Axle Nuts
P7rns
P7rns is offline
PostPosted: Sat Apr 25, 2009 9:57 am    Post subject: Axle Nuts Reply with quote
Can Anybody tell me whats the best way to remove axle nuts on 64 buses, and what size socket fits ?
Thanks
Andrew
Andrew is offline
PostPosted: Sat Apr 25, 2009 10:21 am    Post subject: Reply with quote
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-7036
If you have big nut reduction boxes, though, you will have to make an adapter to change from 36mm to 46mm, but pictures of how to make one can be found here in the forums by searching. Otherwise, these things work awesome.
-Andrew
AlteWagen
Troll
AlteWagen is offline
PostPosted: Sat Apr 25, 2009 11:27 am    Post subject: Reply with quote
my problem was not removing the nut but getting the drum off. It had never been off so 40+ years stuck. It took 7 hours 4 bottles of propane and a BFH to finally persuade it loose.
Official Dual Carb Thread
bugcollections
bugcollections is offline
PostPosted: Sat Apr 25, 2009 3:33 pm    Post subject: Axle nuts Reply with quote
46 mm socket and a very good air wrench after soaking with something such as PB blaster.
ach60 Premium Member
ach60 is offline
PostPosted: Sat Apr 25, 2009 3:45 pm    Post subject: Reply with quote
My choice because everybody has a BFH and $10:
https://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-7045
This tool has been designed to remove the rear axle nut for brake inspection and service. The removal of this sometimes frozen nut is accomplished with a force greater than that of an impact wrench. To use- simply remove the cotter pin holding the axle nut on and place the tool over the nut. Insert a standard 1/2 inch breaker bar or ratchet- applying arm pressure- then strike the tool with a hammer knocking the nut loose. Fits Bus 64-79 & Vanagon 82-92
Good Luck
Al
View user's profile Send private message Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
Andrew
Andrew is offline
PostPosted: Sat Apr 25, 2009 5:29 pm    Post subject: Reply with quote
I have one of these as well, but I was always nervous swinging the BFH with any sort of force so close to the body of my bus, though.
-Andrew
JoelH
JoelH is offline
PostPosted: Sat Apr 25, 2009 11:04 pm    Post subject: Re: Axle nuts Reply with quote
heat it up super hot, then hit it with PB Blaster....lather, rinse, and repeat......know what I mean? works wonders!
Joel
RED RIVER VW CLUB---www.redrivervwclub.com
WIDEFIVE.NET
'60 DD SWR Panel
http://www.thesamba.com/vw/forum/viewtopic.php?p=2522353#2522353
'62 Gulf Blue Ragtop Bug
http://www.thesamba.com/vw/forum/viewtopic.php?t=420720&highlight=
'60 Black RHD Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?p=6478591#6478591
1965 Sea Sand L568 Notchback
http://www.thesamba.com/vw/forum/viewtopic.php?p=8307805#8307805
daniel5560
daniel5560 is offline
PostPosted: Sun Apr 26, 2009 4:56 am    Post subject: Reply with quote
Use either the tool mentioned above that you hit with a hammer or get a one of those big giant 1" impact guns. Ive used both and never failed to get an axle nut off.
P7rns
P7rns is offline
PostPosted: Sun Apr 26, 2009 6:25 am    Post subject: Reply with quote
what is PB Blaster and where do I get it ?
Andrew
Andrew is offline
PostPosted: Sun Apr 26, 2009 6:45 am    Post subject: Reply with quote
http://www.pbblaster.com/
Being in England, you may not have access to it like we do here. You can get it just about anywhere on this side of the ocean.
-Andrew
P7rns
P7rns is offline
PostPosted: Thu Apr 30, 2009 9:34 am    Post subject: Reply with quote
I dont know if its the same stuff as your PB Blaster, but I sprayed what we Brits call WD40 onto the axle nuts and with a bit of persuation and jumping up and down on the bar the nuts came loose !!!
DownRiver
DownRiver is offline
PostPosted: Thu Apr 30, 2009 9:40 am    Post subject: Reply with quote
We have WD-40 here as well.
PB blaster is a penetrant. WD-40 is a lubricant.
Both will work, but the PB Blaster, Kroil or similar will work a ton better.
Whether you think you can or think you can't, you're right. -Henry Ford
VanSlyke VW Doublecab
Clara Premium Member
Clara is offline
PostPosted: Thu Apr 30, 2009 9:52 am    Post subject: Reply with quote
Pull ebrake hard.
If your ebrake doesn't work, chock the wheels so the bus doesn't roll. (Fix your ebrake whether it is an adjustment issue of the brake shoes or broken cable or whatever.)
Remove cotter pin.
Use 46mm socket on 3/4" slide bar.
Often I need the 5 foot cheater pipe on the slide bar.
Place pipe a bit up from horizontal and stand on it. I hold the drip rail for balance.
You really shouldn't need heat etc. In fact, if the axle nut is torqued to 250 ft lbs (which is should be), you can just stand on the slide bar and not need the cheater pipe. Do not use the cheater pipe when installing the nut. grease the splines so the drums doesn't rust in place, and the threads to the nut, and to torque it stand 1 foot out if you weigh 250 lbs, or further out if you weigh less (do the math). 2 feet out if you weight 125 lbs. In between if you weigh in between.
Then see if the cotter pin holes line up... bounce on the bar till the cotter pin holes line up and don't forget to put that cotter pin in.
Torque on the nut is something like 217 to 250 ft lbs.
The whacker tools can be useful, but I worry that it could be bad for the bearings. So I prefer the socket.
If the drum doesn't come off, there are threads for stuck drum issues. It is a not uncommon problem on buses that have sat a while. Evil or Very Mad
WD-40 is a lubricant, but not a penetrating oil like PB Blaster.
pyrOman
Fire Master
pyrOman is offline
PostPosted: Thu Apr 30, 2009 11:01 am    Post subject: Reply with quote
Hijack! (Sort of) Anxious
Though WD40 is a lubricant, its uses have other limitations as such. Namely, you do not want to use it to lubricate a stubborn keylock as it will also dissipate any existing grease. While it may "help" the situation at first, it will recurr more often after using WD40. If you must use it there, make sure you take it apart later and grease it properly. Or just take it apart from the get go, repair, grease it, and be done with that. Cool
FlusteredBust
FlusteredBust is offline
PostPosted: Thu Apr 30, 2009 11:08 am    Post subject: Reply with quote
Like Clara said, chock the wheels real well. I used a 4' cheater bar along with my 18'' breaker bar, and had no problems. To remove the drum, make sure you loosen both adjusters as much as you can. To me, peering into that little hole and finding and loosening the adjusters is actually the biggest pain in the whole process.
Mortimer Bondurant
Mortimer Bondurant is offline
PostPosted: Thu Jul 21, 2011 1:14 pm    Post subject: Reply with quote
Dredging up this old thread because I just twisted the 3/4" drive off of a Craftsman 18" breaker bar. It had a 1" adapter on the business end into a large nut socket. On the other end was a 36" cheater bar with me standing on it and my son whacking it with a nut tree knocker in the area of the breaker bar. This worked fine on the passenger side rear but the driver's side rear is not budging. 1967 Deluxe. My questions are:
1. even though the front spindle on the drivers side has reverse threads , all three other spindles including this one are counter-clockwise to remove, right?
2. We've been soaking it for a week in 3-in-1 oil. I've never seen PB Blaster for sale. Should I look harder for PB?
Thanks.
I guess I'll try heat too which is mentioned above in this thread.
jlarsen
jlarsen is offline
PostPosted: Thu Jul 21, 2011 2:32 pm    Post subject: axle nuts Reply with quote
yes - both rear axle nuts tighten by turning them clockwise and loosen by turning counterclockwise. Kroil is another effective penetrating and lubricating product as an alternative to P.B. Blaster.
jim
Mortimer Bondurant
PostPosted: Thu Jul 21, 2011 3:06 pm    Post subject: Reply with quote
Thanks, Jim. Also, in my haste, I gave you a few pieces of bum information. I ruined a 1/2" inch drive going into a 3/4" adapter and it was an ACE brand breaker bar, not Craftsman.
ldsvwguy
ldsvwguy is offline
PostPosted: Thu Jul 21, 2011 3:38 pm    Post subject: Reply with quote
X2! Plus this works on the gland nut if you ever need to replace the flywheel.
guatebus
guatebus is offline
PostPosted: Thu Jul 21, 2011 3:45 pm    Post subject: Reply with quote
You pretty much need all 3/4" hardware to get the axle nuts off. The 1/2" stuff tends to break. Using the proper tooling, it's not too hard to get them off.
One of the big things is making sure the bus holds still when you're torquing off the nuts. I'd block the wheels AND make sure the e-brake is on. You can even get an assistant to step on the regular brakes as you work in back.
I don't recommend the "whacker" tool, but you can weld one to a big length of pipe to make a great axle nut removal tool. Or upgrade to the 3/4" breaker bar, as mentioned above.
'64 standard microbus
'69 deluxe microbus
