dc Samba Member
Joined: April 03, 2004 Posts: 1426 Location: Kitsap Peninsula
Posted: Thu Dec 07, 2017 5:45 pm Post subject: Re: Type 3 Truck - the "other" vw |
Cool!
So what is #15 in the picture? Between the oil seal and the spindle - some sort of large seal?
Thanks- that was a fast shipping _________________ 1963 Karmann Ghia |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Thu Dec 07, 2017 5:47 pm Post subject: Re: Type 3 Truck - the "other" vw |
It's a paper gasket that almost no one uses.
If you really want them I have some NOS pieces... |
dc Samba Member
Posted: Thu Dec 07, 2017 5:58 pm Post subject: Re: Type 3 Truck - the "other" vw |
I'm DEFINITELY not worried about originality- just want it to work and look good doin' it.
So that seal doesn't real do anything...? _________________ 1963 Karmann Ghia |
Posted: Thu Dec 07, 2017 6:17 pm Post subject: Re: Type 3 Truck - the "other" vw |
It'll probably disintegrate after a decade but that's about it. It may have been made of a corrosion inhibiting paper but beyond that, I don't know what other purpose it'd serve.
I don't have them on my current car and haven't seen them on a car in a very long time because I think they just disappear over time. |
dc Samba Member
Posted: Sun Dec 10, 2017 1:33 pm Post subject: Re: Type 3 Truck - the "other" vw |
Got the front brake hardware all bolted in. Not too bad! I was concerned that the shoes and springs would be a pain- but I figured out how to do it. Tom is going to help me get the old races out of the drum hubs and the new stuff pressed in and greased....
Getting closer
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
dc Samba Member
Posted: Sun Dec 17, 2017 1:00 pm Post subject: Re: Type 3 Truck - the "other" vw |
Got the drums packed with the new bearings and all back together. The shoes are adjusted back as far as they will go BUT there is still a slight drag on the drums...give it a good spin with the wheel/tire bolted on and it only rotates freely for 3-4 seconds. Is that normal Will it settle in? Do I need to modify the adjuster or shoes to make it work? Or just go ahead and bleed the brake fluid and try it out? _________________ 1963 Karmann Ghia |
Posted: Sun Dec 17, 2017 1:27 pm Post subject: Re: Type 3 Truck - the "other" vw |
dc wrote: |
Got the drums packed with the new bearings and all back together. The shoes are adjusted back as far as they will go BUT there is still a slight drag on the drums...give it a good spin with the wheel/tire bolted on and it only rotates freely for 3-4 seconds. Is that normal Will it settle in? Do I need to modify the adjuster or shoes to make it work? Or just go ahead and bleed the brake fluid and try it out? |
What you might find is that the leading edge of the brake shoes might need a slight taper ground into them (knock the sharp edge off). I do however think it'll settle in though without taking it apart. I'd run it a bit, and check the temps on the drums. You find that you're fine.
How is your bearing adjustment? You might be slightly too tight. Just something to double check when using the 2 nuts and lock plate (harder to set than the locking nut).
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
dc Samba Member
Posted: Sun Dec 17, 2017 1:47 pm Post subject: Re: Type 3 Truck - the "other" vw |
Bobnotch wrote: |
dc wrote: |
I hope this helps. |
Good advice - same as my mechanic friend Tom just told me on the phone! I will mess with it and report back _________________ 1963 Karmann Ghia |
dc Samba Member
Posted: Mon Dec 18, 2017 3:54 pm Post subject: Re: Type 3 Truck - the "other" vw |
That was good - my daughter is home on Winter Break and just helped me bleed the brakes. Lots of crud in the lines and lots of air She was at the brake pedal and we went from no pedal to about 70% pedal.
Still not ALL bled but I'm not surprised - the whole front end braking system is new and the left rear wasn't really working before. I will cautiously test it in the driveway and see if it is driveable enough to get to a regular shop for a full bleed.
Used about 2/3 of a quart of DOT 3.
Weirdly - one of the front bleeders was 10mm head and the other was 11mm head - but both with the same threads. The rears were 7mm.
Car is sitting on all fours again! Hoo-ray _________________ 1963 Karmann Ghia |
dc Samba Member
Posted: Wed Dec 20, 2017 4:53 pm Post subject: Re: Type 3 Truck - the "other" vw |
Houston we (may) have a problem...
So... when I hooked up the brake hoses to the new set-up, I should have screwed it into the LOWER wheel cylinder, not the UPPER cylinder... correct?
The upper port is for the bleeder this way.
I did it backwards
No wonder it's hard to bleed _________________ 1963 Karmann Ghia |
Posted: Wed Dec 20, 2017 4:54 pm Post subject: Re: Type 3 Truck - the "other" vw |
It shouldn't be a big deal to swap them but you will have to bleed again. |
Posted: Thu Dec 21, 2017 12:49 pm Post subject: Re: Type 3 Truck - the "other" vw |
ataraxia wrote: |
Yup. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
dc Samba Member
Posted: Thu Dec 21, 2017 3:09 pm Post subject: Re: Type 3 Truck - the "other" vw |
All together now - Had to seek pro help AND it's still not quite right - but I drove it around the neighborhood today. The air is out of the system after correctly routing the hoses.
May go lower with the stance, but I'm liking the 14" wheels on there.
So what's the problem?
It's leaking BRAKE fluid.... - after driving around it's pretty clear that the cylinders are leaking. The hoses and bleeders are dry. Can't see the cylinders with everything all bolted together so I'm not sure where it's coming from. Worse on on side. Can't work on it anymore for a while...
Only after I messed with this a couple of times did I read/realize that my DIY zeal did not help me remember/recognize that those pretty NOS Cylinder should have been re-conditioned/properly prepared BEFORE installation.
Now, I will likely have to pull it all apart OR pay someone else to pull it apart and find and address the leaks. _________________ 1963 Karmann Ghia
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Thu Dec 21, 2017 3:37 pm Post subject: Re: Type 3 Truck - the "other" vw |
I would lower it 1-2 inner splines in front! Maybe 1 in back? It's a truck but it should look/handle more like a sports car. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
dc Samba Member
Posted: Thu Dec 21, 2017 3:39 pm Post subject: Re: Type 3 Truck - the "other" vw |
YES! Lower would be cool - I'm heading in that direction. _________________ 1963 Karmann Ghia |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Thu Dec 21, 2017 5:57 pm Post subject: Re: Type 3 Truck - the "other" vw |
Ouch. Yes, NOS cylinders look nice, but if more than 4-5 years old they need to be disassembled, cleaned, and reassembled with all new rubber before they can be used.
I might have missed this, but what was the reason for converting to early brakes? Just curious. _________________ 71 Elm Green FI A/T Squareback |
dc Samba Member
Posted: Thu Dec 21, 2017 7:05 pm Post subject: Re: Type 3 Truck - the "other" vw |
Why wide five? I think it looks better - don’t care for four lug on early cars. Also had my eye on more options with 14” tires and wheels. Wanted to see how bus rims would work. Disc brakes are better and safer but that as not the deciding factor.
I will be patient- always a goal- and order some 22mm rebuild kits. I learned how to do this, which was good practice. I can do it again in a few days! I believe isp West has the kits... _________________ 1963 Karmann Ghia |
dc Samba Member
Posted: Thu Dec 21, 2017 7:44 pm Post subject: Re: Type 3 Truck - the "other" vw |
Btw - went on another short drive around the neighborhood- no leaking. Or much less🤔 _________________ 1963 Karmann Ghia |
Posted: Fri Dec 22, 2017 1:38 pm Post subject: Re: Type 3 Truck - the "other" vw |
You could contact Jim Adney, as he's rebuilt some early wheel cylinders for Pedro. He might have some parts, or part numbers, or a place where you can get them. I don't know if Pedro supplied them, as I never asked either of them that question. I do know Jim had asked the list about them back when he was doing them for Pedro's early T-34 Ghia. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
