dave123 Samba Member
Joined: July 29, 2006 Posts: 174 Location: Perth, Western Australia
Posted: Wed Apr 22, 2009 7:29 am Post subject: |
I phoned up PPG over here in Aus and it blew there minds as well! Gave them the 2 different ppg/ditzler codes but they only have 1 recipe/formula (under code L360) so i guess i'll just get what i get and be happy |
AlteWagen Troll
Posted: Wed Apr 22, 2009 11:49 am Post subject: |
KWZ wrote: |
I think that only the "Sea Blue 1" appeared on busses. I have never, ever seen a difference on the busses, and I have owned eight different original paint sea blue '65-'67 busses over the years. |
My 1960 euro Type I is sea blue #1 and down the street there is an original paint 1961 sunroof Type I with the sea blue #1 as well. I have only seen sea blue #2 on 65 and later type I. I have never seen a sea blue #2 bus until that picture of the first bus. Good paint job but doesnt look right to me.
dave123 wrote: |
Have them do the test films first. The difference is huge as stated earlier. I personally like sea blue #1 best, the color of the inside of the glove box and the back of the ashtray cover is beautiful!! It seems there were a ton of sea blue #2 cars and they look ok but having a sea blue #1 car really stands out!
Its cool to argue with sea blue nuts too since the one most know about is #2. |
AlteWagen Troll
Posted: Wed Apr 22, 2009 12:35 pm Post subject: |
Just finished reading the other sea blue posts, I was confused by the remarks regarding the #1 looking darker and greener and #2 looking more blue. I took my chip sheet out in the sun to take a closer look. The #1 looks darker and more blue, the #2 looks lighter and has more of a turq shade to it.
I think the info on the back of the chip sheet gives a clue to what got what.
On the back my chip sheet it shows years that specific colors were available.
Sea Blue L360 1960-1966
Sea Blue 2 L360 1963-1967
I think early type Is, ghia, and busses got #1. In 63 type I, ghia and Type III got #2. Busses continued to get #1 til 66.
Here is the back side of the chip sheet online
Its a bit more confusing, it shows SB#1 for 60-61 and SB#2 for 64-65. I have seen 66 type I in SB#2 so maybe this is an early sheet.
I think both of these sheets help confirm the #2 greener version was used on later type I and III. SB#2 on type IIs is still up in the air.
Anyone have an original paint 1967 Type II with sea blue #2?? Pics?
One more thing to consider for type I, Gulf Blue L390 was also listed for 1960-1964. It is very close to SB#2 but has more of a gray color instead of the green hue. I owned a euro 62 type I that was gulf blue and a export 63 that was also gulf blue, both original paint. People tried to tell me that it was sea blue but when parked next to a SB#2 car it was different. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Doubledoor Dave Samba Member
Joined: February 14, 2008 Posts: 98 Location: York, Maine
Posted: Wed Apr 22, 2009 1:46 pm Post subject: |
Here's my 1965, euro, Sea Blue/Blue White, original paint bus. I guess this is what is being called "Sea blue #2". It does seem to change a lot with different lighting.
Posted: Wed Apr 22, 2009 4:17 pm Post subject: |
Feck me i'm confused now |
AlteWagen Troll
Posted: Wed Apr 22, 2009 8:53 pm Post subject: |
The repainted 61 does NOT look like SB#1. The 65 bus looks more like SB#1 but the owner says it is #2.
Here is a pic of the last bit of SB1 on my glove box door. Funny, with the flash it looks greener than when in the sun where it looks more dark blue.
In the sun it looks more like the dark blue closer to the white moulding clip button. I took a longer exposure due it being night. Tomorrow I will try to take a pic using sun only. |
Posted: Thu Apr 23, 2009 5:59 pm Post subject: |
derluftwagen wrote: |
Have them do the test films first. The difference is huge as stated earlier. I personally like sea blue #1 best, the color of the inside of the glove box and the back of the ashtray cover is beautiful!! It seems there were a ton of sea blue #2 cars and they look ok but having a sea blue #1 car really stands out! |
Just returning to this - that seems to be the problem... even PPG in Australia only seem to have one formula... i dont know which one it is!
It seems like Sea Blue 1 is the code that i'm after though - more blue than green, and correct for buses, so at least we got that sorted out...
Maybe i need to find a kind soul to send me a gas flap or something in original Sea Blue 1 paint? |
krautwaggen Samba Member
Posted: Thu Apr 23, 2009 8:53 pm Post subject: |
Comparing paint via digital photos on a computer screen is less than effective. It'll look different on every screen out there. Then you have the light during the time the photo was taken and how the particular camera processed it compared to another camera. Only if you have the two colors in question in the same photo (like on one of those paint sheets in an earlier post) will you be able to compare two colors, although they will still not be a true representation of the actual colorl _________________ Half Bus, Half Truck, What the _______? |
W1K1 Samba Member
Posted: Thu Apr 23, 2009 9:02 pm Post subject: |
Quote: |
The repainted 61 does NOT look like SB#1. The 65 bus looks more like SB#1 but the owner says it is #2. |
Mine is PPG 12333 sea blue L360
The easiest thing would be to get them to mix you a spray can of both and spray it on something and see if you like it.
This is stock sea blue inside the tail light housing.
When you hold it next to the car it's the same color, it just depends on the light
_________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Fri Apr 24, 2009 7:06 pm Post subject: |
Here's some sea blue #1 from paint chips I have, photo taken in cloudy sky, all from the same angle and spot.
First is Ditzler, second is DuPont, and third is off a '65 bus gas door.
AlteWagen Troll
Posted: Fri Apr 24, 2009 10:25 pm Post subject: |
do any of the bus guys have a color sticker? Some stock red bus colors have had hybrid or abbreviated color codes, sea blue the same? M codes??
any of the bug guys have a birth certificate??
as for the bus cover, I vote SB1 |
AlteWagen Troll
Posted: Sat Apr 25, 2009 2:29 pm Post subject: |
This has been keeping me up at night now.
This is what I think so far, if someone has a vehicle with something else (in original paint) please post a pic, birth cert, or some other documentation.
Type I
1964-1967 Sea Blue #2
Type II
1965-1966 Sea Blue #1
edit: Saw a 1967 in person with og paint and it def was SB#1.
Looks like SB#1 is for Type II and SB#2 is for Type I.
Only Indigo Blue is avail for 1960
Only Gulf Blue avail for 1961-1963. _________________ Grapes of Wrath $200 Engine Rebuild
Official Dual Carb Thread
Posted: Sun Apr 26, 2009 8:06 pm Post subject: |
Do those paint code numbers (L391, L397) relate to the sea blue as well?
Easily the clearest indication of the difference between these two colours so far - Thanks! |
Posted: Sun Apr 26, 2009 8:40 pm Post subject: |
Going back to my original post, i would say that my test panel is Sea Blue no. 2...?
BarryL Samba Member
Posted: Mon Apr 27, 2009 8:21 am Post subject: |
dave123 wrote: |
Do those paint code numbers (L391, L397) relate to the sea blue as well? |
Sorry about that crop job. The top blue is 360 and the bottom is 361. The 391 is Pastel Blue and the 397 is Lavender in the adjacent column. Personally, I was alive during the Sea Blue and I only remember the #1 on busses. |
Posted: Mon Apr 27, 2009 3:55 pm Post subject: |
this sheet shows L361 as Slate Blue...
AlteWagen Troll
.65vw Samba Member
Joined: August 06, 2008 Posts: 122 Location: Washington - East of Seattle
Posted: Sat May 02, 2009 10:03 am Post subject: 2 - 65 Sea Blue Bugs. One original, one new |
This drove me crazy trying to figure out a few months back. #1 is for the Bug per previous posts, #2 for the Bus.
I have a one owner 65 Bug and its the original Seablue color from the factory.
I am restoring a 65 VW and had it painted the L360 Seablue (its original color too. It had been repainted an off green from original). When it was newly painted the color didnt match my original Bug. Kind of makes you queazy.
In some pictures I have in certian light the colors between the two bugs is exact, in other pictures and light the colors are off.
I concluded that time and color changes, lighting angles, and as mentioned variations in the mixing all can make the Sea Blue color seem off between VW's. For an exact match take in an existing part.
Here is a link to the 2 65 Bugs with SeaBlue paint. The one with the plates, Bug 1, is the original factory Sea Blue, the other, Bug 2, is the newly L360 painted one.
http://picasaweb.google.com/pbjensen/Bug2April2009CleaningTheDustOff#
BTW, L466 new does not at all match L466 faded. Faded L466 is very white and not at all beige. Color matching is a pain. |
Posted: Sun May 03, 2009 2:29 am Post subject: Re: 2 - 65 Sea Blue Bugs. One original, one new |
sneazel wrote: |
#1 is for the Bug per previous posts, #2 for the Bus. |
Looks like SB#1 is for Type II and SB#2 is for Type I. |
OK, one of you is wrong!!
Thanks for the info though.... and looking at your pic here i'd say the beetle on the left is the least like either Sea Blues of any vehicle here!
AAaaaaaaaaahhhhhhhh!!!! |
