Sigurd Samba Member
Joined: April 18, 2006 Posts: 2639 Location: Rockford, IL
Posted: Sun Apr 19, 2009 9:48 pm Post subject: Quick endplay question (video content) |
Does this look ok? It looks like 0.003", but if I push and pull the flywheel harder, it will extend to about 0.005". I didn't think I was losing my mind. This is correct isn't it?
This is a new case, new flywheel std/std crank and std thrust. No o-ring. Distributor and pinion are in place; pulley is not. 370 ft. lbs. on new chromoly glandnut -- tightened with torque multiplier and my homemade welded 38mm adapter thingy. Dial indicator is on the flywheel with the plunger on the case with the flywheel lock in place. Is that enough details?
perrib Samba Member
Joined: September 14, 2004 Posts: 3402 Location: Chandler, Az
Posted: Sun Apr 19, 2009 10:13 pm Post subject: |
Great detail. One of the thrust washers may be bowed a bit. |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Mon Apr 20, 2009 3:44 am Post subject: |
Looks fine to me, shimstack is probably just compressing a little more. I wouldn't worry about it. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Sigurd Samba Member
Posted: Mon Apr 20, 2009 5:47 am Post subject: |
Ok sounds good. I should add that the shims are new. Will they wear in a bit? |
The Noof Samba Member
Posted: Mon Apr 20, 2009 5:55 am Post subject: |
Depending on how hard your pushing/pulling,you might be seeing a little flywheel deflection too.If you're not sure,go for .004" with thumb effort,on new shims:the minimum clearance is a critical value. |
Sigurd Samba Member
Posted: Mon Apr 20, 2009 6:24 am Post subject: |
I'd say I'm pushing kind of hard to get that extra deflection. If I grab the flywheel right where I have the mic, yeah, it moves way more than 0.005". If I just push and pull normally, I've got 0.003". The plunger is at 12 o'clock and my hands are at 3 and 9. Does that make sense? |
Posted: Mon Apr 20, 2009 6:50 am Post subject: |
Yes, it does.Flywheel deflection can be confused with warped shims easily enough.I say an "honest" .003 is fine. |
perrib Samba Member
Posted: Mon Apr 20, 2009 7:56 am Post subject: |
Get a helper and have them push on the front of the crank. |
Sigurd Samba Member
Posted: Mon Apr 20, 2009 10:48 am Post subject: |
perrib wrote: |
I may try that tonight. Thanks guys, I think I'm going to run it. |
