7thing3 Samba Member
Joined: April 05, 2003 Posts: 473 Location: Cleveland, OH
Posted: Tue Sep 27, 2011 10:33 am Post subject: |
Alaric.H wrote: |
7thing3 wrote: |
Did you do that with tank in or out of vehicle? |
No it was in the van. |
I was only able to get about 1/2 of my nuts to turn, and that was some of the easier ones to access. I'll have to do it by dropping the tank, dremeling bolts, etc.
Need to redo the straps, etc. anyways. _________________ '73 Thing--Ted
'77 Super Beetle Convertible
'87 Vanagon GL Syncro
'84 Mercedes 280 CE |
hans j Samba Member
Joined: May 06, 2006 Posts: 2715 Location: Salt Lake City UT
Posted: Tue Apr 03, 2012 6:46 am Post subject: Re: Syncro fuel tank removal, reseal and SS strap install |
I am resigned to the fact I am going to have to do this very soon since both my tank straps are completely rusted through Is there any list of the replacement parts before I spend 2 hours looking on ETKA?
I have to pull the engine anyway for a slight leak from my rear main, and so I figure I may as well go all the way and take care of the straps too. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
CdnVWJunkie Samba Member
Joined: February 01, 2004 Posts: 1110 Location: Sarnia, Ontario, Canada
Joe75 Samba Member
Joined: February 21, 2005 Posts: 260 Location: New Zealand
Posted: Wed Oct 10, 2012 1:34 pm Post subject: |
Thought I would add my photos ...
With the tranny out I thought it might be a good time to sort out any other problems. The tank has leaked for ages and the straps look very rusted. So I decided to drop the tank. What a sh..t job. Diesel, coolant and 25yr old dirt and mud in ya face! Do people normally remove the sender gauge first? Mine got hooked up on the chassis rail stopping the tank from dropping down. After lots of bad words a large pry bar and jack I got it out. Anyway, its out...
As you can see i have had a leak for a while from the filler hose.
The metal part where you fill the tank has been badly welded in the past and was leaking.
The sender works but along with the tank straps is very corroded. Plus I think the sender should have a pickup tube on the end of it?
So it looks like a load of new parts? Being based in New Zealand i need to look all over the world with deep pockets I should get another 25yrs out of it! Not complaining at the part costs, just happy people still make em, its just postage costs...
-filler neck (stainless) Brickwerks UK
-filler neck rubber hose (only found on van cafe web site) expensive for a rubber hose?
-sender unit kit. Van Cafe and Go Westy
-tanks straps (stainless) Many suppliers
-tanks re-seal kit Van cafe Go Westy.
So do i put the sender in first or refit the tank then install the sender unit? |
minsk Samba Member
Joined: March 17, 2008 Posts: 899 Location: pittsburgh
minsk Samba Member
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Thu Oct 11, 2012 3:35 pm Post subject: |
Joe75 wrote: |
I put in the sender then cut a big plastic soap detergent bottle and taped it to the DS frame member tightly with duct tape. That helped everything slide by the frame easier without digging into it too badly but a pair of pry bars were still used to persuade the tank into place- be very careful about the sender nipple.
Got a ebay account? http://www.ebay.ie/itm/VW-TRANSPORTER-T25-FUEL-FILLER-NECK-HOSE-251201143A-NEW-/130578791502
You have a lot of hackery in a small area from the PO on your van. |
dkonzy Samba Member
Joined: October 24, 2012 Posts: 142 Location: Kirkland
Posted: Thu Jun 06, 2013 7:47 pm Post subject: |
I am removing the AC from my rig (along with everything else) and wondering if the filter looking thing parallel to the fuel filter is. Looks like pressurized hose and is about the size of a can of soup. Bolts to the Frame with two bolts...
Some sort of AC filter or expansion tank? _________________ 1987 Syncro |
dkonzy Samba Member
Posted: Thu Jun 06, 2013 8:16 pm Post subject: |
Looks way nicer than mine but that's it!
Removing now... _________________ 1987 Syncro |
dkonzy Samba Member
Posted: Thu Jun 27, 2013 9:23 am Post subject: |
Anyone know the measurement between the tank strap mounts on the firewall? I cut my bracket out and am fabricating a new one. Lining everything up...the SS straps do not seem to be lining up well with the shape of the bottom of the tank.
Big question: Do the straps stay square with the car (equal distance between hangers and firewall mounts)
Thanks! _________________ 1987 Syncro |
Farfrumwork Samba Member
Joined: October 10, 2008 Posts: 692 Location: Mile High
Posted: Thu Jun 27, 2013 1:22 pm Post subject: |
I can get a measurement when I get back home.
I will say that I just finished installing my SS straps around my refurbed fuel tank in my on going syncro conversion.
I neglected the formed support, and made ~1.25" wide L-brakets out of angle steel that bolt through the bulkhead into the underseat compartment; I welded captive nuts onto the L-brackets and secured the SS straps to that.
Point being (for this discussion) - My L-brackets do NOT leave the strap mounting point in exactly the same location that the stock syncro had them. The straps are relatively close to being 'square' with the vehicle, but not perfect.
I have found that there is a lot of leeway with the fiting of the syncro fuel tank. Mine is SOLIDLY in there.
(btw - others have mounted their tanks this way in past 2wd-syncro conversions - most notably Syncroghia and Frankensubysyncro, 2 people that know vangons and USE them to the fullest)
I also found that I had to 'form' the SS straps to the tank a bit to get them to follow the tank shape. Makes sense realy as they are pretty much flat as you recieve them.
And man, that tank is NOT fun to work with. One of the more unpleasant tasks I have completed with the syncro conversion (and that's saying something) _________________ sold -> '85 Wolfsburg Syncro / 'Built' DOHC EJ25 (a great machine!)
'07 Legacy spec.B, road tuned stgII
'17 4x4 Sprinter, stone grey, SMB pop-top, on 33"s
"Blood stains, speed kills - Fast cars, cheap thrills - Rich girls, fine wine - I've lost my sense, I've lost control, I've lost my mind" |
SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 2458 Location: Highnam, UK
Posted: Fri Jan 03, 2014 4:16 pm Post subject: |
thummmper wrote: |
interesting--whats the capacity of that tranny saddle tank? my bentley is bereft of data. |
70 litres.
Does anyone have a rubber seal for the fuel tank sender to hand? How thick is the rubber and what is the outside diameter of the seals?
Thanks in advance.
MG _________________ T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD |
VeeDubDaySpa Samba Member
Joined: February 29, 2008 Posts: 368 Location: Bend, OR
Posted: Sun Apr 20, 2014 2:43 pm Post subject: |
Ok, I'm doing the same job smurf rocked out... I have a question regarding the set up of the fuel line rack. When I look at the Bentley, the T for the vent lines looks to be on the passenger side sending the non float valve, open line towards the fuel filler... In my set up I pulled, the T is on the passenger side with the open line going towards the charcoal canister, which sounds right to me?
Here is a photo of my rack I pulled:
Any help is greatly appreciated as I'm hoping to make Syncrofest! _________________ North American Hightop Installer/Distributor
Current stock (5)
Hot Water Systems
90 Syncro NAHT Vanagon RHINO
86 "Syncro" Van DIAMOND
87 Syncro Hightop WestyCamper ROCKY (for sale soon)
79 bay window OLIVER |
Posted: Mon Apr 21, 2014 10:14 am Post subject: |
Bump _________________ North American Hightop Installer/Distributor
Current stock (5)
Hot Water Systems
dkoesyncro Samba Member
Posted: Mon Apr 21, 2014 6:20 pm Post subject: |
Your answers are on page 1 of this post, study the pics you'll be in good shape! Best of luck to you.
I feel like a broken record but......with all the dang farm bills pushing us into bio based fuels make sure your new lines are up to the task...and I mean dig. You may find your self talking to a German girl who really knows her fuel line tell you that yup that's fuel line but it won't support oxygenated or bio base. I made this $$ mistake and glad that i did. After all our vans do burn down too!
Check out the condition of your inter filter (screen) and submersible fuel line. Fas has this http://www.foreignautosupply.com/parts-accessories/39-syncro-in-tank-fitting/#.U1XDnlVdXAk |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Sun Jan 25, 2015 11:49 am Post subject: |
Can the steel filler pipe be removed and replaced with the motor and syncro tank left in place? How is The pipe (#13 in picture) attached to the tank? Is it just a slip fitting into a rubber grommet?
I have a new sending unit that is leaking. It was installed when the motor was built. Anyone run into this before? Do the gaskets fail?
Thanks!
insyncro wrote: |
This is the Late version. |
_________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
Posted: Sun Jan 25, 2015 12:21 pm Post subject: |
The sending unit can be serviced with the tank in place. Remove the charcoal canister and remove the bolts for the fuel filter and pull it out of the way.
I have never dealt with the filler pipe without removing everything so I cannot help there.
Aviation form-a-gasket from your local auto parts place is resistant to gasoline. It has worked well to fix a minor fuel smell that I had on my truck, I used it on the outer sender seal without issue. |
insyncro Banned
Posted: Sun Jan 25, 2015 12:48 pm Post subject: |
A Syncro that I built, but had a resealed tank and new sender in it before coming to my shop is now leaking when the temps drop below 30 degrees.
I do not know if an old gasket or any sealant was used during the install, but have not heard back from the owner since having it looked at locally.
Up until this point I have not had a weep from any sender, no matter how crusty or brand new. |
insyncro Banned
Posted: Sun Jan 25, 2015 12:50 pm Post subject: |
rmcd wrote: |
Thanks!
insyncro wrote: |
Yes, 13 is a slip fit at the tank.
It can be removed without much being removed along with it. |
