jpeekstok Samba Member
Joined: November 07, 2008 Posts: 20 Location: michigan
Posted: Sat May 09, 2009 10:42 am Post subject: new motor will not start |
ok .... i had a 2.1 built into the 1.9 crankcase for an '84 vanagon... i installed the motr and at first it wouldn't spark and i replaced peice by peice the intire ignition system just short of the key cylinder and i have spark now.... the fuel system has been primed we aligned everything TDC and it just gives us pops but only when we retard it...... but i can't get this thing to start!!!
the only thing that i notice is that the temperature gauge blinks and goes all the way up when the key is turned over.... even when the sensor is unplugged, ... does it do that normally when it isn't running and can that effect it starting (should be a bypass when unplugged other wise there would be busses on the side of the road every where).... if any one has any thoughts, that would be extremely helpful
thankyou _________________ 1984 westfalia 2.1 auto |
Vanagon Nut Samba Member
Posted: Sat May 09, 2009 11:03 am Post subject: |
Sounds to me like timing.
I don't have my Bentley in front of me, but IIRC, it's possible to install the distributor drive gear (in block) incorrectly.
Was it installed correctly? _________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
Posted: Sat May 09, 2009 11:19 am Post subject: |
well we did the screwdriver test when the motor was at TDC and the rotor aligned correctly to the #1 mark on the distributor... i am worried that with all of this cranking i am destroying my $2k motor!! : ( _________________ 1984 westfalia 2.1 auto |
Posted: Sat May 09, 2009 11:54 am Post subject: |
Considering your coolant gauge behaviour, check connections at coolant sensors. Don't know about Digijet or Digifant, (you're running Digijet?) but Motronic needs input from coolant sensor for it to run properly. _________________ 1981 Westy DIY 15º ABA
VE7TBN |
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3343 Location: Talos IV, Piedmont Arizona
Posted: Sat May 09, 2009 12:01 pm Post subject: |
jpeekstok wrote: |
well we did the screwdriver test when the motor was at TDC and the rotor aligned correctly to the #1 mark on the distributor... : ( |
And then you checked the valves on #1 to be sure they were closed. TDC comes up twice. 4 cycle engine __________remember.
Your temp wire is most likely grounded and your firing order is off 180'. _________________ LEARN TO SELF RESCUE
.....................All Current....................... |
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2332 Location: Southeast Kentucky
Posted: Sat May 09, 2009 9:00 pm Post subject: Engine timing, etc. |
Check the timing with a timing light as engine is being cranked. That will help get you in the ball park on timing.
Also, we have to assume you are running Digijet system. Either way, all the sensors, grounds, etc., have to be properly connected. On the 1.9 engine, the engine temp sensor and the temp sensor for the ECU are located close together...... check the manual for proper location.
And, as suggested, confirm that #1 is on TDC "compression" to establish that Cam is in time which affects distributor timing, etc. Have someone to crank the engine over while you watch the rocker arms open and shut the exhaust and intake valves in order to double confirm that you are on the correct TDC (as already suggested). (Still talking #1 cylinder, right front of engine.)
All the cranking will not destroy the $2k engine .......maybe the battery and starter!
Hope you get it going! _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
