppose I will go ahead and replace both. Have you ever replaced either of these parts? If so, how difficult was the job? |
