How to: Open a stuck hood
NOTAHONDA
Vegas Don
NOTAHONDA is offline
PostPosted: Fri Jun 19, 2009 1:00 pm    Post subject: How to: Open a stuck hood Reply with quote
Seems like theres alot of topics on how to open a stuck hood that wont open due to a broken or stretched cable or some other reason. This just happened to me so I took pictures and show how to open it. Theres no need to cut a hole to reach in or other destructive methods, this take under 5 mins.
First off, you need to cut the handle in half with a grinder, air cutoff wheel, etc.
Once its cut in half cut twist each side to your left, this will unscrew the nut.
Thats it, the hood should lift right up. Just get a new or used handle and fix the problem that made it get stuck..
outoftheoffice
outoftheoffice is offline
PostPosted: Mon Jun 22, 2009 7:55 am    Post subject: Reply with quote
Wow, very useful information. Thanks for posting
Juice C
Juice C is offline
PostPosted: Sat Jun 27, 2009 2:16 pm    Post subject: Reply with quote
I've never thought of that. Its genius.
dantrefethen
dantrefethen is offline
PostPosted: Sat Jun 27, 2009 10:49 pm    Post subject: Reply with quote
Also a good way to get into your locked car, lost keys.
Cut off the handle, go in through the the glove box
Dan
Deluxe Lowlight Ghia
Deluxe Lowlight Ghia is offline
PostPosted: Sat Jun 27, 2009 11:47 pm    Post subject: Reply with quote
Dan
remember if a theif wants your car bad enough he/she will get it no matter what you do
These vws are cool but the people who own them are far more valuable. Keep friends close they can be taken away overnight.
57 ghia
“57 factory safari 11 window”
59 patina ghia
61 patina Ghia
71 bus
74 thing
75 half bug
Eric&Barb
Eric&Barb is offline
PostPosted: Thu Jul 02, 2009 9:33 pm    Post subject: Reply with quote
While that will work, first try this. Shove downward three times on the hood handle. Then most likely the hood latch will pop open without needing one to be destructive.
Hood latches are a three position latch.
1. broken cable or loose cable and open goes the latch when the friction is released from shoving downward.
2. Properly adjusted cable keeps latch in closed position.
3. Pulled cable and latch swings away from position 1 to open normally.
In Stereo, Where Available!
1973 MELLOW YELLOW
1973 MELLOW YELLOW is offline
PostPosted: Fri Jul 03, 2009 4:04 pm    Post subject: Reply with quote
If EVER adjusting or working on the bonnet release mechanism, you should remove the spare wheel. If for any reason the bonnet (hood?????) wont open, reach in with a ratchet and extension and undo to nuts on either the handle, latch or both. The flex from even having these slightly loose will enable you to open the bonnet with one sharp tug.
I always screw up adjusting the cable and this has been a real life saver! The first time I did it it was just coincidence that the wheel was out but after that, I ALWAYS remove it if I am doing anything remotely to do with the release! Wink
hitest
hitest is offline
PostPosted: Wed Aug 19, 2009 8:29 pm    Post subject: Reply with quote
Unfortunately, a working return spring makes all the above advice moot.
There's no way one could do battle with my '63's hood handle in such a manner.
FU#5
Eric&Barb
PostPosted: Wed Aug 19, 2009 8:32 pm    Post subject: Reply with quote
You mean the spring in your hood latch is/was missing/broken??
58volks
58volks is offline
PostPosted: Thu Aug 20, 2009 9:05 am    Post subject: Reply with quote
AWW SH*T !!!! 5 days before this was posted I had to cut my spare wheel well!!
It was the wrong year front anyway......
rgambord
rgambord is offline
PostPosted: Sun Nov 08, 2009 5:32 pm    Post subject: Reply with quote
I know of another method involving the glovebox and a midget...
63Shagginwagen
63Shagginwagen is offline
PostPosted: Wed Feb 17, 2010 11:54 am    Post subject: Reply with quote
Dan
I know this post is waaayyy old. But I just lol'd in the middle of my class and got a few stares. Great visualization! haha
new sig.
Daily- '63 Beetle, Restoring- '71 Super
Rare for sale - Ask for details - Limited time only!
fastonthetrack
fastonthetrack is offline
PostPosted: Wed Apr 06, 2011 12:51 pm    Post subject: Reply with quote
Old post, but i'm having a weird issue with my latch on my 69. Sometime i just push the button and the hood opens, and other times it just wont open not matter what i do to the latch.. I cant figure it out!
wjoef
Location: Vancouver, no, not that one, the original one
wjoef is offline
PostPosted: Wed Apr 06, 2011 1:09 pm    Post subject: Reply with quote
My wife's car ('73 standard), had occasional problems with the hood not wanting to open also.
Close inspection of the seal retaining flange (the flange that holds the rubber seal in place), revealed / indicated that the hood was catching on the flange (or vice versa).
I took a body hammer and dolly and carefully "smoothed" out the flange and the edge of the hood. No more problems with the hood getting stuck closed.
Mine: 1966 Karmann Ghia coupe
Wife's: 1973 Standard Beetle, her daily driver
Karmann Ghia - a German Alfa Romeo or an Italian Porsche?
BluegrassMan
BluegrassMan is offline
PostPosted: Thu Feb 09, 2012 10:37 am    Post subject: Reply with quote
I have what is supposed to be a 67. I cannot find where or how the hood is supposed to open. There is no holes in the glove box or anyhting I can find that looks like a release lever. I am hesitiant to cut off the handle until I can try to figure out how it is supposed to open or where that release cable might be.
Advice and info greatly appreciated
Snydr
Snydr is offline
PostPosted: Thu Feb 09, 2012 10:40 am    Post subject: Reply with quote
From the Type 1 '67 Manual (see: THE KNOB): http://www.thesamba.com/vw/archives/manuals/bug67models.php
- e
'63 Beetle Ragtop - (Build in progress)
'00 Jetta 1.8T
61SNRF
61SNRF is offline
PostPosted: Thu Feb 09, 2012 10:53 am    Post subject: Reply with quote
The knob is number 10 here (from the same book Wink )...
-Bruce
An ounce of prevention is worth a pound of cure.
BluegrassMan
PostPosted: Thu Feb 09, 2012 11:31 am    Post subject: Reply with quote
Thanks for that. So I went ahead and cut the handle. But now at least I have that hood open.
jkbnoble
jkbnoble is offline
PostPosted: Tue Jul 03, 2012 8:39 am    Post subject: Stuck hood Reply with quote
Thank you very much for the reply! This was the only way I could think too!
TCBeier
TCBeier is offline
PostPosted: Mon Jul 09, 2012 10:30 pm    Post subject: Reply with quote
Dan
how can you go through the glove box? The screw holding it in is under the bonnet.
Here's to women, that wonderful vine. She blooms every month, bears every nine. She is the only creature this side of hell...can draw juice from a nut, without crackin' the shell. - CHEERS!
http://www.thesamba.com/vw/forum/viewtopic.php?t=525849&highlight=stute
http://stutethewonderbug.blogspot.com/
