Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Fri Oct 19, 2018 7:11 pm Post subject: Re: Correct Dip Switch Settings VDO Tachometer |
telford dorr wrote: |
IIRC, stock type 1 engines redline at 4600; type IV at (around) 5500 (shorter stroke). Thus, 6000 limit at the tach should be fine. |
Cool. Then I doubt I have to worry. My bus is a T1, so I should be fine.
I'll post a pic of my build.
Did you ever put yours in an enclosure? _________________ ~Kevin
My 1968 Campmobile |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3547 Location: San Diego (Encinitas)
Posted: Sat Oct 20, 2018 8:55 am Post subject: Re: Correct Dip Switch Settings VDO Tachometer |
No, I never did (being the lazy butt that I am). But it seems happy to just hang out where it is. (I did put a plastic bag over it, to keep it dry.)
I really should put it in a box... _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Sat Nov 10, 2018 11:21 pm Post subject: Re: Correct Dip Switch Settings VDO Tachometer |
Hi Telford
Thanks again for sharing your schematic.
I have my parts, and am getting ready to build the buffer circuit.
I'm pretty sure I know the answer, but wanted to clarify one detail.
Pin 5 and 7 on the IC are being ignored, right? _________________ ~Kevin
Posted: Sun Nov 11, 2018 9:01 am Post subject: Re: Correct Dip Switch Settings VDO Tachometer |
Correct. The 555 is just being used as a schmitt trigger buffer, not as a timer. _________________ '71 panel, now with FI
hethen57 Samba Member
Joined: April 02, 2005 Posts: 283 Location: San Luis Obispo, CA
Posted: Fri May 15, 2020 5:34 pm Post subject: Re: Correct Dip Switch Settings VDO Tachometer |
Once again, thanks for posting this info. My VDO tach hasn't registered the correct RPMS since I installed it many years ago according to the instructions. Good thing I rely on sound, not the tach, but I knew it shouldn't be wound at 2500 rpms . Now it finally works correctly! _________________ 69 Baja Bug
77 Bus |
