mtbcpa Samba Member
Posted: Sat May 23, 2009 1:26 pm Post subject: Why Won't my Engine Come Out? |
I have a 1969 type II and am trying to remove the engine for a clutch replacement. I feel like I have done everything I need to do (followed all the steps in the dummie guide). I have jacked up the engine and tried to pull it out but it is just not budging. If I look at where it connects to the tranny there is about a 1/2" gap so it seems like I have removed all 4 of the bolts properly. Any ideas as to what I have forgotten to do that would make it not budge? It almost feels like it is in gear or something like that preventing it from sliding out.
I can post up some pictures if needed.
Thanks! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Sat May 23, 2009 1:29 pm Post subject: |
accelerator cable, heater box cables, fuel line, wires to generator/alternator? _________________ Glenn
Member #1009
#BlueSquare |
mtbcpa Samba Member
Posted: Sat May 23, 2009 1:39 pm Post subject: |
Did all of those. Thanks! |
kevin77westy Samba Member
Joined: November 12, 2004 Posts: 795 Location: Ocean Springs, MS
Posted: Sat May 23, 2009 1:54 pm Post subject: |
Did you support the tranny? If the shaft is starting to point down as the tranny sags it will catch a little. If thats not it get under there while your helper moved the motor. You'll find what is catching. Sometimes some tilting and pulling is require for heater box wire connectors and such to not get hung up. |
mtbcpa Samba Member
Posted: Sat May 23, 2009 2:03 pm Post subject: |
Tranny is supported. It feels like something is not unbolted. It doesn't feel like a wire or cable holding it back. Thanks! |
enjoispammy8 Samba Member
Joined: December 26, 2007 Posts: 1984 Location: Long Beach, CA
Posted: Sat May 23, 2009 2:08 pm Post subject: |
try jacking the engine up a little more. mine was stuck as you described, and when i raised the engine up a little and gave it a pull it popped right out. _________________ 1969 Westy, 1690cc. montana red and cloud white.
1969 Standard Beetle [sold]
Watch My Movies: https://www.youtube.com/user/taylorlikesacdc
Desertbusman wrote: |
Is there a message here? Enjoy Spammy Ate |
EZ Gruv wrote: |
Way to fuck up some little kids riding in the car next to you. |
hazetguy wrote: |
you need to be doing better drugs. |
trackwesty Samba Member
Joined: May 11, 2004 Posts: 511 Location: Long Beach, CA
Posted: Sat May 23, 2009 2:11 pm Post subject: |
Push in the clutch are the rear wheels off the ground? Try rocking the bus forward or rotate the wheels if they are off the ground. Is the cross support hanging up on something _________________ AKA The Mummy |
SGKent Samba Member
Posted: Sat May 23, 2009 2:43 pm Post subject: |
step back and eye the angles of everything. Make sure that the engine and the transmission are in the same plane horizontially and vertically. Make sure that the engine and transmission are both supported. Use a wrench to spin the generator right and left to rock the crank back and forth a few times a little. Then pull straignt back again. If it came 1/2 " apart then it is almost out. Most likely when you look at it you will see it is cocked a little and when you straighten it out with the jack it will come right out. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
pjalau Samba Member
Posted: Sat May 23, 2009 4:03 pm Post subject: |
Confirm something for us:
It "seems" like all four bolts are out? There should be four bolts and nuts in your hand. One of them will have a half-circle as part of the head shape - it is the one that connects the starter motor. All four are definitely definitely out. Correct?
Engine mounts are unbolted? they should also be in the pan of disconnected bolts.
-Peter |
Lionhart94010 Samba Member
Joined: January 04, 2005 Posts: 1417 Location: SF Bay Area / Silicon Valley / So Cal
Posted: Sat May 23, 2009 6:08 pm Post subject: |
One other thing you could try, is removing the rear engine cross bar, in certain situations, removing it has made it easier for me to get the engine out... (jack under the engine of course ;0) _________________ Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm |
