msinabottle Samba Member
Posted: Tue May 26, 2009 2:37 pm Post subject: GoWesty Wiper Mod |
Has anyone had a look at this kit?
http://www.gowesty.com/ec_view_details.php?id=4373&category_id=&category_parent_id=
I have most of the stuff, but what do the wavy washers add? Has anyone tried this? GoWesty has a habit of making neat little mods possible, but is this one of them?
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6235 Location: Portland OR
Posted: Tue May 26, 2009 2:48 pm Post subject: |
A wavy washer is just another form of lock washer. It works just as their product description says; to keep the nuts tight. _________________ 89 Westy 2.1 Auto |
Dogpilot Samba Member
Posted: Tue May 26, 2009 2:49 pm Post subject: |
Funny thing, most other windshield wipers have the wavy washer. It is available separately at most hardware stores in the isle of many drawers section.
It really isn't a bad kit price when you throw in all the plastic bits. _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
hiram6 Samba Member
Joined: September 29, 2006 Posts: 1880 Location: Beautiful South
Posted: Tue May 26, 2009 3:30 pm Post subject: |
timely, as I've been fighting my wipers for the last couple of weeks. I knew I had an almost stripped beyond use wiper post on the driver's side, and I had a replacement in my cabinet that I procured from VC a few months back. Had been procrastinating on doing the repair because it's back in the bowels of the dash behind the instrument panel. I had visions of having to remove the dash to get to it, although I've seen other posts indicating it was possible to get to it just be removing the cluster.
So, over the weekend while searching for a bad ground causing my cooling fans to malfunction, I saw the mechanism back there, and proceeded to knock out that replacement. Much easier than I expected!!
So, I installed the wiper arm back in place with a few tweaks to get it in just the right sweep position. Put on the the original flat washer and nut and tightened it down. I will admit to not getting out the torque wrench, I'm not even sure the Bentley has a spec for this, but I tightened it down to where I didn't think it would slip, but also nowhere near stripping threads tight.
Imagine my irritation today when my wiper arm slipped!! So, dang it, I'm finding some wavy washers!!! And I need two caps, so I might as well order the kit. I need some other stuff anyway, might as well get lots of stuff throw in to make the shipping worthwhile. _________________ 1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning. |
HeftySmurf Samba Member
Joined: June 15, 2008 Posts: 879 Location: Washington, USA
Posted: Tue May 26, 2009 6:15 pm Post subject: |
I ordered me one as well, not bad for 10 bucks _________________ -Lorenzo
90 GL w/ Bostig |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Wed May 27, 2009 5:53 am Post subject: |
Wouldn't just a drop of Locktite stop the nuts from coming loose? _________________ -- 1987 Westfalia automatic (Captain Vino) |
BigNick0 Samba Member
Joined: September 14, 2007 Posts: 112 Location: Asheville, NC
Posted: Wed May 27, 2009 7:03 am Post subject: |
hiram6 wrote: |
timely, as I've been fighting my wipers for the last couple of weeks. I knew I had an almost stripped beyond use wiper post on the driver's side... |
Is the threaded part where the nut attaches stripped? Or are you talking about the splined shaft being stripped? It's very rare for the shaft itself to actually strip, since they are harder than the material the wiper arms are made out of.
You should take the wiper arms off, and clean-out the splines on the shafts that the arms sit on. The wiper arms are a soft metal and the shafts are supposed to "bite" and cut little grooves into the arms. As soon as the shafts strip the grooves they've cut, then no amount of tightening of a nut, or washers will really do the trick.
Take the arms off, and use an exacto blade to scrape the little slivers of soft metal out of all the grooves in the shaft. Re-attach old arms and new grooves will be cut as you tighten the nuts. No more slipping wiper arms.
Goodluck. |
Posted: Wed May 27, 2009 10:58 am Post subject: Dental Pick |
I used a dental pick to clean out all the gunk on Winston's splines--and I did use Loc-Tite. And I accidentally bumped the wiper at VW's on the Green and it shifted noticeably. Hence, my interest in this mod. The measurements for where to have the wipers 'at rest' are in the Bentley.
Would anyone know what size of wavy washer to install for those of us who just need to do that to have the complete mod?
Posted: Wed May 27, 2009 11:56 am Post subject: |
Since I believe the wiper shafts are in metric, you may come into the issue 1/4" is too small and 5/16" too big. Personally, I usually get a set of each, as they tend to be in the .30¢ range as the gas going back isn't worth it. Your Ace may stock ones in Metric, Denver being the big city and all. Out here in the sticks, electricity is still novel. I have had to drill out washers for the Westy before to fit a metric bolt, but these are spring steel so you may have bad luck drilling, you need to grind those with a Dremel and a small stone if they are too small. _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
hiram6 Samba Member
Posted: Wed May 27, 2009 12:16 pm Post subject: |
BigNick0 wrote: |
hiram6 wrote: |
Goodluck. |
No, what had stripped was the threads where the nut tightened down. I know all about cleaning out the grooves, I have a set of dental pics in my toolbox just for that purpose. I had already tried to repair the threads with a die, but not enough good metal left.
The new part, as seen here from van cafe, has pristine threads, well worth the piece of mind.
1996 Mazda Miata
ddonnell Samba Member
Joined: September 04, 2007 Posts: 373 Location: Sunset Beach
Posted: Thu May 28, 2009 5:20 pm Post subject: |
I just got the wiper caps from West Coast Metric. I think it was less than two bucks, so if you just need two, go there. Although they did charge me up the yin yang for shipping...
GoWesty's product is probably sturdier and better well made though...so I recommend GoWesty if you need all three as well as new hardware. _________________ 1990 Vanagon Carat-SOLD
1995 Dodge Ram 2500 4x4 V10
1966 Baja "The Beast"
instagram #bajabugproject |
Posted: Fri May 29, 2009 3:59 pm Post subject: Curse You, Dog Pilot! |
Curse you, Dog Pilot!
Well, not really, James is far too nice and far too heavily armed for real cursing...
BUT!!
That wavy washer diameter you gave was O.D! I just bought two 14mm I.D. wavy washers! AND THEY DON'T WORK!!!
Growl.
You want 15 or less mm. OUTER DIAMETER wavy washers, folks.
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Fri May 29, 2009 4:33 pm Post subject: Re: Curse You, Dog Pilot! |
msinabottle wrote: |
BUT!!
Growl.
Best! |
Yeah but I bet you charge up the ying yang for shipping. |
goffoz Samba Member
Posted: Sat May 30, 2009 11:15 am Post subject: Re: Dental Pick |
I used a dental pick to clean out all the gunk on Winston's splines--and I did use Loc-Tite. ! |
Another tool you can use for this...I think it works better...is a jewellers file...get a good quality 3square (triangle) ...Swis or german made.. from a jewelers supply house they run about $7ea
Very nice precise teeth and a wicked sharp tip..I use a 2cut (6=fine.0-coarse)
You can recut the splines full lenght, with ths |
Robw_z Samba Member
Posted: Sat May 30, 2009 2:55 pm Post subject: |
[quote="hiram6"][quote="BigNick0"]
hiram6 wrote: |
are you sure it's worth that?
-Rob |
Posted: Sat May 30, 2009 5:50 pm Post subject: |
The problem with the wipers is that the stock washer will not fit down over the splines at all, so once the wipers arms have any wear at all, you just end up tightening the washer against the shaft while putting little or no pressure against the wiper arm itself.
The answer is a thick flat washer with a big enough hole to fit over the splines. I do not know the fit of the parts in the Go Westy kit, but since it contains an added flat washer (which isn't stock, but the wavy washer is) I would assume that this additional washer must have the big hole and be thick enough to do the job.
The price looks good. Someone should buy the kit and tell us what it really does, the Go Westy description of the kit make no sense and is probably plain wrong.
If the arms are stripped out bad enough you might want to buy new arms at the same time you add the kit. |
hiram6 Samba Member
Posted: Sat May 30, 2009 7:44 pm Post subject: |
[quote="Robw_z"][quote="hiram6"]
BigNick0 wrote: |
hiram6 wrote: |
-Rob |
Rob,not sure what you're getting at. My post had completely damaged threads, beyond repair. So no matter what washer combination I used, I wasn't going to get enough grip to hold the wiper.
So, yes, it was worth it. I drove about 800 miles this weekend, in and out of thunderstorms multiple times, never had to worry for one second about my wiper losing it's place. _________________ 1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
randywebb Samba Member
Posted: Sun May 31, 2009 1:52 pm Post subject: |
wrong word choice... |
hiram6 Samba Member
Posted: Sun May 31, 2009 2:00 pm Post subject: |
okay, caught it. Spell-check strikes again, in combination with my horrible typing skills _________________ 1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
Posted: Thu Jun 04, 2009 6:33 am Post subject: Re: Curse You, Dog Pilot! |
You want 15 or less mm. OUTER DIAMETER wavy washers, folks. |
They are 6mm spring washers _________________ -- 1987 Westfalia automatic (Captain Vino) |
