hpw Samba Member
Posted: Sat Apr 25, 2009 2:30 pm Post subject: Wheels that bolt to frame horns? |
Saw a picture of it, didn't pay attention to what they where called. But it
has wheels that bolt to the frame horns to move a pan around and I assume
they make one for the front end, but didn't see one. Can anyone either
give me a name or link? (I have searched but couldn't find it) It is hard to
find something when you don't have its proper name.
thanks _________________ http://www.youtube.com/watch?v=3SLIzSCt_cg&list=FLIX26sGa8__1F1loczLPTtg&index=2 |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sat Apr 25, 2009 4:28 pm Post subject: |
The ones we used at the dealer were "Local manufacture". We made them ourselves. For the rear, a piece of 3" angle iron with a caster wheel bolted to the center.
For the front, the sam basic thing, but 2 casters bolted to it.
Use your imagination. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
tubdub Samba Member
Posted: Sat Apr 25, 2009 11:10 pm Post subject: Re: Wheels that bolt to frame horns? |
hpw wrote: |
thanks |
there is a local guy to me who makes and sells them. his price is 300 plus shipping. he has a thread in readers rides about doing a body drop on his 57 panel. his username is rebirth |
mike yapps Samba Member
Posted: Sun Apr 26, 2009 3:44 am Post subject: |
I made mine out of angle iron and a wheel from harbor freight I believe. Why not just make your own? It's much cheaper! |
hpw Samba Member
Posted: Sun Apr 26, 2009 3:48 am Post subject: |
mike yapps wrote: |
Yes that was kinda of my plan, but if they were available commercially
I was going to look at that. Also I can't weld and was looking to see if
you could bolt something together and wanted to see a picture for some
ideas. After posting this I think the one I saw was bolted to the tranny
mounts between the frame horns and not to the horns themselves. _________________ http://www.youtube.com/watch?v=3SLIzSCt_cg&list=FLIX26sGa8__1F1loczLPTtg&index=2 |
Chad1376 Samba Member
Joined: January 29, 2005 Posts: 1435 Location: Henderson, Nevada
Posted: Sun Apr 26, 2009 7:09 am Post subject: |
300 bucks seems outrageous. I build mine with a $8 HF wheel and scap iron. I would think a local welding shop should be able to hack one together pretty cheap.
_________________ My never ending 1302 Autocross Project:
http://www.shoptalkforums.com/viewtopic.php?f=51&a...02b8f83f22 |
Posted: Sun Apr 26, 2009 7:59 am Post subject: |
hpw wrote: |
mounts between the frame horns and not to the horns themselves. |
For $300, you can buy a welder, and all the material to build a set. When you are done, you still have the welder, and have learned to weld.
What is the sense of bolting to the tranny, if you are going to have the tranny out. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
hpw Samba Member
Posted: Sun Apr 26, 2009 9:56 am Post subject: |
Here is mine. Home brew. Materials were pulled from the dumpster at work.
4 swivel casters, and high enough that I can sit on a stool and not have to bend over while working.
The cross pieces are held with carriage bolts, that are movable, depending on where I want to work, and where the balance point it. Right now the car does not have an engine in it.
