sled Samba Member
Posted: Sun Jun 07, 2009 7:00 pm Post subject: 40 DCNF 2007cc compatibilty? |
alright, well I just got a set of never used DCNF 40's...NOS??
I am wondering if these carbs will support a 120-130 horsepower 2007cc engine? I was told I could get the vent's up to 37mm from the 32 mm stock. Is this feasible? and would it allow the carbs to feed the engine enough?
I am not stuck on using these carbs, but I love the way they look as opposed to some IDF's
Also, through research I have read that these carbs have issues with fuel starvation under hard cornering? These will be used a vintage road race car that will be going around corners as hard as it can. Am I just asking for performance issues?
_________________ drive your split. |
Cuog Samba Member
Joined: July 15, 2008 Posts: 509 Location: Richmond VA
Posted: Sun Jun 07, 2009 9:52 pm Post subject: |
I don't know for sure how big you can go with vents, however I can tell you that the vents are compatible with those in the 42mm DCNFs, so that will give you a little idea how big you can go as you can go at least as big as the vents in those do.
I just wish my pair of 40's were anywhere near that clean, nice find.
Edit: http://www.jalopyjournal.com/forum/archive/index.php/t-131462.html I did a little searching, in that thread, I found a guy running 36mm vents on a set of 42 DCNFs, so those should drop right in if you can find yourself a set of them. |
robert olmsted Samba Member
Joined: February 14, 2007 Posts: 71 Location: Queens, NY
Posted: Sun Jun 07, 2009 11:12 pm Post subject: |
Hi Sled,
I have a set of the 42dcnf's and they do not do very well on tight, long corners. Other than that I love em. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Mon Jun 08, 2009 5:43 am Post subject: |
There was a good reason Weber disconntuined the DCNF's and centered the floatbowl on the IDF's!! Get some 44IDF's and have fun _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
sled Samba Member
Posted: Mon Jun 08, 2009 8:29 am Post subject: |
ok, so does anyone know if there are any modifications that can be made to help with the 'fuel slosh' in corners?
also, any opinions on if these carbs will support the power I am looking for?
I dont want to have to fall back on some IDF's if I dont have to. _________________ drive your split. |
volksnut Samba Member
Joined: November 16, 2002 Posts: 380 Location: winter park, florida
Posted: Mon Jun 08, 2009 11:33 am Post subject: |
DCNF's rock. I've had 40's and 42's. Some like them some hate them, can't do no autocrossing with them but they'll support your 2 litre fine, I had 36 Dells on my 2017 and it ran 14's in the 1/4 with full weight sedan go for it and nice find! Throw a post over at www.cal-look.com lot of people still run them |
henrym Samba Member
Joined: August 19, 2006 Posts: 1002 Location: Marina Del Rey, California
Posted: Mon Jun 08, 2009 1:34 pm Post subject: |
I have Mark Harney refurbished 42 DCNF's on my 2110 and they run just fine. No hesitation, no popping or stumbling whatsoever and they pull hard. I can tell you that that the larger vents are tough to find and kind of expensive. Good luck. _________________ 1967 Bug (Second owner) |
sled Samba Member
Posted: Mon Jun 08, 2009 1:45 pm Post subject: |
cool, thanks for the replies.
so, it sounds like the biggest issue is the lack of hard cornering ability. This car will be thrown around corners with near reckless abandon, SO...I might end up havnig to choose a different carb Unless anyone knows any tips/tricks to get them to hold fuel delivery
as far as the vents, is it possible to take the stock 32's and machine them out to 36 or so? then contour the leading edge? _________________ drive your split. |
Cuog Samba Member
Posted: Mon Jun 08, 2009 1:47 pm Post subject: |
sled wrote: |
as far as the vents, is it possible to take the stock 32's and machine them out to 36 or so? then contour the leading edge? |
If you're good with a steel lathe(or know someone that is) then it shouldn't be a problem. |
sled Samba Member
Posted: Mon Jun 08, 2009 2:22 pm Post subject: |
cool, then it wont be a problem _________________ drive your split. |
Cuog Samba Member
Posted: Mon Jun 08, 2009 3:16 pm Post subject: |
sled wrote: |
cool, then it wont be a problem |
Just remember getting them all the same is more important than getting the maximum size out of them so take it easy. |
sled Samba Member
Posted: Tue Jun 09, 2009 8:54 am Post subject: |
thanks for the tips. It sounds like I will keep them, but I am still worried about the fuel slosh aspect of them
anyone ever heard of float bowl modifications? _________________ drive your split. |
