54 seat frame color
mmilliganclark2
mmilliganclark2 is offline
PostPosted: Sat May 30, 2009 5:30 pm    Post subject: 54 seat frame color Reply with quote
I have a 54 deluxe and am going to paint it iceland green. What would be the color for the seat frames, ebrake, shifter and steering column? What other interior pieces should be painted that same color?
1967 Fasty
El Guero
El Guero is offline
PostPosted: Sun May 31, 2009 10:19 am    Post subject: Reply with quote
Ive been told light beige.
Praise the Lowered...
mmilliganclark2
PostPosted: Sun May 31, 2009 11:13 am    Post subject: Reply with quote
So the interior pieces should be light beige for all exterior colors in 1954? I thought some exterior colors had black interior pieces???
1967 Fasty
cvallone
cvallone is offline
PostPosted: Tue Jun 02, 2009 7:10 pm    Post subject: Re: 54 seat frame color Reply with quote
I hear all different colors on these forums from light beige, Ivory, cream white, etc. I used "Almond" by Rustoleum, looks pretty damn good. You can get them from Home Depot.
cv
My restos www.classicvwbugs.com
Restoring Beetles back to their historical beauty.
aa390392
aa390392 is offline
PostPosted: Wed Nov 10, 2021 11:45 am    Post subject: Re: 54 seat frame color Reply with quote
I discovered on my OG interior, Savanna beigh is so very close..and I have shit load of beighs/ tans
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet
FritzCP
FritzCP is offline
PostPosted: Wed Nov 10, 2021 4:24 pm    Post subject: Re: 54 seat frame color Reply with quote
From "The Car of the Century"
L75 Light Beige on Deluxe Models (Black on standards)
Steering Column
Gear Lever
hand brake lever
L567 Ivory on Deluxe Models (Black on Standard)
Steering Wheel
Turn signal case
Horn button case
041 Black on all
Gear lever boot
hand brake boot
011 Ivory Plastic on Deluxe - Same as L567 ivory paint
shift and heat knob
Window crank knob
all escutcheons
all dash knobs
rear ashtray knob
hand brake button
Seat Frames and luggage bars - no color given.
Split Beetle dash pods are often repainted with Rustoleum Gloss Almond spray can paint which matches the OG pods nearly 100% per pod restorers and i myself compared it to an OG deluxe pod. I cannot find the factory dash L code color listed for the deluxe pods, but its probably the Ivory since the dash knobs, window knobs and escutcheos are that color so Almond would be closest match for those items.
I have an Iceland Green 54 with OG painted interior bits, and I would say the seat frames are light beige same as the steering column and gear lever, as its not the exact same and is a tad darker in tone than the steering wheel (Ivory). that said, the colors are so close when i redo mine, Im going to use the Rustoleum Gloss Almond paint color for all of the bits and call it good.
Fritz Custom Products
Fritz 10 - Tin Screw Torquer
Fritz 124 - Crank Pulley Puller
Fritz 70 - 6306 Bearing Puller
Fritz 44 - Dizzy Puller
Dan22
Dan22 is offline
PostPosted: Thu Nov 11, 2021 10:24 am    Post subject: Re: 54 seat frame color Reply with quote
Wolfsburg West says it is supposed to be L275 based on their spray paint descriptions.
1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074
janerick3
janerick3 is offline
PostPosted: Thu Nov 11, 2021 4:50 pm    Post subject: Re: 54 seat frame color Reply with quote
Agree 100%. L620/L10N Savannah Beige is a near perfect match for 1953-55 deluxes. I used it to repaint my horn button and touch up the e-brake handle and shift lever on my '54. It is too dark for '56-'60 and way too light for pre-Zwitters.
Thanks,
Jan K.
Iowa Mark
Iowa Mark is offline
PostPosted: Fri Nov 12, 2021 8:28 am    Post subject: Re: 54 seat frame color Reply with quote
Whenever there is a posting about the "correct" paint color I'm reminded of an old friend that ran a Sherwin Williams store. People were always wanting that perfect off white color and shades of whites were the most chips the company showed. After hours of trying to decide, he would reach under the counter and pull out a sheet of stop sign red and hold it next to any of the customer's off white samples. They all looked "white". Crying or Very sad
aa390392
aa390392 is offline
PostPosted: Fri Nov 12, 2021 10:45 am    Post subject: Re: 54 seat frame color Reply with quote
Thank you…
55 ragtop
56 delux sedan
56 Kabriolet
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Fri Nov 12, 2021 1:45 pm    Post subject: Re: 54 seat frame color Reply with quote
Steering Column
Gear Lever
hand brake lever
Steering Wheel
Turn signal case
Horn button case
041 Black on all
Gear lever boot
hand brake boot
shift and heat knob
Window crank knob
all escutcheons
all dash knobs
rear ashtray knob
hand brake button
X2
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
aa390392
aa390392 is offline
PostPosted: Fri Nov 12, 2021 5:42 pm    Post subject: Re: 54 seat frame color Reply with quote
“Light beige” …… covers a lot of beiges. Included “ savanna beige”. Which I found to be perfect match…which Temple paint provides..
Thomas Wink
55 ragtop
56 delux sedan
56 Kabriolet
