slammed super skid plate advice
infantibus
infantibus is offline
PostPosted: Sun Jan 03, 2010 7:05 am    Post subject: slammed super skid plate advice Reply with quote
Recently i dumped my dads super in the weeds.
i have a skid plate from a 4x4 ranger that will be modified to cover the control arm mounts from bashing the ground. I have already bottomed out a few times and care not to rip something off @ high speeds.
rolling hard.
my query is should i fab the plate to bolt on and off by drilling holes in the bulkhead or should a just weld it on?
lowmitsu
lowmitsu is offline
PostPosted: Sun Jan 03, 2010 8:40 am    Post subject: Reply with quote
The skid plate isnt gonna last long if its that low.You are better off not using one.I've been driving slammed vehicles for 20 + years with no issue.The key is to watch where & how you drive.
Tommy Wolff
1974 Standard Beetle
1966 Beetle (kudzu project)
1968 Type 3 Notchback
1963 Chevy Nova SS
1999 Passat wagon
Southern Integrity Aircoolers
http://www.vwdragnight.com/
jmsmilin
Samba's Most Posted
jmsmilin is offline
PostPosted: Sun Jan 03, 2010 8:46 am    Post subject: Reply with quote
thats one low 73, post some side shots
Der Schmutzige Süden.
(o\ ! /o) | o \/ o | (o)=|=(o) [o\|_|_|/o] \m/
chickengeorge
Samba Ricer
chickengeorge is offline
PostPosted: Sun Jan 03, 2010 10:07 am    Post subject: Reply with quote
Bolt it.
zombie
zombie is offline
PostPosted: Sun Jan 03, 2010 11:00 am    Post subject: Reply with quote
slammed cars make you a better driver.
I run two fuel filters in my engine bay.
iVolkswagen
The Modern-Day Hippie
iVolkswagen is offline
PostPosted: Sun Jan 03, 2010 11:55 am    Post subject: Reply with quote
Found some.
TJ
\/OLKSWAGEN
- 1963 Beetle - 1987 Cabriolet
Juice C
Juice C is offline
PostPosted: Sun Jan 03, 2010 12:25 pm    Post subject: Reply with quote
I like it. Cool I say just drive carfully and lower the back alittle more to get the sway bar off the ground.
Culito
11010101
Culito is offline
PostPosted: Sun Jan 03, 2010 4:44 pm    Post subject: Reply with quote
Yes.
Copyright CJ Industries, Inc.
'64 standard
'62 bug
johnnypan wrote:
infantibus
PostPosted: Sun Jan 03, 2010 9:18 pm    Post subject: Reply with quote
The back is going to be lowered when the new cofap shocks arrive this week.
before i try the plate im going to try and mount some 3\8 thick rubber from a big rig mudflap. Some greaser\rodder guy has something similar on his old bagged lead sled. more pics when work is finished
LeviMan2001
Samba Post Whore
LeviMan2001 is offline
PostPosted: Sun Jan 03, 2010 11:53 pm    Post subject: Reply with quote
Hmmm, that's an interesting Idea actually
http://www.thesamba.com/vw/forum/viewtopic.php?t=366056 - My '73 Super Build. 2332cc, 16" Fuchs
VeroDubs
VeroDubs is offline
PostPosted: Mon Jan 04, 2010 5:18 pm    Post subject: Reply with quote
I am making a skidplate for my super because no matter how hard you try... eventually you rill hit something.
My super hit the little lip in front of overpasses on the interstates. I had less than a half inch of clearance depending on the load in the car!
I was thinking of using 1/4" aluminum plate, same thats used for aftermarket plates on later model VW's.
I will draw a small design of what I was thinking in a bit!
Rick73Super
Rick73Super is offline
PostPosted: Mon Jan 04, 2010 5:44 pm    Post subject: Reply with quote
Although, it is not a daily driver, this VW is driven frequently by me its owner and the mechanic infantibus in Philly. City streets are rough, it bottoms out crossing well paved intersections because of the crown in the road. I'd like the underside to have some protection. It looks like the mud flap idea might work, I'll post pix (if I can get a camera under the car).
infantibus
PostPosted: Tue Jan 05, 2010 1:24 pm    Post subject: Reply with quote
ok well the sway bar mounts are protected. basically i just cut a square the same size of the mount and drilled a hole through it, and mounted it with the sway bar mount itself.
i need you to take some pics dad so people can see.
the main idead is not for it to be pretty but for it to be functional.
i do need new brackets as they have almost already ground through.
the other mechanic here thinks that a metal plate will do the best, i was under an 08 impala today and the aluminum subframe that cradles the engine and trans looks like it has the perfect approach angle and strength.
now im just waiting for new shocks to come form the factory to lower the back down.
infantibus
PostPosted: Tue Jan 05, 2010 1:25 pm    Post subject: Reply with quote
i have a skid plate from a mid 90's ranger the i was cosidering modifying will take pics after measurements are taken.
Rick73Super
PostPosted: Tue Jan 05, 2010 1:41 pm    Post subject: Reply with quote
How about this for the back?
infantibus
PostPosted: Tue Jan 05, 2010 3:10 pm    Post subject: Reply with quote
looks great can you come by the shop to take some pics for these guys?
Rick73Super
PostPosted: Tue Jan 05, 2010 4:55 pm    Post subject: Reply with quote
tomorrow
and I ordered the plate
infantibus
PostPosted: Wed Jan 06, 2010 5:43 pm    Post subject: Reply with quote
Alright since im still waiting for new shocks to come in here is a teaser for yall
before rebuild
after, total props to glenn from the northeast. that thing is going in as soon as we're down.
skid plate schematics coming soon
infantibus
PostPosted: Fri Jan 08, 2010 6:23 pm    Post subject: Reply with quote
The steel stock has arrived courtesy of my buddy rob, its a sheet of 1/4 thick steel plate. my main plan was to make the skid plate boltable to the existing front bumper mounts.
Today i installed new cofap rear shocks. They required some grinding due to them not fitting in stock locations.
I read once through on airkewld's drop your rear article it looks pretty simple. any advice for first timers would be appreciated. i will be chaining and jackstands underneath the arm to support everything.
The rear will be going down 2 clicks, and hopefully that will level everything out.
dueces.
LeviMan2001
Samba Post Whore
PostPosted: Sat Jan 09, 2010 3:28 am    Post subject: Reply with quote
1/4"!?!?! Do you even need lowering struts after you put that on? Shocked
