PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6245 Location: Portland OR
Posted: Mon Jun 22, 2009 3:28 pm Post subject: What Size Torque Wrench Do I Need? |
I need to buy a torque wrench and I was wondering what range do most of the bolts on a Vanagon fall into. There are a lot of choices and price ranges. 10-75 ft-lbs, 5-80, 20-150, 25-250, etc. 1/2" or 3/8 drive. I probably will never do an engine tear down, but I will do most everything else. I'd like to stay within $125.
What size wrench have people found most useful? What's the highest torque bolt I'll need to tighten?
Thanks! _________________ 89 Westy 2.1 Auto |
WestyLuna Samba Member
Joined: May 19, 2009 Posts: 10 Location: Vancouver, BC
Posted: Mon Jun 22, 2009 3:47 pm Post subject: |
I searched for this last week. Check out this previous post:
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...uts+torque
It says you'll need something that goes up to 150 Ft/lb as lug nuts should be torqued to 133. _________________ ----------------------
86 Westy AT (Luna) |
Posted: Mon Jun 22, 2009 6:17 pm Post subject: |
I have heard several complaint of 1/2 drive torque wenches breaking if used much at over 150 ft*lbs. That pretty much negates buying anything that would read higher. For your rear axle nut just standing on your breaker bar is accurate enough.
I own a 150 ft*lb clicker and a 3/8 beam and somewhere buried were I can no longer find it is a 1/4 beam which I miss. |
reluctantartist Samba Member
Joined: August 13, 2006 Posts: 1927 Location: Bloomington, IN
Posted: Mon Jun 22, 2009 7:48 pm Post subject: |
In my experience you really need two....the large one 20 -150 ft/lbs and an inch/lbs one for the more delicate torque settings under 20 ft/lbs. It is nice to know that you are getting something in aluminum tight enough without stripping the bolt. _________________ 1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them. |
msinabottle Samba Member
Posted: Mon Jun 22, 2009 8:56 pm Post subject: My Solution for Inch-Pounds |
This device works pretty well for minute adjustments in inch-pounds, up to 65 inch-lbs:
http://www.midwayusa.com/viewProduct/?productNumber=718023
The price is good. You can get a 1/4 to 3/8" adapter to use it with a conventional socket set. I bought this mostly for Winston's windshield washer screws, and... Er... more explosive uses.
