Slowlow Samba Member
Joined: March 17, 2004 Posts: 4121 Location: Northeast Tennessee
Posted: Tue May 05, 2009 9:13 pm Post subject: Rear "Boomerang's" Used for lift |
I'd love to see any and all pics of busses using the "Boomerang" style rear plates, normally installed to drop a bus, flipped around to Raise the bus.
Ive seen maybe two, but curious if there were more. Just curious to see how high it would be AND Axle/ CV angles.
Thanks! _________________ • Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 • |
Posted: Wed May 06, 2009 4:07 pm Post subject: |
Nobody...? _________________ • Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 • |
roland Samba Member
Posted: Thu May 07, 2009 3:04 am Post subject: |
Well I don't have pics but i'm pretty sure that it will blow the bus CV's. I raised my bus by putting 1 click on the sping plate, then I changed the bus CV's for 944/thing ones wich can get more angle and I still managed to break them now & then...
Depends on the use of the bus I guess... If it's just for the looks, mostly road driving it'll hold longer but if you offroad with it and bottom out on the suspension a lot it won't... |
Posted: Thu May 07, 2009 5:43 pm Post subject: |
You had the red camper right?
That thing was bangin...... Hopefully my Truck will sit atleast that high. _________________ • Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 • |
roland Samba Member
Posted: Fri May 08, 2009 3:03 am Post subject: |
Yeah, the red camper was mine, thanks..
It wasn't really hard to get it that high, i'm sure you could make it a lot higher with a bit more work... |
