icekoffee Samba Member
Joined: March 14, 2005 Posts: 1239 Location: DeSoto, Missouri
Posted: Sun Jun 21, 2009 7:36 pm Post subject: Early trans to 66 reduction boxes... Question |
I have a 60 single cab.... my brakes blew and i had to take the passenger rear brake drum off to replace the wheel cylinder. Its stuck on the reduction box axle.... i have tried everything to get it off with no luck. but now my axel to the reduction box is totally screwed. I doubt i will be able to find the axle i need but i do have the reduction boxes from a 66 bus. My question is.... Whould i be able to take the long axles and reduction boxs off of the 60 single cab and put the ones from the 66 on instead? from where they connect on the trans to the drum... would this be possible? or do they connect diffently? or are they different all together?
THanks _________________ 1952 Zwitter
1959 23 Window
1963 Doubleturd
1958 Patina Beetle EJ25
1984 Vanagon Westfalia EJ25
1964 Lifted Mouse Grey Standard
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Sun Jun 21, 2009 9:17 pm Post subject: |
The whole shebang will fit, no problem. The 1966 RGBs will gear it higher, the brakes will be bigger, and the wheel cylinders will cost a lot less. Most of the braking power is at the front so I don't know how it will feel to have the bigger brakes just at the rear. I have 1964-1967 transaxles and later model frontends on all four of my older model buses. _________________ Don't worry; be happy. (Baba) |
Kombi Samba Member
Joined: August 02, 2002 Posts: 562 Location: Edmonton, AB, Canada
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Sun Jun 21, 2009 9:29 pm Post subject: |
Campy wrote: |
the wheel cylinders will cost a lot less. |
The wheel cylinders are identical from '55-'70, so I wouldn't look forward to a savings there. |
Campy Samba Member
Posted: Sun Jun 21, 2009 9:41 pm Post subject: |
Brain cramp. Thanks, Greg. _________________ Don't worry; be happy. (Baba) |
Posted: Mon Jun 22, 2009 4:41 am Post subject: |
thank you everyone... I actually already have a 65 beam up front. so now i will have that and 66 rgb-s _________________ 1952 Zwitter
1959 23 Window
1963 Doubleturd
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
Posted: Mon Jun 22, 2009 4:42 am Post subject: |
I emailed him already... still havent gotten a reply _________________ 1952 Zwitter
1959 23 Window
1963 Doubleturd
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
Clara Samba Member
Posted: Mon Jun 22, 2009 6:32 am Post subject: Re: Early trans to 66 reduction boxes... Question |
icekoffee wrote: |
THanks |
the short answer is yes you can take the big nut boxes and put them on your center section.
The longer answer is...
well, do a search and look up reduction rebuild... there is a tutorial that explains it, by hazetguy, with pics.
Also, read through your Bentley on it.
The axle shafts are the same, but I'd pull them off, use the best ones,a nd inspect the crown gears and fulcrum plates and upgrade worn parts as needed.
you will want to remove the tranny to do this, . I am sure you can replace it in situ, but not worth it. Plus you might want to replace old tranny mounts and shift linkage bushings and dust covers.
Another option is do a search on drum puller or stuck drum to figure how to separate the drum from the axle shaft.
In order to pull the rgb box/tube off the tranny, you will need to remove that drum.
Always use grease or anti-seize when putting a drum on the axle.
You may want to clean up and paint you new tube/s boxes, takes them apart and check all the bearings, and there is a plug on the inside that must be remove to replace the inner bearings.
Here is a helpful exploded view from the Parts List:
http://vintagebus.com/parts/5867part/285.png _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
