Early popes nose on a 56/57 deck lid
thompam
thompam is offline
PostPosted: Thu May 28, 2009 12:45 pm    Post subject: Early popes nose on a 56/57 deck lid Reply with quote
Hi all,I purchased a 57 deck lid to replace my shaved 57 deck lid and want to put the early popes nose light off of a pre 55.Has anybody done this and if so how much extra work is it.Thanks,Andy
FRK Premium Member
FRK is offline
PostPosted: Thu May 28, 2009 1:19 pm    Post subject: Re: Early popes nose on a 56/57 deck lid Reply with quote
You mean pre-'53! Oval W decklids have the pope nose hole wider. I guess if you can get the metal part/area around the pope nose from the split decklid you can weld it to the oval decklid. Compare it to thise pictures.
Oval W decklid ('53-'57)
Split W decklid ("52 down). This one is (I think) '50- '52
Here is the pope nose for a split & the oval.
Split:
oval
"RVA" VW Club
July '55 L320/L321 US Karmann Kabriolett
Nov. '50 L11 11G
Feb. 50 L11 11A
March '49 L32 11 Deluxe
Aug. 48 L41 11
thompam
thompam is offline
PostPosted: Thu May 28, 2009 2:26 pm    Post subject: Re: Early popes nose on a 56/57 deck lid Reply with quote
This is just what i was talking about.Not real good with my years but you know what i am looking for.I did'nt want to buy one if i could'nt make it work.The width and height look close and i can fab up a piece for the bolt hole location.Thanks!
Split:
oval
HerrrKafer
HerrrKafer is offline
PostPosted: Thu May 28, 2009 7:35 pm    Post subject: Reply with quote
Repro split decklids are now being made. That would be the best route to take for putting a Pope's nose on a '57 if you don't want to cut out that section of metal and fabricate the earlier style pressing.
Evan H.
In a perfect world, anyone running chromies would be shot.
Attellier 94
Attellier 94 is offline
PostPosted: Thu Apr 10, 2014 10:02 am    Post subject: Popoes Nose Reply with quote
Does anyone make a repro Popes Nose ? Any info will be appreciated....
Blue Baron
VW Aficionado
Blue Baron is offline
PostPosted: Thu Apr 10, 2014 12:38 pm    Post subject: Reply with quote
I have the housing available in fiberglass. PM me if you're interested.
Heinz Nordhoff
Zvonimir1985
Zvonimir1985 is offline
PostPosted: Tue Feb 14, 2017 9:53 am    Post subject: Re: Early popes nose on a 56/57 deck lid Reply with quote
Is there any difference between 53 and 60 nose?
Proud to be Croat!
tasb
The Distributor Distributor
tasb is offline
PostPosted: Tue Feb 14, 2017 10:59 am    Post subject: Re: Early popes nose on a 56/57 deck lid Reply with quote
Yes, see above.
Roads Scholar & distributor restorations
1956 oval third owner 36 hp- slow drag Champion 2012, 2014, 2015, 2017 sold to a good new home
1960 sunroof beetle owned since 1991 36 hp moved on after 32 years of stewardship.
Mr. OGPaint
Mr. OGPaint is offline
PostPosted: Tue Feb 14, 2017 11:11 am    Post subject: Re: Early popes nose on a 56/57 deck lid Reply with quote
Above doesn't describe the difference, but yes any oval window era decklid nose is different than 1960. The oval era nose has more curves on the upper edge to fit the more defined W-decklid of 1957 and earlier
https://instagram.com/mr.ogpaint
Patrick Hall
