Help Needed....Radius Arm Bushing Sleeve Replacement?
PDXWesty
PDXWesty is offline
PostPosted: Mon Jun 08, 2009 9:53 am    Post subject: Help Needed....Radius Arm Bushing Sleeve Replacement? Reply with quote
This part is NLA from vendors and VW. Mine are almost dust and I'm going to rebuild my front end. Has anyone had to replace this? What did you use? I think a piece of pipe the right size would work but I wondered if anyone else has come up with something the correct size.
Van Cafe said they are searching for a replacement but haven't come up with anything.
Thanks!
http://www.van-cafe.com/home/van_1244479401810/page_309_1003/radius_arm_bushing_sleeve.html
89 Westy 2.1 Auto
syncrosimon
syncrosimon is offline
PostPosted: Mon Jun 08, 2009 10:19 am    Post subject: Reply with quote
Got mine from Brickwerks in the UK.
The dimensions of the piece were discussed on club 80-90. Cant find them though but will keep looking. Easy for a machine shop to make.
http://www.brickwerks.co.uk/index.php?page=shop.pr...p;Itemid=6
1991 16" 2.1 DJ Syncro factory hightop ex Finnish Army Ambulance, now sold.
Thinking about Thing or 181 (182) ownership.
insyncro
Banned
insyncro is offline
PostPosted: Mon Jun 08, 2009 5:35 pm    Post subject: Reply with quote
I am currently working on having these and other sleeves in the Vanagon suspension produced in stainless steel.
My partner needs the exact specs of a new sleeve and he will make them.
We are waiting on new sleeves from another source to reproduce.
Our target price will be $15-$20 a sleeve at the moment.
I will keep this thread informed as too how we are making out.
If anyone has this sleeve brand new and is willing to measure it and or will ship it to me so I can measure it, I will pay shipping and give them a set of stainless sleeves once produced.
dylan
crazyvwvanman
crazyvwvanman is offline
PostPosted: Mon Jun 08, 2009 6:09 pm    Post subject: Reply with quote
I'm pretty sure I have a set or 2 of new ones on hand. Do you still need measurements?
Mark
dylan
kobylan
kobylan is offline
PostPosted: Mon Jun 08, 2009 6:15 pm    Post subject: Reply with quote
I just bought a complete set a couple of months ago. No problem getting them from VW. Have you tried www.1stvwparts.com ?
86 Westy
Vanagon Nut
Vanagon Nut is offline
I got lucky when doing radius arm work on my '81. Got two of the last few, if not the last 2, that were available to my parts guy.
FWIW, I too thought one could use pipe. I forgot to measure my new ones while still in hand. Meant to do that.
Again FWIW, the metal they're made of is *likely* harder than mild steel. On my '81, the rubber bushings were so worn.... "how worn were they?" .... they ovaled the hole in the subframe. Point is, ovaled hole seemed to take more of a beating that the sleeve and arm.
http://tubaneil.googlepages.com/radiusarm
Neil.
1981 Westy air cooled to 15º ABA swap: http://tinyurl.com/y9n4xob8
50º ABA Swap in to '88 Westy: http://tinyurl.com/yap5hpwt
Vanagon VAG GAS engine swap Google Group:
https://tinyurl.com/2f24rmh
VE7TBN
PDXWesty
PDXWesty is offline
PostPosted: Mon Jun 08, 2009 6:49 pm    Post subject: Reply with quote
I called VW. They are NLA. Anyone have a set they want to sell? Please post the dimensions if you have them. Thanks!
89 Westy 2.1 Auto
squeegee_boy Premium Member
squeegee_boy is offline
PostPosted: Mon Jun 08, 2009 7:58 pm    Post subject: Reply with quote
I bought some from GoWesty last month. I had to call, though, because they weren't listed on the site.
Robyn
1984 FrankenSyncro Westy. EJ25 RMW kit
1971 Super Beetle with an EJ22. Oh yes. Daily driver
PDXWesty
PDXWesty is offline
PostPosted: Tue Jun 09, 2009 9:07 am    Post subject: Reply with quote
Thanks to Mark who sent me the measurements:
56 mm long - 2 3/16”
25 mm outside diameter - 1”
19 mm inside diameter –3/4”
So I'll post the info if I can find a standard pipe or fitting that works. It's almost the size of a 3/4" Sch 80 pipe. OD=1.05" ID=0.742"
It doesn't look like the price for stainless pipe is that bad.
http://www.onlinemetals.com/merchant.cfm?pid=960&a...;top_cat=0
Thanks! -Rick
89 Westy 2.1 Auto
crazyvwvanman
PostPosted: Tue Jun 09, 2009 9:25 am    Post subject: Reply with quote
I too noticed how close it was the Schedule 80 steel pipe. I found a place online that sells stainless pipe cut to length and was thinking about ordering some already cut to size. The cost is a bit high for a speculative effort so if someone has a scrap of Sch 80 steel pipe we can test fit that would be great.
edit: I ordered 4 pieces cut to 2.20", if/when it comes I will try the fit. The cutting they offer is not precise, only as a minimum length with it allowed to be 1/8" over that. I anticipate having to use the bench grinder to finish it off.
Mark
Thanks! -Rick
teej
teej is offline
PostPosted: Sun Sep 11, 2011 6:42 am    Post subject: Reply with quote
FWIW, some more information on sourcing these: I just received a set from gw.
Disappointed in quality, they are pretty sloppy pieces of work. Nice beefy stainless but they also were cut imprecisely, unquare ends all 4 ends, slightly different lengths. Mulling my options: reuse old, return these, or dress the ends and use these anyway.
Have others who have purchased these from said vendor been satisfied?
1986+ Wolfsburg Weekender Pop-Top 2.3 WBX
insyncro
Banned
insyncro is offline
PostPosted: Sun Sep 11, 2011 7:25 am    Post subject: Reply with quote
I have purchased all available over the years.
I have VW units that are cut and beveled on each end.
I still am in the process of having these sleeves and other suspension parts reproduced from the original VW parts.
It is a slow process.
I will inform the lists and forums when they are ready for sale.
dylan
indytriple
indytriple is offline
PostPosted: Sun Sep 11, 2011 7:40 am    Post subject: Reply with quote
I bought some of these several months ago from GW with the intention of doing some front end work. I never did. I just went out to the garage to inspect them, and sure enough, they definitely are NOT square on the ends, and they are different lengths by almost 2mm per my calipers. I'm not sure if it matters or not, but yes, they don't look to be precision craftsmanship. Should I send mine back as well or does precision even matter in this particular part?
"See The Glass As Already Broken."
87 Vanagon Westy Auto Bostig
www.bluegrassbicyclecompany.com
insyncro
Banned
insyncro is offline
PostPosted: Sun Sep 11, 2011 8:15 am    Post subject: Reply with quote
The replacement parts need to be the same size and finish...IMHO.
a914622
a914622 is offline
PostPosted: Sun Sep 11, 2011 8:27 am    Post subject: Reply with quote
PDX
Run out to your local trade collage and give them a quick drawing with dim. and an idea of the material.
That part would take less than ten munites to make on a manual lathe. That is the perfect project for the students.
With a cnc it should be less than 2 min to make. If you get up by Leapold/Stevens there is a costco west of there. across the parking lot there is a shop that should be able to help you out.
jcl
87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru
James 93SLC
James 93SLC is offline
PostPosted: Sun Sep 11, 2011 8:29 am    Post subject: Reply with quote
Bought mine from the Samba classifieds.
Have not installed them yet, but they are nice quality and made from heavy stainless tubing. Great seller and price.
http://www.thesamba.com/vw/classifieds/detail.php?id=1106616
91 Vanagon Carat
93 Corrado SLC
Photos: http://picasaweb.google.com/slc.corrado
tencentlife "Sometimes a pooka is a problem and sometimes it's just a pooka"
insyncro
Banned
insyncro is offline
PostPosted: Sun Sep 11, 2011 8:31 am    Post subject: Reply with quote
Judging by the picture, these were cut with a hacksaw and not beveled either.
Par for the course.
insyncro
Banned
insyncro is offline
PostPosted: Sun Sep 11, 2011 8:32 am    Post subject: Reply with quote
The edge bevel I am referring to is found on the Syncro 16 sleeves I own.
I am having all replacements beveled.
James 93SLC
PostPosted: Sun Sep 11, 2011 8:37 am    Post subject: Reply with quote
Thanks! -Rick
The ones I bought from here:
Using my Mitutoyo calipers they measure.
Length = 56.12mm
OD = 25.35mm
ID = 19.7mm
91 Vanagon Carat
93 Corrado SLC
James 93SLC
PostPosted: Sun Sep 11, 2011 8:39 am    Post subject: Reply with quote
There are saw marks. But they are square cuts.
Maybe he uses a band saw.
91 Vanagon Carat
93 Corrado SLC
