Yet another design for an interior hatch release/latch
Page: Previous  1, 2, 3
teej
teej is offline
PostPosted: Fri Feb 07, 2014 8:14 am    Post subject: Reply with quote
Thanks guys for putting up those pics of the later model hatch release.
1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans
fxr
fxr is offline
PostPosted: Mon Jul 11, 2016 11:36 am    Post subject: Re: Yet another design for an interior hatch release/latch Reply with quote
I've just added an inside latch using the actuator from West Marine shown earlier in the thread (but without the lock). Although pricey at about $44, it was cheaper than any other lever/actuator I could find.
http://www.westmarine.com/buy/perko--non-locking-f...ar--402679
I had an operating cable left over from the discarded bits of the Town and Country front seat replacement. One hole drilled in the rear latch mechanism and a bit of steel corner bracing drilled and cut did one end:
Some cutting and drilling of the West Marine actuator and another corner brace finished the other end:
It took some experimentation to get enough mechanical advantage for Mrs fxr to operate it, but she declares the end result a winner. Wink
Jim Crowther
Vespa GTS 300
dsdunbar
dsdunbar is offline
PostPosted: Tue Jul 25, 2017 10:21 am    Post subject: Re: Yet another design for an interior hatch release/latch Reply with quote
I just installed the VC hatch release mechanism (found on the later models ('90 and '91?). I also added a simple parachute cord pull down where the door panel already had 2 holes (about 2.5" apart). I will add a picture of the finished product but wanted to post. This took me about 45 mins, but most of the time was measuring and prep.
I didn't have the tools referenced from HF for removing the clips, but I did have some gardening weed puller. I should have put tape on the end of the tool to not mar the paint, I didn't so I ended up w/ some scratches d'oh! .
anyways, pictures for reference if they help anyone:
'89 2WD Westy "Grey Goose" - Manual 4spd
Crozet VA
Vanaru EJ25, Peloquin
MootPoint
MootPoint is offline
PostPosted: Tue Jul 25, 2017 10:47 am    Post subject: Re: Yet another design for an interior hatch release/latch Reply with quote
In reviewing this thread I have noticed that photos in my posts (and many others) are now squelched by $#@&$!! Photobucket because I'm posting to a "3rd party hosting site." Since I can't edit anything that's been posted for "86,400 minutes" and repost the original images from here, if you are interested in any of my photos from the initial post, PM me and I'm happy to respond. Others probably feel the same way.
1984 Westy with tencentlife power!
djkeev
djkeev is offline
PostPosted: Tue Jul 25, 2017 11:02 am    Post subject: Re: Yet another design for an interior hatch release/latch Reply with quote
Contact Kam or I, we can help you out with posting new photos. It isn't the easiest task but well worth the effort for helpful "how to" threads.
Dave
Ghia
Vanagon
Beetle
The Carrot
The Carrot is offline
PostPosted: Tue Jan 08, 2019 2:07 pm    Post subject: Re: Yet another design for an interior hatch release/latch Reply with quote
Interior hatch release was on my winter to do list for the Carrot so I researched this thread plus a couple of others for ideas.
https://www.thesamba.com/vw/forum/viewtopic.php?t=677329
I wanted a simple way to pop the hatch from inside while camping so I came up with this:
The lever is from a 3/4” plumbing ball valve. It is attached directly to the release pin on the latch assembly via a heavy bent wire hook. The red part of the lever is parallel to the door card and about 3/8” clear of it.
I am going to add a threaded eye to the centre of the door to attach a lanyard for closing the hatch.
1990 Orly Blue Carat
The Carrot
PostPosted: Thu Jan 10, 2019 2:56 pm    Post subject: Re: Yet another design for an interior hatch release/latch Reply with quote
Here are a couple more images with the hatch panel hole cut and installed...
B.O.B.Wanders
B.O.B.Wanders is offline
PostPosted: Thu Jan 10, 2019 7:17 pm    Post subject: Re: Yet another design for an interior hatch release/latch Reply with quote
I like that idea!
83.5 WBX 2WD Assuan Brown Westy, B.O.B.
"It feels good to be lost in the right direction” - unknown
Page 3 of 3
