vwserphguy Samba Member
Joined: April 30, 2009 Posts: 175 Location: Vail Valley
Posted: Thu May 14, 2009 8:18 am Post subject: brakes on a 58 bus |
i recently bought a 58 bus! ...and it currently has a 65/66 trans axle setup. i want to redo the entire brake system as it has been sitting for 20+ yrs. i am also planning on using a 1500sp with the big nut tranny.
my question is what year brake kit do i want? i would assume i want to use a 66 brake line kit however not sure everything fits correctly on a 58. is the configuration i'm thinking of going to work? Also, any thoughts on where to buy good aftermarket brake kits? thanks. |
Mikee Samba A.D.D. Boy
Joined: March 22, 2004 Posts: 3510 Location: Puyallup WA
Posted: Thu May 14, 2009 9:25 am Post subject: |
If your front beam is original, you need to get brakes for that, 58, and you need to get brakes for a big nut tranny in the rear
as far a brake lines I think they are all the same _________________
localboymark wrote: |
One man's "patina" is another man's cancer. |
bugnut68 wrote: |
I would have kicked the guy right in the dick, balls, ass and face and destroyed his weed. Hippies suck. |
Ian Samba Moderator
Posted: Thu May 14, 2009 9:27 am Post subject: |
Got any pictures of your 58? _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012
**ACHTUNG DO NOT USE AA BRAND PRODUCTS OR BUY ANYTHING FROM PACIFIC PARTS INTERNATIONAL IN CALIFORNIA** |
Posted: Thu May 14, 2009 9:29 am Post subject: |
Go to wolfsburg west website and you can see all the stock replacements, if you want aftermarket stuff check out airkewld _________________
bugnut68 wrote: |
spiderjames Samba Member
Posted: Thu May 14, 2009 9:35 am Post subject: |
As far as the metal lines go the best way is to pull the lines and measure them. Assuming of course that they are correct now and are all there. I am not up on all the different setups for the Buses but I have seen at least two different setups on swing axle bugs. |
Posted: Thu May 14, 2009 9:55 am Post subject: |
thanks for your input... 58 for the front and 66 for the rear was the conclusion i was coming to while i was looking for parts. it does look like the brake lines will work for like 55-67. so i should be ok. i'll just double check with the company i order from but wanted some experiienced second opinion.
just curious if having a consistent setup (66 axles both in front and back) is better (safety-wise) or does it not matter if I'm mixing and matching the years of the axles (58 and 66)? |
Posted: Thu May 14, 2009 11:01 am Post subject: |
vwserphguy wrote: |
it would be cheaper, early front wheel cylinders are expensive _________________
bugnut68 wrote: |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Thu May 14, 2009 12:48 pm Post subject: |
I would recommend that you go with a later model frontend, with the larger drums. Seventy percent of the brakeage is at the front brakes, so you need to update it to conform with the rear brakes. Also, the wheel cylinders will cost a lot less and the link pins will be thicker. _________________ Don't worry; be happy. (Baba) |
twistedbug Samba Member
Posted: Wed May 27, 2009 5:13 pm Post subject: |
hey campy come to live oak and fix bruce's bus before it goes to colorado lol i got the bus in orland |
Culito 11010101
Joined: December 07, 2006 Posts: 5866 Location: Columbia Missourah
Posted: Wed May 27, 2009 5:35 pm Post subject: |
Campy wrote: |
I would recommend that you go with a later model frontend, with the larger drums. Seventy percent of the brakeage is at the front brakes, so you need to update it to conform with the rear brakes. Also, the wheel cylinders will cost a lot less and the link pins will be thicker. |
This is a good idea, but I'm running an early front end with a big nut trans, and can stop on a dime.
I got the Varga front cylinders and I'm two years in with nary a leaked drop of brake fluid. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
