garrison Samba Member
Posted: Tue Apr 21, 2009 2:02 pm Post subject: Laptop Mount |
Hi folks,
I'm planning to mount a small laptop (eeePC 901) in my Westy to use for navigation and entertainment. Anyone have experience with the RAM laptop mount in a Vanagon ? Looks like a robust device but not sure if the installation works out well for rotating seats. |
pighamling Samba Member
Joined: November 30, 2007 Posts: 67 Location: Southern NM
82WestyMan Samba Member
Joined: December 28, 2006 Posts: 1098 Location: Western OR
Posted: Tue Apr 21, 2009 2:51 pm Post subject: |
you mean this?
http://www.ram-mount.com/CatalogResults/PartDetail...fault.aspx _________________ "The floggings will continue until morale improves"
"I never did give anybody hell. I just told the truth and they thought it was hell" - Harry S. Truman
82 Westfalia - w/ a Raby 'Camper Special' engine |
airkooledchris Samba Member
Posted: Tue Apr 21, 2009 3:07 pm Post subject: |
I haven't tried this, yet, but ive had it on my list of stuff to buy for about a year now:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350102890922
It will only work if your laptop is on the small-ish side, but if your thinking about mounting it in your van, it probably is already.
best of all, its about $30 shipped.
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Tue Apr 21, 2009 3:51 pm Post subject: |
This is the one I was looking at for my "vanputer".
It's made by Ram, should work fine, but I'm not sure I really need a mount.
I would mount it for my wife on the passenger side, but I'm not sure it just won't cluter up the dash even more. |
Nytebus Samba Member
Joined: April 11, 2009 Posts: 1 Location: Staunton, VA
Posted: Wed Apr 22, 2009 5:00 pm Post subject: Platform size |
airkooledchris wrote: |
How big is the platform? Would it hold a MacBook? Have you mounted this? It looks like an incredibly reasonable solution for videos. |
hiram6 Samba Member
Joined: September 29, 2006 Posts: 1880 Location: Beautiful South
Posted: Wed Apr 22, 2009 5:52 pm Post subject: |
I had this, wasn't impressed. It's basically made up of a few sections of steel pipe like you can buy at Home Depot, a few elbows and 15 degree elbows so you can mix and match to get the platform to the right angle. All thepiping is covered by a plastic corrugated hose to give it a finished look. The only piece you couldn't buy yourself for less than $10 total is the acrylic piece the laptop sits on.
My complaints? Never could get it to just the right angle, had to break out the pipe wrenches to tighten or adjust, after a while the joints would loosen from the vibrations of the van going down the road. And then the acrylic piece broke, and I was left with spare plumbing parts. The seller will sell the acrylic piece by itself as a spare part, but by that time I no longer cared to keep the mount, so I went in a different direction, I'll try to post a pic tomorrow. _________________ 1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning. |
vwjedi Samba Member
Joined: November 29, 2005 Posts: 1463 Location: G-ville, FL - hopefully on a trail.
Posted: Wed Apr 22, 2009 6:02 pm Post subject: |
If i'm not mistaken that first piece of wood screwed to the dash looks like a piece of wood screwed to your dash?
The "Ram" mount looks cool, remove when parked. _________________ 1987 Wolfsburg T25 still riding out. A bunch of other VW's passed on... |
westynova Samba Member
Joined: December 14, 2008 Posts: 209 Location: Nova Scotia, Canada
Posted: Wed Apr 22, 2009 6:09 pm Post subject: |
The Vanagon Accessories Dash mount actually uses a block that fits into the ashtray slot and a bolt clamp arrangements so there is no damage to the dash.
I thought it was a great idea. The only issue is that it does not protect against shock. I am trying to come up with a modification. I am thinking of changing the 3/4" plywood into 2 pieces of 3 or 5 ply Marine 1/8" thick plywood separated by some small rubber mounts.
It is one of many little projects that I still have to do. I have a shopping list to get done to pass Safety and I only have 2 weeks left before a planned trip, so the mount is going to have to wait.
I am working on upgrading the Front Turn Signal Sockets to something modern. _________________ 84 Westy
2010 VW Golf TDI Wagon
2009 Jeep Rubicon Unlimited, Lifted and Locked |
Posted: Wed Apr 22, 2009 8:52 pm Post subject: |
Thank-you all for the great ideas ! Some thoughtful solutions have been found to tackle this problem.
I like the RAM seat-bolt mount. Looks quite solid. It is the costlier solution though. |
