bvilletom Samba Member
Joined: January 22, 2006 Posts: 95 Location: cedar rapids iowa usa
Posted: Fri May 01, 2009 4:09 pm Post subject: 36 Rocker Art |
Here is a set of forged steel 1.3 to 1 rocker arms for a stock 36 or
Okrasa head. To get the proper offset the rocker shaft is handmade from
billet tool steel hardened to 60r then drawn back to 48r. This is designed
to be a performance replacement to fit directly in a 36hp head with the
stock pushrods, valves, and springs. The shaft was really hard to get all
the offsets built-in and still be able to get the rockers on and be strong.
We’re going to be testing these under racing conditions May 16th.
Bvilletom (Brukrasa)
_________________ bvilletom
36hp Challenge record holder New Age 126.236mph
1970 Porsche 914/6 – 2 liter LSR record holder
1992 Metro Sedan – 1 liter LSR records
1987 Chevy Turbo Sprint – under construction
grueni Samba Member
Joined: November 03, 2008 Posts: 582 Location: Germany
Posted: Fri May 01, 2009 5:07 pm Post subject: |
funny looks like the same i thought about when starting thinking about rocker ratio. but alot of work and i thougt about using stock rocker...weldet and then relocat the new holes.
am i right that this are the later intake rocker from 356/912 porsche?
beautifull work.
i also have a question to you tom PM
wishes from berlin |
Julio Iniguez Samba Member
Posted: Sat May 02, 2009 11:33 am Post subject: |
Very nice Tom!! Good luck on the test bed.
Julio |
Art Thraen Samba Member
Posted: Sun May 03, 2009 8:15 am Post subject: |
Nice PICs Tom.... These little engines are Fun... But hard to hopUP..
See you soon, Art @ ACE |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76907 Location: Sneaking up behind you
Posted: Sun May 03, 2009 8:24 am Post subject: |
It's great to see all this performance stuff for the 36hp... it's about time. _________________ Glenn
Member #1009
#BlueSquare |
Louis Samba Member
Joined: September 26, 2007 Posts: 423 Location: canada BC
Posted: Mon May 04, 2009 2:41 am Post subject: |
good job... will be waiting for those thats for sure!! |
Roadcow Samba Member
Joined: November 14, 2003 Posts: 1012 Location: Stockton, Ca. area
Posted: Tue May 05, 2009 8:14 pm Post subject: |
Nice work Tom. _________________ 71 Westy Roadcow
67 Panel
63 Bug
66 Ghia Bonneville 2014
74 Ghia Vert
69 Bonneville Ghia 150 in Chico
69 Bonneville Ghia in Ireland
80 Cabby 2.1 16v
98 Passat |
blacklineracing Samba Member
Joined: March 21, 2009 Posts: 128 Location: Salt Lake City, Utah
Posted: Wed May 06, 2009 5:01 pm Post subject: |
Very nice Tom,
we can't wait to see how they work for you
Justin and Colton |
Unkl Ian Samba Member
Joined: September 11, 2008 Posts: 288 Location: Near Toronto
Posted: Sun May 24, 2009 10:26 am Post subject: Re: 36 Rocker Art |
bvilletom wrote: |
How well did they work ? |
Posted: Sun May 24, 2009 1:07 pm Post subject: Re: 36 Rocker Art |
Unkl Ian wrote: |
bvilletom wrote: |
They set a new SSS record of 90 mph. _________________ 71 Westy Roadcow
67 Panel
63 Bug
74 Ghia Vert
80 Cabby 2.1 16v
98 Passat |
Posted: Sun May 24, 2009 3:32 pm Post subject: Re: 36 Rocker Art |
Roadcow wrote: |
They set a new SSS record of 90 mph. |
Congratulations !
What were the arms for originally ? |
Posted: Tue Jul 07, 2009 4:13 pm Post subject: |
Rest of the story:
Before we went racing we had to modify the rocker covers, the lower end
of the Porsche rockers at the screw top it hit the cover a lot. We made
little hand-hammered spoon-shaped covers & brazed them on which
worked fine. The racers say my covers have boobs now.
The high lift rocker set performed perfectly & made the engine much
more responsive. The valve lift went from about .295 to approx. .385 at
the valve. The ratio must be 1.3:1 or slightly more. Modified rocker
arms similar to Blackline type could also be used with the new shaft and
everything else stock.
Just a side note, I had a chance to take a road trip and got to visit
several 36hp LSR shops. Ronnies bus shop in AZ, Justin & Art (Blackline)
in Salt Lake, and Bruce Cooks in NC. I also got to meet Whitey Worsham
from NC, Cooks Cylinder head guru. We had a day to brainstorm36hp
heads with pictures and everything. Much fun, then back to my shop.
Bvilletom
1987 Chevy Turbo Sprint – under construction |
greggearhead Samba Member
Joined: June 20, 2004 Posts: 563 Location: Colorado Springs, CO
grueni Samba Member
Posted: Thu Oct 29, 2009 1:29 am Post subject: |
grueni wrote: |
beautifull work.
how I told once, now after get my cam grinded to my wishes I could start the rocker geometrie.
this is just the test-head its only about the rocker stands.
after machinig them they are now 1,33:1 in ratio everything was fine so I can start the next days with my big singleport's
sorry its in german
http://bug-talk.de/forum/viewtopic.php?t=24323&start=15 |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1275 Location: australia
Posted: Thu Oct 29, 2009 3:25 am Post subject: |
beautiful work. |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Thu Oct 29, 2009 8:51 am Post subject: |
grueni wrote: |
grueni wrote: |
beautifull work.
sorry its in german
Do you have the demensions of how far you moved the arms back? _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
Posted: Thu Oct 29, 2009 9:16 am Post subject: |
grueni wrote: |
sorry its in german
NICE work. |
grueni Samba Member
Posted: Fri Oct 30, 2009 4:11 am Post subject: |
hi folks...
today I did all the messuring stuff on the rocker geometrie..this was just the test-head..
at first i call them "medusa-rocker ratio's" all the stuff I build by my own is now medusa stuff , cam , supercharger system,engine just vor fun.
the offset is exact 4,5mm.
because off all the messurmants I did..more than 10 times every messure to calculate out the mistakes.
the exact theoretical rocker ratio is 1,3214:1 so 1,32:1 the post befor I forgott that the rockers are a bit different just 0,5mm.
the shaft is exact in level to the valves.
rocker and valve match very good.
for the racers:
1,34:1 is possible with these rockers..but it is it's max.
with my cam it should be about 0.480" lift max. an the EX. and 0.470" on the IN. |
Posted: Fri Oct 30, 2009 10:48 pm Post subject: |
grueni wrote: |
hi folks...
for the racers:
Very nice work, thank you for the info _________________ Stocking distributor of "The Funky Green Panels"
oval56 Samba Member
Joined: July 21, 2003 Posts: 1309 Location: oktoberfest maintown
Posted: Mon Nov 23, 2009 2:55 pm Post subject: |
i have done my homework also....
www.oval56.de/video/okrasa%20rockers.wmv
next step cylinder piston and headwork _________________ www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com |
