poptop tom Samba Member
Joined: July 27, 2004 Posts: 1607 Location: The Hoosier State
Posted: Thu Apr 23, 2009 7:27 am Post subject: proper vapor line routing |
I'm trying to figure out how this particular vapor line was routed. Most of the ones I've seen have a straight steel line where my hand is holding my line, and there is a tee running to the right side, and to the canister.
A pic of the correct routing would be great!
_________________ '76 Deluxe Campmobile |
Traveling Writer Samba Scribe
Joined: May 07, 2006 Posts: 1112 Location: Florence, Italy
Posted: Thu Apr 23, 2009 7:47 am Post subject: |
If the hose you're holding is the one that goes back to the charcoal canister from the T near the very back top of the engine bay (the other two lines are steel and go left and right from the T and up into those condenser thingies in the air scoops), then mine is clear tubing, NOT steel, and runs from the T up sort of between the hot air fan and the metal roof it is bolted through, back to the charcoal canister. The fan mounting is a flattened horseshoe shape which leaves just enough room to batten it down without pinching a hose going through there...don't know if it is the way it's "done", but it's the way it was done on mine! _________________ Cheers,
Davi
1977 2.0 FI Westy
2011 1200cc Yamaha Super Tenere
1976 Feet (they work surprisingly well) |
EZ Gruv King of Plaid
Joined: December 10, 2002 Posts: 8544 Location: Las Vegas
Posted: Thu Apr 23, 2009 8:13 am Post subject: |
Look by the heat booster fan.
The vent line comes in from the left, another form the right. They meet at a T fitting, ultimately routed to the charcoal canister. _________________ Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page. |
Posted: Thu Apr 23, 2009 4:07 pm Post subject: |
Thanks Eric and all. Eric, is that a steel line going back to the canister, or a yellow plastic one?
I figured that's how it was done, but wanted to be certain! _________________ '76 Deluxe Campmobile |
Posted: Thu Apr 23, 2009 5:20 pm Post subject: |
It is a clearish yellow plastic from the T to the canister. _________________ Eric
jamesdagg Samba Member
Joined: August 18, 2007 Posts: 3364 Location: B.C.Canada
Posted: Fri Apr 24, 2009 3:30 am Post subject: |
Seen this on ratwell's site?
jim _________________ '72 FI Westy
'71 Super rear inside defrost vents no longer available |
Posted: Fri Apr 24, 2009 3:46 am Post subject: |
Thanks Jim, I have. In fact I used that kit from German Supply.
The diagram just isn't detailed enough. I believe I have it figured out now - thanks for the help everyone! _________________ '76 Deluxe Campmobile |
thewalrus Big Jack
Joined: March 27, 2006 Posts: 3014 Location: Belchertown, MA
Posted: Fri Apr 24, 2009 5:42 am Post subject: Re: proper vapor line routing |
Is THAT what that bracket on my fire wall is for?! The Charcoal Canister huh? My engine was converted to Single carb long ago (Not by me!) and I'm STILL figureing out what all the leftover odds and ends are. _________________ '73 Transporter 1.7L Dual Carb
notchboy wrote: |
You ran over some #Vanlife'ers hopes and dreams? |
60vwnewengland wrote: |
Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards! |
germansupplyscott Samba Member
Posted: Fri Apr 24, 2009 6:07 am Post subject: |
poptop tom wrote: |
The diagram just isn't detailed enough. |
everything in the front part of the diagram is fine but the rear part is weird on that diagram. i have never seen a bus that looks like that diagram in the rearward parts. one of these days i'll find time to do some diagrams like our fuel hose kit ones, of the various years of vapour recovery hoses. _________________ SL |
Posted: Fri Apr 24, 2009 7:30 am Post subject: |
Agreed Scott. I have no doubt you'll sort out some nice new diagrams like you did with the fuel injection kit! Keep up the great work!
I'll be in touch at the beginning of the week!
Tom[/quote] _________________ '76 Deluxe Campmobile |
Posted: Fri Apr 24, 2009 7:39 am Post subject: |
germansupplyscott wrote: |
poptop tom wrote: |
everything in the front part of the diagram is fine but the rear part is weird on that diagram. i have never seen a bus that looks like that diagram in the rearward parts. one of these days i'll find time to do some diagrams like our fuel hose kit ones, of the various years of vapour recovery hoses. |
If you're fixing the vapor line diagram, the asymmetrical blue 24 to the right of the red 24 is the mirror image of how it actually is (at least in my bus, but I think looking at the way it fits in there, on all buses, at least 77s). _________________ Cheers,
Davi
1977 2.0 FI Westy
