curtis4085 Samba Member
Posted: Tue Apr 24, 2012 5:06 pm Post subject: |
Im so interested in finding this Bobbie guy. I would pay a boat load for a NOS one of these. Lets reproduce this pressure relief valve. If anyone has leads on a NOS 022-115-303A drop me a PM please. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1730 Location: Portland
Posted: Tue Aug 20, 2019 11:53 am Post subject: Re: UPDATED: Need help help finding a NOS part. |
I am looking for one as well _________________ 1978 Sage Green P22 Westfalia
1989 T3 Syncro Single cab
Just a regular guy |
SGKent Samba Member
Posted: Tue Aug 20, 2019 12:19 pm Post subject: Re: UPDATED: Need help help finding a NOS part. |
otiswesty wrote: |
I am looking for one as well |
the new breathers are pretty rare these days. I sold my spare. You might look at the links in this post I made the other day. The diaphragm looks close to the same as the one on the right. AircooledChris made a suggestion to buy as many used ones as you can find. About 50% will still be good.
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
jmstu76 Samba Member
Joined: March 01, 2004 Posts: 1227 Location: Edmond Oklahoma
Posted: Tue Aug 20, 2019 5:08 pm Post subject: Re: UPDATED: Need help help finding a NOS part. |
Any chance GEEBEE might reproduce these? I realize he mostly works in silicone but could he make a simple diaphragm to help out our habit? _________________ James
'76 Deluxe Sage Green Westy
2258 cc GD case 78mm CW crank, 2.0 H-beam rods 5,325” 22mm pin, JE forged pistons with 15cc dish, JE rings, type 11 clearanced oil pump, CB Eagle 2205 Type-2 “Torque Special” hydraulic cam with matched lifters fed by CB Dual Weber 40 IDF MX with 6” foam air filters, currently 55 idle, 130 main, 200 air correction, 32 mm venturis. 27in General Grabber AT2 All Terrains, Berg Shifter, stock '76 exhaust HPC Ceramic Coated. 11/18/2020 |
SGKent Samba Member
Posted: Tue Aug 20, 2019 6:15 pm Post subject: Re: UPDATED: Need help help finding a NOS part. |
that one will work but you will need an adapter made if you want it in the stock position. You can either find an grommet that will fit the metal breather box, or make a plate with a hole in it for a grommet, or run a hose into the base and the outlet to the S-boot _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Tue Aug 20, 2019 6:25 pm Post subject: Re: UPDATED: Need help help finding a NOS part. |
I have that part, I just replaced it on my 2004 Passat. I still have the old one, I'll see if I can hack it to fit.
Anyone have a good "glue" for, what I'm assuming is, ABS, that is readily available at local stores? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
SGKent Samba Member
Posted: Tue Aug 20, 2019 8:45 pm Post subject: Re: UPDATED: Need help help finding a NOS part. |
ivwshane wrote: |
Anyone have a good "glue" for, what I'm assuming is, ABS, that is readily available at local stores? |
the diaphragm in the bus one and the late one like the photo aren't the same size. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Tue Aug 20, 2019 9:41 pm Post subject: Re: UPDATED: Need help help finding a NOS part. |
SGKent wrote: |
ivwshane wrote: |
the diaphragm in the bus one and the late one like the photo aren't the same size. |
I wasn't thinking of swapping diaphragms but instead using the new part and modifying it to fit the breather box.
That is unless you are saying that the new crankcase breather valve, even if it were to fit, wouldn't function similar to the original one. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
SGKent Samba Member
Posted: Wed Aug 21, 2019 7:51 am Post subject: Re: UPDATED: Need help help finding a NOS part. |
ivwshane wrote: |
SGKent wrote: |
ivwshane wrote: |
That is unless you are saying that the new crankcase breather valve, even if it were to fit, wouldn't function similar to the original one. |
the last generation of T4 air cooled engines used a valve like that. It went into a hole in the tower according to the fiche. It should work the same. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6613 Location: Houston, Texas
Posted: Wed Aug 21, 2019 10:08 am Post subject: |
SGKent wrote: |
With new laws coming on smog and a push for higher mileage, my guess is that the US Gov't will try to push every old car off the road that they can - except for maybe parades etc. |
They look for the big smog producers, in the big areas, and in the big cities.
There are no smog tests for motorcycles, lawnmowers, etc. You think they are going to go after a little VW? You are in California. That's the problem. The folks there have tried to convince you the way it is there is the way it is everywhere. _________________ www.vwnos.com [email protected]
Richard J Samba Member
Joined: January 12, 2008 Posts: 3 Location: Lubbock, Tx
Posted: Wed Jan 01, 2020 7:32 pm Post subject: Re: UPDATED: Need help help finding a NOS part. |
I am in need of a PCV valve as well. I cant drive my bus now, because of it. I need a fix, if anyone has something that has worked for them. Has anyone tried using a breather from a 914 and using that style PCV valve?
Please help, I’m getting desperate! I may end up with carbs! |
Posted: Wed Jan 01, 2020 7:33 pm Post subject: Re: UPDATED: Need help help finding a NOS part. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Wed Jan 01, 2020 10:09 pm Post subject: Re: UPDATED: Need help help finding a NOS part. |
Richard J wrote: |
Hi Richard, and welcome! Don't jump the shark just yet; carbs aren't without their own problems.
You can make a "restrictor" for the breather hose that will act as an interim metering valve until you find a good breather. I used one of these LEGO bricks on an old T4 engine for a bit before Aeromech helped me out with a good valve.
Some years of 914 engines used a combo breather/oil cap. I think those can be bolted to a bus breather box if you can make the right gasket/o-ring combo. Make double sure you get the oil cap tight enough on those, otherwise they'll be a vacuum leak.
Good luck,
www.airschooled.com |
SGKent Samba Member
Posted: Wed Jan 01, 2020 11:19 pm Post subject: Re: UPDATED: Need help help finding a NOS part. |
Quote: |
I cant drive my bus now, because of it. |
It should still drive without a good valve unless you have a vacuum leak somewhere like a valve cover or oil cap leaking etc.. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
gkalexdc Samba Member
Posted: Sun Sep 12, 2021 10:13 am Post subject: Re: UPDATED: Need help help finding a NOS part. |
SGKent wrote: |
that one will work but you will need an adapter made if you want it in the stock position. You can either find an grommet that will fit the metal breather box, or make a plate with a hole in it for a grommet, or run a hose into the base and the outlet to the S-boot |
I did just what you said SG KENT. I ordered 06A-129-101-F from Amazon from URO parts. I got the PERFECT grommets at True Value and the brand is GB and the iD is 19mm and the OD is 1". The GB model number is GHG-1575
The pictures tell the tale, it works perfect on the bus. Also, I only paid like $14 for the O6A-129-101-F part. It worked so well, I ordered 5 more spare valves, so that when THESE URO valves go extinct, maybe I will have one. !!
Thanks for all/ and everybody's effort on this endeavor. I am a follower, not a leader, and all of you that helped me understand this dilemma, and have the technical knowledge surely got this problem on the way to being solved.
Dr GK ALEXANDER
Houston |
SGKent Samba Member
Posted: Sun Sep 12, 2021 1:23 pm Post subject: Re: UPDATED: Need help help finding a NOS part. |
that is great. There are only so many solutions, and that one is the easiest where FI is involved. NOS valves of the original style are at this point made of 'no-longer-availabletanium.' I've seen a couple folks 3-d print a copy of the original diaphragm, but the top of the original valves were seam welded on so they don't always come apart cleanly enough to replace the diaphragm. Your solution is as good as it gets. It is even getting hard to find a bad worn out original style one to attempt to fix. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
D52E Samba Member
Joined: August 05, 2019 Posts: 57 Location: Nashville, TN
Posted: Thu Sep 16, 2021 5:23 pm Post subject: Re: UPDATED: Need help help finding a NOS part. |
gkalexdc wrote: |
Dr GK ALEXANDER
Houston |
I think you may have to confirm the valve orientation. It’s possible you have it backwards. I did the same configuration and the crankcase pressure got so high it puked oil out of the dipstick tube. I ended up flipping it around.
_________________ 1977 Bus
2.0 fuel injection
Solid lifters
Manual transmission
GM 105A Alternator |
SGKent Samba Member
Posted: Thu Sep 16, 2021 5:52 pm Post subject: Re: UPDATED: Need help help finding a NOS part. |
D52E wrote: |
...I think you may have to confirm the valve orientation. It’s possible you have it backwards. I did the same configuration and the crankcase pressure got so high it puked oil out of the dipstick tube. I ended up flipping it around.... |
cu and cv type 4 vanagon
D52E Samba Member
Posted: Thu Sep 16, 2021 8:04 pm Post subject: Re: UPDATED: Need help help finding a NOS part. |
Please let us know how it works out. It’s possible I was mistaken in my orientation. _________________ 1977 Bus
2.0 fuel injection
Solid lifters
Manual transmission
