55 Barndoor Single Cab Fuel tank Questions
Car Doc
Bus Electrician
Car Doc is offline
PostPosted: Wed May 06, 2009 6:08 pm    Post subject: 55 Barndoor Single Cab Fuel tank Questions Reply with quote
Hi all. I'm a little confused as far as what the fuel tank looks like in a barndoor truck. Does it have the wide filler neck and a wide body like the busses, or is it slimmer like the post barndoor type 2's? I'd also be grateful if someone could show me a good picture of the '55 barndoor truck fuel tap. Thanks a million!
98 Cavalier Z24
71 Plymouth Satellite Custom
74 Sebring Vanguard Citicar
65 Corvair Monza Convertible
Fried egg Double-Door Bus (two days)
71 Plymouth Sport Fury Hardtop.......HECK YEAH!!!!!
PostPosted: Wed May 06, 2009 6:31 pm    Post subject: Reply with quote
Here's the tank and tap from a 1953 Single Cab. I believe it is the same.
http://www.thesamba.com/vw/forum/album_page.php?pic_id=510240
http://www.thesamba.com/vw/forum/album_page.php?pic_id=510241
http://www.thesamba.com/vw/forum/album_page.php?pic_id=510242
http://www.thesamba.com/vw/forum/album_page.php?pic_id=510243
The fuel tap is the same as a regular Bus, it's only the long post that run out to the rocker hole that is an additional part.
My '54
Rick
Rick is offline
PostPosted: Wed May 06, 2009 7:38 pm    Post subject: Reply with quote
Isn't it also a "truck only" tank? What is the difference? I havn't looked at mine that closely yet.
PostPosted: Wed May 06, 2009 10:05 pm    Post subject: Reply with quote
Look at the photos, it appears that the filler neck is in the center while my '55 Bus tank is more offset to the right side.
The fuel outlet is much closer to the neck side. My '55 tank outlet is basically in the center.
bubba
bubba is offline
PostPosted: Thu May 07, 2009 5:49 am    Post subject: Reply with quote
It's the same tank as 53-55 barndoor with the neck moved more to the center. You can make it if you need too.
streetwagens
streetwagens is offline
PostPosted: Thu May 07, 2009 6:17 am    Post subject: Reply with quote
Rocker hole for the reserve rod? Does anyone have a pic of this piece that hasnt rusted off the bus? Both my '54 s/c's dont have anything left of this area, i'd love to pop it back the way it's meant to be. Cool
To catch a fish, you must first think like a fish....
Rick
Rick is offline
PostPosted: Thu May 07, 2009 6:58 am    Post subject: Reply with quote
you mean the hole for the church key? Or the linkage behind that to the tap? I've got all and can take pictures. Do you need measurements too?
streetwagens
PostPosted: Thu May 07, 2009 7:02 am    Post subject: Reply with quote
Photos of where the rod goes on Ev's pic would be great thanks Rick! Cool There is no trace of any of that on mine Embarassed
Rick
Rick is offline
PostPosted: Thu May 07, 2009 7:32 am    Post subject: Reply with quote
Here you go. bottom picture has the tape measure hooked in the bottom of the gas filler door opening - measures 11.125 to center of hole. top picture is hooked in the treasure chest opening - measures 5.25 to center of hole. The hole is 13/16" in diameter. I'm also interested in the rod. Mine has it, but a friends doesn't. Any ideas for making this part? Take a round tube and hammer a square rod into the end?
streetwagens
PostPosted: Thu May 07, 2009 7:51 am    Post subject: Reply with quote
Thats perfect Rick, thank you!
A square rod gently tapped in the end while pressing the flat sides in should do the job I think. Cool
kombicol
kombicol is offline
PostPosted: Thu May 07, 2009 11:28 am    Post subject: Reply with quote
I seem to remember John Jones taking some pics of this area also in the thread/gallery on his BD single build up. If you look in the gallery there are photos of the tank brackets, etc also.
I believe he had to make a tank for his too, and used part of a beetle tank?
Tonny_Larsen
Tonny_Larsen is offline
PostPosted: Thu May 07, 2009 12:36 pm    Post subject: Reply with quote
http://www.barndoor.dk/detaljer42.html
veedub
veedub is offline
PostPosted: Sun Oct 10, 2010 5:10 pm    Post subject: Reply with quote
Is the correct color for a single cab fuel tank of this era grey or black?
~slovolks~
PostPosted: Sun Oct 10, 2010 10:45 pm    Post subject: Reply with quote
My ex-'54 looks pretty dark:
jborregoy2k
jborregoy2k is offline
PostPosted: Mon Jul 06, 2020 10:40 pm    Post subject: Support for 52 Single Cab in neck side Reply with quote
Can anybody help me with a picture for the floor-to-tank single bolt support for a 60mm fuel tank in the neck side, like the single one showed in the picture.
My car came without this support neither the tank had it.
Jdt1976
Jdt1976 is offline
PostPosted: Sun Jan 31, 2021 6:17 am    Post subject: Re: 55 Barndoor Single Cab Fuel tank Questions Reply with quote
Would the measurement of the location of the filler hole on the long side panel be the same between RHD and LHD SC’s that.
(26A 261 Pick-up, tool compartment lid right, LHD
26B 264 Pick-up, tool compartment lid on left, RHD)
gatorwyatt
gatorwyatt is offline
PostPosted: Mon Feb 01, 2021 4:53 am    Post subject: Re: 55 Barndoor Single Cab Fuel tank Questions Reply with quote
The “filler” hole for the fuel tank is on the short wall side. Always. And, yes it is the same size. There is no LHD fuel tank and RHD fuel tank they are the same.
www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine
Jdt1976
Jdt1976 is offline
PostPosted: Mon Feb 01, 2021 9:53 am    Post subject: Re: 55 Barndoor Single Cab Fuel tank Questions Reply with quote
Thanks for your reply. I read through your restoration of the 54 RHD SC. Good work. I am also fortunate to own a 54 RHD SC.
I was drooling over your NOS side panel.
The reason for my question was I ordered one from Autocraft and when it arrived it was without the filler hole.
They weren't aware that it was on the oppositie side of the LHD but was more than willing to make one if I gave them measurements.
So was curious if the left panel with the filler hole was a mirror image of the right one?
gatorwyatt
PostPosted: Mon Feb 01, 2021 1:41 pm    Post subject: Re: 55 Barndoor Single Cab Fuel tank Questions Reply with quote
Thanks for the comment!
Yes! The NOS panel was one of my favorite finds for the truck. Mine was wasted badly!! Remember the Wolfsburg gas door seal detail when having them make it. It takes the one long seal not the two bumpers.
The panel should be a mirror image as the gas tank is situated in the same spot just on the opposite side. I know Klassic Fab makes or made the tank mounts that weld to the floor. The whole floor for those trucks are specific to RHD Barndoor truck. So many details to get right.
What VIN is yours??
www.blastserv.com
wanted:
Jdt1976
Jdt1976 is offline
PostPosted: Mon Feb 01, 2021 10:26 pm    Post subject: Re: 55 Barndoor Single Cab Fuel tank Questions Reply with quote
Thanks for the info.
Vin is 20-0865XX, Built 21 May 1954
