iradi Samba Member
Joined: August 24, 2007 Posts: 211 Location: Miami, Fla
Posted: Thu Apr 23, 2009 12:56 pm Post subject: Distributor Vacuum Advance Inspection |
A friend of main gave me a original german bosch distributor vacuum advance # 643 905 205 .
I have a KG 74 with the original engine ( Solex 34PIC3 ) and I want to replace the existing centrifugal advance 009 distributor.
How can I check if is working properly ?
I put new cap, new rotor and new points, what other parts do I need to change ?
Thanks in advance |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4536 Location: Arizona Highways
Posted: Fri Apr 24, 2009 10:27 pm Post subject: Re: Distributor Vacuum Advance Inspection |
iradi wrote: |
Thanks in advance |
Beetle 1971 * 1600 Manual Trans
Distributor: VW 113-905-205AJ, Bosch 0231 167 049 > 043-905-205C, 0231 176 028
Can Use: VW 113-905-205AN, Bosch 0231 167 070 or 043-905-205C, 0231 176 028
Points Replacement Plate Assy: 1237 110 064
Condensor: 02 054
Rotor: 04 033
Cap: 03 010
Coil: 00 015 (Blue Coil: 00 012)
Vacuum Can: 07 223
Ignition Wires: 09 001
Spark Plug: W8AC
Timing Set At:: 5deg ATDC @ 800-950rpm w/strobe, vacuum hose(s) connected.
Advance/Retard Range: Vacuum: 9-12deg Adv, 11-13deg Ret; Centrifugal: 6-12deg @ 1500rpm, 22-25deg @ 3800rpm
according to your # this is a DVDA distributor and should work well with your 1600. you can run it with the retard side hooked up or not. the advance side should move and hold the point plate just a little bit and the retard side should move and hold the point plate considerably more. the retarded idle timing (pun intended) was just an emissions thing. i'd time it to 30deg total w/o the advance hooked up and see where your idle timing falls to. check total w/ adv hose hooked up @ 35-40deg BTDC & adjust if needed. i use this same unit on my '71 autostick. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
iradi Samba Member
Posted: Mon Apr 27, 2009 7:21 am Post subject: |
Thanks Borninabus, can you please tell me how can I check if it is in good condition before I install the distributor in the car ?
I use my Guia as a daily driver and I do not want get stuck in the middle of the I-95. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Posted: Mon Apr 27, 2009 8:48 am Post subject: |
Put a hose on it and suck. You should see the points plate move.
Or you can use one of these:
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Apr 28, 2009 8:24 am Post subject: Re: Distributor Vacuum Advance Inspection |
Glenn wrote: |
Put a hose on it and suck. |
borninabus wrote: |
the advance side should move and hold the point plate just a little bit and the retard side should move and hold the point plate considerably more. |
the advance side being the small port that is usually angled downward. the retard side being the big port that points toward the FRONT on the car.
does the shaft spin freely--howz the UP & down play? _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
iradi Samba Member
Posted: Wed Jun 24, 2009 8:46 am Post subject: Re: Distributor Vacuum Advance Inspection |
Quote: |
according to your # this is a DVDA distributor and should work well with your 1600. you can run it with the retard side hooked up or not. the advance side should move and hold the point plate just a little bit and the retard side should move and hold the point plate considerably more. the retarded idle timing (pun intended) was just an emissions thing. i'd time it to 30deg total w/o the advance hooked up and see where your idle timing falls to. check total w/ adv hose hooked up @ 35-40deg BTDC & adjust if needed. i use this same unit on my '71 autostick. |
I only notice one fitting, is this a DVDA o SVDA ?
Where are the other fitting ?
Enclosed please find the pictures and how I connect to the carb
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Wed Jun 24, 2009 10:08 am Post subject: |
I think the number you orginally posted was mis interpreted and you actually have an 043 905 205 / 0231 170 034
Which is what it looks like is correct. A 74 model SVDA and not a DVDA style can. You have the vac hose connected correctly so... time it right and you should be fine. |
iradi Samba Member
Posted: Wed Jun 24, 2009 11:23 am Post subject: |
All right, thanks. I would do the set up this afternoon after return from Work. |
