Sunroof handle
J Flare
J Flare is offline
PostPosted: Mon May 04, 2009 12:19 pm    Post subject: Sunroof handle Reply with quote
Having trouble trying to get the handle to fit. The PO said it was correct but I'm not sure. It's a 66 Delux with a golde handle. The teeth inside the handle are fine and the mechanism has no teeth. It appears like you just slide it over and put in the set screw but the handle seems too small for the mechanism.
Any ideas?
BarryL Premium Member
BarryL is offline
PostPosted: Mon May 04, 2009 7:00 pm    Post subject: Reply with quote
Any pictures of both?
J Flare
J Flare is offline
PostPosted: Mon May 04, 2009 7:06 pm    Post subject: Reply with quote
Hi Barry
Here is one of the handle. The mechanism is just a like for a door handle without the screw hole or teeth.
Braukuche
Braukuche is offline
PostPosted: Mon May 04, 2009 7:54 pm    Post subject: Reply with quote
J Flare wrote:
Hi Barry
Joe,
If you want you can come by my place and we can see if your handle will fit on my sunroof mechanism. It would at least narrow the problem down.
--Dan
J Flare
J Flare is offline
PostPosted: Mon May 04, 2009 8:21 pm    Post subject: Reply with quote
Sounds good
I will catch up with you later this week sometime
Thanks
BarryL is offline
PostPosted: Tue May 05, 2009 7:02 am    Post subject: Reply with quote
It looks like the right handle. They went to the flat style so people would stop bonking their skulls, I've heard.
