jdbs3 Samba Member
Posted: Thu May 07, 2009 11:23 am Post subject: Radiator Fan Questions |
1990 Vanagon GL
Getting my van ready for a road trip after its being in the garage over the winter. A few questions on the radiator fan:
1. If I am waiting for a period of time at a traffic light (e.g. stop and go in a big city) sometimes the radiator fan will come on; ditto if I leave the van idling for a few minutes.
Is there any rule of thumb as to how soon the fan will start? Does it matter how long it runs till it goes off?
Probably a stupid comment, but I have always felt it best to avoid having the fan run as much as possible.
2. Radiator fan and A/C
I've been reading everything I can on A/C; would like to use it on the trip. The radiator fan should go on as soon as I turn on the A/C switch, but it isn't.
What is the best way to diagnose this problem - where to start, etc. Yes, I'll check the fuses first.
thanks |
shenan-agon Samba Member
Joined: May 11, 2005 Posts: 423 Location: Portland, OR
Posted: Thu May 07, 2009 12:54 pm Post subject: |
1. Sounds like normal behavior to me - you should expect the fan to cycle on/off while idling or running at low speed when there isn't much airflow over the radiator. This GoWesty article explains the cooling system operation pretty well:
http://www.gowesty.com/library_article.php?id=52
2. Not sure on this one - my fan turns on when I flip on the A/C (even though I don't have functioning A/C anymore). I don't remember if it jumps right to the high speed or if it does low speed first - do you know if both speeds on your fan are working? Have you ever heard the high speed kick in? (You can test both fan speeds by jumping each pair of pins at the fan switch connector on the radiator). If I remember right, the wiring diagram doesn't show any interaction between the A/C and the radiator fan, even though we all know by experience that there is - might make it trickier to troubleshoot... |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9935 Location: Orbiting San Diego
Posted: Thu May 07, 2009 1:31 pm Post subject: |
Vanagon Bentley page 97.145 shows the 1989+ A/C wiring connections to the radiator fan circuit.
The fan should come on at the lowest of 3 speeds when you switch on the A/C. If it doesn't, the common problem is the fan resistor for low and medium speed. The resistor burns out and then one or both lower speeds stop working. It lives behind the driver side headlight, as shown on page 87.5 in the A/C section.
Mark
shenan-agon wrote: |
........ If I remember right, the wiring diagram doesn't show any interaction between the A/C and the radiator fan, even though we all know by experience that there is - might make it trickier to troubleshoot... |
Posted: Thu May 07, 2009 2:04 pm Post subject: |
You want the fan to come on fairly quickly when you slow down on a hot day, otherwise you will heat soak your engine. If you install a new fan switch with a -75 suffix on the part number it will come one earlier and cycle more frequently while keeping the engine temps very constant. In my experience the fan will even last longer is if is cycled more frequently, maybe spinning it more often helps the bearings and the shorter cycles keep the resisters and winding from getting as hot. Don't know for sure. |
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Thu May 07, 2009 2:32 pm Post subject: |
From what I've heard others here say, if the 3rd speed fan comes on at a lower temp, it will shut your AC off sooner as well. _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
Posted: Thu May 07, 2009 3:18 pm Post subject: |
True, with 86+ the A/C compressor is shut off by the high speed fan switch. Using the 75 degree switch will diminish the A/C cooling on hot days.
I have tried the 75C switch twice on different vans and took it back out both times. Not because of the A/C but because it ran the fan way too much.
Mark
GWTWTLW wrote: |
From what I've heard others here say, if the 3rd speed fan comes on at a lower temp, it will shut your AC off sooner as well. |
mtnwater Samba Member
Posted: Thu May 07, 2009 3:28 pm Post subject: |
My radiator fan only comes on when my AC compressor is engaged - i.e. there are times when my AC is on and my radiator fan isn't. As soon as the compressor clutch kicks in, the fan comes on. Is this correct operation, or should my radiator fan be on continuously when the AC is on regardless of the compressor state? |
Posted: Thu May 07, 2009 3:34 pm Post subject: |
mtnwater wrote: |
Doesn't sound to me like it is operating correctly. Are you sure it isn't coming on when you first turn the switch and you just aren't hearing it? On low the fans doesn't make much noise. The fan on low is much more audible when standing in front of the van than sitting inside.
When the engine is hot enough that the thermostat is open as you slow down the fan switch should cut the fan on fairly quickly and cycle often until the engine is shut off or you pick up speed and get good air flow through the radiator again. |
Posted: Thu May 07, 2009 3:35 pm Post subject: |
I believe it is tied to the compressor. _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
tencentlife Samba Member
Posted: Thu May 07, 2009 8:50 pm Post subject: |
Could be the low speed is inop because of bad series resistor. The 2nd speed is only activated by the AC high-side pressure switch, so maybe the pressure gets higher faster because the low-speed fan isn't working; it would help lower hi-side pressure by condensing more gas. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Fri May 08, 2009 9:23 pm Post subject: |
Thanks for the reply tencent - I appreciate the feedback. The resistor and fan thermo switch are both relatively new (w/in the last 10k miles). I thought the fan was only two speed? I can get the fan to blow both high and low by jumping the wires on the fan switch, so assumed all was well with the resistor. Fan seems to kick on when the coolant temp climbs, so I believe the thermo switch is working okay too.
As for fan operation with AC, I confirmed this afternoon that the fan only comes on when the compressor is engaged - the compressor and the fan both kick on at the same time. If the AC is on but the compressor isn't engaged...no fan. Any thoughts as to what's up? SEems okay to me, but if something is wrong I'd like to fix it. For reference, my van is a '90 syncro. |
Penny Wolin Samba Member
Posted: Fri May 08, 2009 10:07 pm Post subject: Radiator Fan Running All of the Time |
I just acquired a 1989 Vanagon Westfalia with 43K original miles. The radiator fan runs all of the time, and turns off when the engine is turned off. My local mechanic who just bled the system said,"Great, let it run." I don't think it is meant to run all of the time, is it? What is going on here? Thank you. |
jdbs3 Samba Member
Posted: Mon May 11, 2009 2:22 pm Post subject: |
RE: Are you sure it isn't coming on when you first turn the switch and you just aren't hearing it? On low the fans doesn't make much noise. The fan on low is much more audible when standing in front of the van than sitting inside.
It works; comes on immediately. Standing in front of the van helped.
Thanks all for the feedback. Now on to replacing the R12 with Red Tek. |
dannywk Samba Member
Joined: April 08, 2009 Posts: 32 Location: Mount Vernon, WA
Posted: Fri May 15, 2009 3:51 pm Post subject: Fan runs constantly 1987 2.1 |
I also have the problem of the fan running constantly. This is a bigger problem in the winter when i would really like the van to warm up.
If anyone had this problem and fixed it, i would love to hear how you did it. |
