aa390392 Samba Member
Posted: Fri May 22, 2009 4:04 pm Post subject: proper installation of engine lid spring |
My recent purchase of my 56 didnt include the w deck lid, so I purchased 1 repop from KSR, which is OK , my question is the proper placement of the spring? to the body, and to the lid itself.
the body recieves the "U" in the spring. correct? is there only 1 groove that it fits into?
And
The eng lid recieves the 2 bends in the spring, but there seems to be 2 different slots they fit into, is it the lower 1's or the 1's near the top?
and after you mount the spring do you then adjust the lid to the body?
any help would be great appreciated. |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Fri May 22, 2009 8:16 pm Post subject: Re: proper installation of engine lid spring |
aa390392 wrote: |
The engine lid receives the 2 bends in the spring, but there seems to be 2 different slots they fit into, is it the lower 1's or the 1's near the top? |
Use the holes near the top edge of the decklid |
Posted: Fri May 22, 2009 8:24 pm Post subject: |
ah thanks .now on the body mount, is there 2 slots or 1 for the u shape of other end of spring? I searchin pic's on samba as I typ |
outoftheoffice Samba Member
Joined: March 02, 2009 Posts: 470 Location: Houston, Texas
Posted: Sat May 23, 2009 1:15 am Post subject: |
Not sure of the year of this one but it appears to be correct EXCEPT for the use of the incorrect holes on the decklid - rareair is correct, the two end points on the spring should be in the two holes closest to the edge of the decklid
And good luck with the install, it usually goes best with two people.
Posted: Sat May 23, 2009 9:45 am Post subject: |
OK that pic helps alot....I agree 2 peeps is better than one. according to what you showed me I did it correctly. |
mtb7001 Samba Member
Joined: February 11, 2009 Posts: 899 Location: Meridian Idaho
Posted: Mon May 25, 2009 6:34 pm Post subject: |
which begs the question.... why 2 sets of holes? _________________ 63 15 window deluxe Turkis walk through 1500
"comfort the afflicted, afflict the comfortable" |
Posted: Mon May 25, 2009 7:43 pm Post subject: |
I know when I installed like the pic shows, hood does not lock into place. |
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4125 Location: Planet VW
Posted: Mon May 25, 2009 8:28 pm Post subject: |
1 person can do it. Hook the body side first, then do the hood holes one at a time. At least the big spring works that way. _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
Posted: Mon May 25, 2009 9:04 pm Post subject: |
aa390392 wrote: |
That's because the pic is showing the incorrect holes being used. Instal the spring in the holes closest to the edge of the decklid
outoftheoffice wrote: |
Not sure of the year of this one but it appears to be correct EXCEPT for the use of the incorrect holes on the decklid- rareair is correct, the two end points on the spring should be in the two holes closest to the edge of the decklid
_________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
SEMCOLL Samba Member
Joined: July 29, 2007 Posts: 16 Location: Fla. panhandle
Posted: Tue May 26, 2009 6:33 am Post subject: |
The reason for the second set of holes is simply to make installation easier. Hook the spring in the "wrong" holes first, then progress to the correct set. |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Tue May 26, 2009 9:52 am Post subject: |
There is an easier still way to do this.
1) install the spring in the decklid, in the hole set closest to the edge.
2) slip the one hinge up on the bracket, but tilting the decklid to that side, leave the spring hanging.
3) thread one of the M6 bolts into the hinge arm through the bracket, but don't tighten it all the way.
4) now pivot the decklid on that bolt, "feed" the spring tongue in to the slot in the bracket on the body as the decklid pivots into the straight across position. Push down on it compressing the spring, using that bolt as a pivot. Once it gets closer, feed the other hinge arm onto its bracket.
I cussed for YEARS until someone told me about that trick... _________________ John Henry
'57 Deluxe
'56 Single Cab
Posted: Mon Jun 01, 2009 1:35 pm Post subject: |
thanks john henry that was the trick, took 5 mins and works like a charm. |
rlutterb Samba Member
Joined: January 10, 2006 Posts: 1393 Location: Carrollton Ohio
Posted: Sun Sep 13, 2009 5:55 pm Post subject: |
this is one of the best tips I've ever read on samba. I put my decklid on in a matter of minutes! _________________ 1973 Super Beetle
1978 Ford F-250
2020 GMC Sierra |
Posted: Sun Sep 13, 2009 6:47 pm Post subject: |
Yep, theres something about the advice gives.its always been right on, I wish I could have him be on the job to show about these windows seals/trim inserts |
Video Bob Samba Member
Joined: November 03, 2005 Posts: 261 Location: Bishop, GA
Posted: Sat Jun 18, 2011 10:39 am Post subject: |
Your hing spring advice lives on John Henry. Thank you Thank you Thank you
Bob Foster _________________ Ya can't have too many Vdubs!
1956 Oval
1966 Beetle
1974 Thing
1974 Super Beetle
1976 Westy P22 |
Bruce Samba Member
Posted: Sat Jun 18, 2011 12:00 pm Post subject: |
mtb7001 wrote: |
which begs the question.... why 2 sets of holes? |
The reason there are two sets of holes is to make the little bracket the same on each end. That way when the bracket was to be installed in the factory, they can't ever install it backwards. Also, installing it is faster when you don't need to check it's orientation. _________________
fcgadget Samba Member
Joined: August 21, 2017 Posts: 111 Location: Willow Glen, CA
Posted: Mon Jun 25, 2018 3:11 pm Post subject: Re: proper installation of engine lid spring |
according to the Bentley manual,
"the tension of a weak spring is increased by placing it in the lower slot" |
