telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Thu Apr 16, 2009 4:12 pm Post subject: Flashing Side Markers |
Didn't see this in the archives, so decided to add a thread:
Seeing as how keeping other Bozos on the road from bending our difficult-to-replace Bay sheet metal because they're too busy with their cell phones to watch where they're going, is seems that anything we can do to increase our visibility is a Good Thing. Even though a Bay isn't all that small, it's amazing the number of times I hear (after a near-hit), "Sorry - I didn't see you."
While this modification isn't all that significant, it surely can't hurt: make the rear side marker lights flash with the turn signals.
This is an easy 30 minute change involving no modifications to the stock wiring harness (also a Good Thing.)
Here's how I did it on my '71 type 21:
1) Inspect the stock wiring going to the side marker lights. You should have a brown (ground) wire and a brown with stripe (tail light circuit) wire. On my bus, they're both terminated in 0.110 blade terminals.
2) Inspect the other end of the wire harness at the tail light. You should see the brown ground wire going to the terminal which grounds the case of the tail light, and the brown with stripe wire going to the tail lamp terminal on the tail light assembly. Each of these wires is crimped in with a second wire in their respective 0.250 terminals.
There is a third single wire going to the tail lamp assembly. This is the turn signal wire. Make a note of its location.
3) Procure the following parts:
- 2 0.110 female blade terminals, either bare or with red insulation.
- 2 0.250 female blade terminals, bare or red insulation.
- 2 0.250 female to double male adapters.
- 3 ft. of #16 wire (anything other than brown.)
- heat shrink tubing as needed.
- small wire ties, as needed.
You can also use 0.250 female terminals that have a male expander terminal in place of the female 0.250 terminals and adapters, if you can find them. While not all that common, some FLAPS stock them.
Buy good quality terminals ("Buy the best and cry once" - Gene Berg).
4) Unplug the turn signal wire from the tail light assembly. Install one of the adapters in its place; reconnect the turn signal wire to one of the available adapter terminals.
5) Make up a length of wire with a 0.250 terminal on one end and a 0.110 terminal on the other, long enough to go from the tail lamp assembly to the side marker, with a little extra for dress. Use a proper crimping tool or solder. Insulate with heat shrink, if using bare terminals.
6) Connect the 0.250 terminal of the made-up wire to the remaining adapter terminal from step #4.
7) Remove the brown ground wire from the side marker light and secure out of the way, so that it can't short out anything later. Insulate with heat shrink if it's a bare terminal.
8] Connect the 0.110 terminal end of the added wire to the now open side marker terminal.
9) Repeat all of the above for the other side marker.
What we're doing:
Normally the side marker is fed by power from the tail lamp circuit and returns to ground, thus lighting when the tail lights are on. We are removing the ground wire and feeding the return current into the turn signal circuit. Because the side marker is such a small bulb, its current flow is insignificant compared to the other lamps, thus it can 'ground' itself through the unlit turn signal bulbs. If the turn signal circuit is active and the tail lights are off, then it grounds the other way through the unlit tail lights, thus flashing along with the turn signals. If both circuits are active, then the side marker will flash alternately with the turn signals (lighting when the turn signal is off).
FWIW
TD
1977_L63H_P27 Samba Member
Joined: January 17, 2006 Posts: 2345 Location: Bristol, Tennessee
Posted: Thu Apr 16, 2009 4:53 pm Post subject: |
Thank you for this "how to". I've been considering this mod for a while. Of course, I've also been thinking about modding the front reflectors into actual side markers. I know that either of the front turn signal assemblies makes concession for a side marker. But I feel that one on the true side of the bus would make it more visible. Peace! _________________
busdaddy wrote: |
...and try a few chubby ones until you find one you like.
1977 Westfalia P27
you can't spell Volkswagen without SWAG
M-code Plate
Full Moon Bus Club
Last edited by 1977_L63H_P27 on Wed May 06, 2009 10:16 am; edited 1 time in total |
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3040 Location: Portland, Oregon
Posted: Thu Apr 16, 2009 6:12 pm Post subject: |
Good idea. I did the same thing to the front side markers on my Jetta. Hmmm...now we need the front side markers to be illuminated and blink. Wonder why they had the rears illuminated but not the front
Can you post a wiring diagram? _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
enjoispammy8 Samba Member
Joined: December 26, 2007 Posts: 1984 Location: Long Beach, CA
Posted: Thu Apr 16, 2009 6:26 pm Post subject: |
theyr supposed to light up?! _________________ 1969 Westy, 1690cc. montana red and cloud white.
1969 Standard Beetle [sold]
Watch My Movies: https://www.youtube.com/user/taylorlikesacdc
Desertbusman wrote: |
Is there a message here? Enjoy Spammy Ate |
EZ Gruv wrote: |
Way to fuck up some little kids riding in the car next to you. |
hazetguy wrote: |
you need to be doing better drugs. |
calebmelvin Samba Member
Joined: July 19, 2006 Posts: 3140 Location: Seattle, WA
Posted: Thu Apr 16, 2009 6:35 pm Post subject: |
enjoispammy8 wrote: |
theyr supposed to light up?! |
On the later ones they do, early buses just have reflectors...
Edit: looked it up because I was curious when it started. When they went to square reflectors in '70 a bulb was added. I knew there was a reason I liked the '68-69 buses the best _________________ Caleb
'68 Tagged Manx | My Wanted Ads
Posted: Thu Apr 16, 2009 7:23 pm Post subject: |
calebmelvin wrote: |
Edit: looked it up because I was curious when it started. When they went to square reflectors in '70 a bulb was added. I knew there was a reason I liked the '68-69 buses the best |
whew, thats a relief. im missing mine, and this thread got me wondering if i was missing all the wirering too! thank god all ill have to do is by reflectors, no micky mouse wirering for me! _________________ 1969 Westy, 1690cc. montana red and cloud white.
EZ Gruv wrote: |
hazetguy wrote: |
dwill49965 Samba Member
Joined: August 08, 2005 Posts: 1396 Location: Dartmouth, Nova Scotia
Posted: Tue May 05, 2009 2:43 pm Post subject: |
Its been done.
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...highlight= _________________ Darryl
'78 Westy, Boston Bob built 2.0 L, FI, MSD 6A
Meyer wrote: |
Lastly, you just referred to US citizens as 'Americans'. Exactly what kind of Canadian are you? From what continent? |
Brown_Bus Samba Member
Joined: December 14, 2007 Posts: 319 Location: Roanoke, VA
Posted: Wed May 06, 2009 6:06 am Post subject: |
Thanks for this telford . I am replacing my houising and seals for my tail lighst soon. I will add this process in.
Not sure if I want to do the front reflectors. Not comfortable cutting the doors. But regardless thanks for that tutorial dwill.
I wonder if a smaller light, such as an led could be used on the front reflecters, allowing for a smaller hole...? _________________ '76 L20A marino yellow Westy |
Posted: Wed May 06, 2009 8:59 am Post subject: |
Quote: |
I wonder if a smaller light, such as an led could be used on the front reflectors, allowing for a smaller hole...? |
Possibly.
Electrically, no problem, although you would have to add a full-wave diode bridge, so that the LED would light up regardless of polarity.
Some LEDs have a narrow angle of light output, so they may not light up the lens the same as a light bulb. I would recommend bench development before cutting any holes... |
VWDruid Samba Member
Joined: June 14, 2008 Posts: 1192 Location: Boca de Ratones FL
Posted: Wed May 06, 2009 9:39 am Post subject: |
I did some thing close to the led side markers, what I did was make independent blinkers.
I ran wires direct from the front blinkers with a inline resistor. _________________ 70 Westy, 2027cc "dual DRLA 40 m140 i55 wjdoc a165 p33 v30 "w100 straight cut 040 polished heads 1.25 rockers 1.5 A1sidewinder supertrapp muffler trans 091 coil SUM-850500 CDI universal svda Pertronix
http://www.storyofstuff.com/
It's not the straight cut gears It's the T.A.R.D.I.S. engine.
wanted Chameleon Circuit |
Vwman55 Samba Member
Joined: August 11, 2005 Posts: 550 Location: Valparaiso, IN
Posted: Thu May 07, 2009 8:26 am Post subject: |
What Stern suggests will work, but it puts the 2 bulbs in series. They will be dimmer and always on, parking lights on = side marker and turn signal filamet on, flasher on(parking off) = side marker and parking light on and parking light on, flasher on = side marker and turn signal on. |
